Essential mods?
My white 2007 is now bone-stock, and I'm good with that.
However, I'm wondering if there are any upgrades - mechanical or cosmetic - that are considered a must for a long-term Shelby GT.
The only thing that currently interests me is a lower grille to protect the cooling fins in there. Also synthetic lubricants at some point, unless synthetics are factory fill.
The scoop upgrade is also on the list.
What else?
You are correct that the lower grill is a must. I suggest some suspension pieces, specifically upper and lower control arms and a Watts Link or adjustible panhard bar to center the rear wheels under the car. Getting drilled and slotted brake rotors, with stainless steel lines and Hawk brake pads would be nice as well.
Jim
Lower Grille was first priority on my list just for the reason you listed...I bought my SGT to drive, so I was very concerned about how open that was down there...Next was the Panhard bar to re-center the rear end since the car was lowered and SAI didn't seem to think to put in an adjustable panhard bar...DOH! The panhard bar will get the rear end where it should be...if you go to larger tires/wheels like I did, you'll definately notice it more...Brakes are also good to upgrade...I just added the Front Brembos off of a GT500 to my SGT...they will NOT fit stock SGT wheels though, so be aware of that...unless you use some spacers...I bought GT500 wheels so not an issue...Stainless Steel brake lines are a must with any brake upgrade...J&M and STEEDA both make lines that are pretty much exact factory replacements...Goodridge are very close, but not exact...the J&M and Steeda lines are not cheap...the Goodridge are a little less expensive if you look around...I got mine for about 160.00...
#1 must do mod for a stock SGT = custom tune. Google Brenspeed or VMP.
Ken
Hey Ken,
Does a custom tune stop all or at least some of the black all over the exhaust tips? Mine must be running pretty ruch, cause it's always black all over the tips...
Carl
Hey Ken,
Carl
Yeah man it definitely will, if the custom tune is setup right. If you have black soot on the muffler tip, you're definitely running rich.
But the tune from SAI isn't much more aggressive than the stock Ford tunes on the MGT's. A custom tune will make your car perform better, unlock hidden HP, and increase throttle response.
It's a heck of a bang for the buck mod. Beyond that, I'd say tires and brakes.
Ken
I'm in the slow process of doing what I feel are the "must haves". See my sig for the items and links.
I also want the lower grille and Shelby brake ducts.
I'm not exactly decided on the lower control arms yet; if I do them it will be with the adj. panhard bar. Or, I may go w/ a Watts Link.
I'm saving the custom tune for the post warranty days, but I do see a Brenspeed tune in my future.
I also want the aluminum driveshaft.
Edited by ilmor
What else?
The "else" depends on what you intend to do with the car.
Many of the suggestions you've seen here are intended to improve the pavement-ripping or corner-carving behavior of the beast. The SGT is good for both those, in stock form, but adding the suspension and brake parts mentioned will make it even gooder.
My process was:
· protect the car (lower grill insert; dual-action buffer for the paint and wax; car cover for use even when it's parked indoors)
· increase my enjoyment of the car (custom tune by [your choice among Brenspeed, JLT, BamaChips, and a very few others] will change the experience in quality and quantity; turn off the radio, so I could hear all the sweet sounds of driving; wider wheels and tires because they not only add to performance in an appropriate way, but make me feel better as I drive, knowing they look good!).
· increase braking and handling performance and thereby safety (bigger tires, wider wheels; larger brakes; more anti-sway front and rear).
· increase power (that custom tune will do plenty in that direction; you may want more).
The 'net is loaded with opinions.
All that sounds good, but I want to keep it SCCA F-stock Solo legal, so most of those won't work.
You did not mention shocks though. What are the shocks on the car?
Had not thought about an AL driveshaft. I like that idea.
I also like braided brake lines. I doubt I'd do the full brake upgrade.
No SC for me. I'd have bought a 500 if I'd wanted boost.
Panhard rod sounds interesting. What locates the axle laterally now?
What's involved in a Brenspeed or other tune? Do you take the car to the shop, or do you buy a chip, or have it flashed or what?
The panhard rod locates the rear of the car now, but it is NOT an adjustable one...therefore, when SAI lowered the car by putting in the Ford Racing Springs, it moved the rear end over toward the driver's side of the car about 1/8 of an inch. Not much, but if you ever go to wider wheels and tires, you will definately notice it...
1st, spend some time perusing the mod/tech section. All of your questions so far have already been asked and answered in previous threads.
As for the tune, Google Brenspeed. You can buy the programmer from them. It arrives in the mail with the custom tune already loaded.
Plug & play.
Ken
Yeah, w/ respect to the slotted/drilled rotors (which I already bought), I thought of this also. You can change the lines and the pads and stay stock, but no the rotors. I'm sort of on the edge about changing them now because once you "modify" then your in a class where a lot more mods are needed (i.e. $$$) to stay competitive.
20" shelby razors
supersnake quarter window scoop
lower grill
install brake duct bezels with brake ducts (uninstall come race day)
sequential brake lights
shelby upgraded leather interior
shelby gauge pod
Carroll Shelby's signature on the airbag cover (A MUST)
Roll bar or cage (if wanted)
That's all I could think of that could keep you in F stock.
I'll probably be seeing you out there from time to time.
Best of luck!
quote: Getting drilled and slotted brake rotors, with stainless steel lines and Hawk brake pads would be nice as well.
I just completed this type of install today. Took my time but I am sure tired. Now if it stops raining I can bed them in on Sunday.
Jim
Take your pick
AFCO Pro Series Dual Pass Intercooler Heat Exchanger
Agent 47 Side Mirrors
Agent 47 Brake Cooling Kit and Lower Grille Inserts
Agent 47 Upper Honeycomb Grille with OEM Fog Lights
Alsa Killer Chromed Power Steering Pump
AmericanRacing 1 5/8 Long Tube headers with H pipe FRRP Bolts
ATE Super Blue DOT 4 Racing Brake Fluid
AutoMeter Cobalt Gauges (Full Sweep Electric) Boost, Oil & Fuel pressure
Baer DecelaRotors Drilled and Slotted
BMR Prothane Bullet Motor Mount
BMR Driveshaft Loop
Chip Beck Fiberglass Hood Scoop and painted on stripes
Fore Precision High Flow Fuel Rails (Billet Aluminum)
FRPP Push Button Start
FRPP Ford GT 38lb/hr fuel injectors
FRPP 0 degree Ford Racing spark plugs
FRPP Shelby GT500 Duel fuel pump
FRPP Rear Axle Girdle with Chrome Bolts
FRPP Axle Back Mufflers KR500
FRPP 62mm Dual Bore Throttle Body
FRPP 4.10 Gears
FRPP Cold Air Intake
FRPP Front and Rear Anti-Roll Bars
FRPP Racing Blue Valve Covers
Goodridge Stainless Steel Brake Lines
H3R Halo Fire Extinguisher Chrome with Bracket
Hawk HPS Brake Pads
Hurst Short Throw Shifter
Hurst Line Lock with Shifter Knob Button
Hurst Hurst Equipped Retro Emblem
Innovators West Harmonized Balancer – aluminum
J&M Adjustable UCA and LCA
J&M LCA Relocation Bracket
Koni Yellow Adjustable Sport Shocks and Struts
Leonard Racing SpyderShaft1 piece Aluminum drive shaft
MM Products Adjustable Caster Camber Plates
McGard Lug Nuts and Locking Nut
Meziere Electric Water Pump
Midwest Auto Radiator Cover with side extenders
MoleSkin Window Felt
Moroso Coolant Expansion Tank (Aluminum)
Moroso Power Steering Fluid Tank (Aluminum)
Moroso Supercharger Coolant Tank (Aluminum)
Moroso Oil/Air Separator Tank (Aluminum)
Moroso Modular Oil Pan (Aluminum)
Moroso Fuse Box Cover 74220
Moroso Brake Reservoir Cover 74221
Odyssey Deep Cycle Battery PC1200MJT
Oil Mobil 1 5w-20
POR15 Rust treated and Painted Rear End
Raptor Shifter Light (Blue)
Speed of Sound Triple A-Pillar Gauge Cluster
Shelby Billet Engine Caps
Shelby Billet Under Hood Hardware
Shelby Billet Hood Pins 2008
Shelby Billet Pedal Covers
Shelby Berg Snake Faux Gas Cap
Shelby Snake Logo Center Wheel Caps
Shelby Satin Chrome Tail Light Trim
Shelby Satin Chrome Quarter Light Trim
SHR Quarter Window Louvers Painted Black
SHR Billet Fuel Door Black Anodized
Spec Stage 3+ Clutch
Spec Steel Fly wheel
StangMods Clear Rear Side Marker Lenses w/red LED bulbs
StangMods Clear Turn Signal Lens w/stealth bulbs
Steeda Battery Relocation Box
Steeda Bumpsteer kit
Steeda X5 Ball Joints
Steeda Front Street End Link Kit
ThumpRRR 76mm idler tension pulley
UMI Double Adjustable ChroMoly Panhard Bar (Rod Ends)
UPR Shorty Antenna
Vogtland Lowering Springs
Web Electric Sequential Tail Lights
Whipple 550 HO Intercooled Supercharger
Good luck deciding
Andrew
Take your pick
BMR Driveshaft Loop
FRPP 4.10 Gears
Hawk HPS Brake Pads
Oil Mobil 1 5w-20
UPR Shorty Antenna
Good luck deciding
Andrew
Good Lord! Don't forget the custom PINK stripes! :hysterical::hysterical:
Hey Andrew, I see your mods and raise you twenty :lol:
(Here's what my list looks like this week)
Powerplant
Comp XFI stage 2 cams
Comp valve springs
Comp titanium spring retainers
Steeda billet idler pulleys
Moroso aluminum high capacity oil pan
Moroso aluminum oil catch can
RedLine 5W20 synthetic oil
Fuel/Air
Paxton Novi 1200SL satin supercharger @ 9psi boost
FRPP GT500 dual fuel pumps
Ford IAT sensor relocation kit
BBK twin 62mm throttle body
Steeda billet charge motion control plates
Paxton 39# fuel injectors
Electrical
FRPP zero degree spark plugs
SCT Livewire w/ VMP custom 91 tune
Optima red top battery
Cooling
Moroso aluminum coolant reservoir
BeCool super-duty coolant
RedLine Water Wetter coolant additive
Lethal Performance 180* thermostat
Exhaust
JBA shorty exhaust headers
Magnaflow 2 1/2" off road x-pipe
FRPP mufflers (#M-5230-5GT)
Drivetrain
FRPP 4.10 gears
TA differential stud kit
RedLine 75W140 synthetic gear oil
RedLine D4ATF synthetic trans fluid
Griggs GR40ST rear suspension:
Griggs Racing Koni rear coil-overs w/ street shocks & 225# springs
Griggs Racing road race adjustable rear lower control arms
Griggs Racing torque arm
Griggs Racing severe duty adjustable panhard bar
Griggs Racing axle & shock support bracket kits
Griggs Racing heim joints throughout
Wheels/Tires
GT500 18"x9.5" wheels
Goodyear Eagle F1 Supercar 285/40ZR18's
Safety
Halon chrome 2.5 lb. fire extinguisher
Griggs Racing 4 point roll bar (on order)
Brakes
Shelby brake cooling bezels
Baer 'Decelarotor' slotted/drilled front rotors
EBC black zinc slotted/dimpled rear rotors
Hawk HPS pads
Goodridge stainless steel brake lines
Stainless steel speed bleeder valves
Motul RBF 660
Exterior Styling
Painted hood stripes
Painted blue side mirrors
Silver pit stripes
RaceSkinz carbon fiber front splitter
Shelby Bash 'Bullrun' decals
Shelby aluminum quarter window covers
Shelby chrome lower grill
SGT faux gas cap emblem
PIAA lower driving lights
HID headlights
35% black onyx tint
Griggs Racing windshield banner
Interior Styling
Autometer A-pillar gauge pod
Autometer carbon fiber narrow band AFR gauge
Autometer carbon fiber boost/vacuum gauge
Shelby dash gauge pod
Shelby headrest covers
Shelby GT leather trim & silver stitch console cover
FRPP floor mats
SGT dead pedal
CS signed airbag cover (awaiting install)
Engine Bay Styling
Functional Shelby 2nd gen hood scoop
JLT carbon fiber radiator cover
Shelby American/Paxton retro engine bay plaque
Shelby engine cap set
Shelby fuse box cover
FRPP blue cam covers
FRPP strut tower brace
Steeda billet hood struts
Scott Drake billet underhood hardware
UPR fuel pressure gauge
Stereo
Dynamat - rear package tray
