Eibach Pro-Kit Lowering Springs
machinehead
Considering lowering my GT500, mainly for appearance. Don't intend to track the car and really don't push the limits on the streets. I would like to tighten it up though. I drove two Roush cars, a 2009 and a 2010 before I bought the GT500 and the suspension seemed "tighter". Not that they rode any harsher than the GT but they made less noise, less banging.
Local speed shop is recommending Eibach Pro-Kit Lowering Springs. Said I can keep the same shocks and MAY not require an alignment. Wouldn't have to worry about the panhard bar, upper and lower control arms, etc...
OK guys - educate me. Tell me why I should or should not go this route. Remember I'm not racin' the car and want to keep the ride somewhat civil. I know there's a bunch of threads regarding suspesion upgrades and lowering and I've read them, but there seems to be a number of different approaches (i.e. lowering springs, ford racing, coil overs, etc.) Just wanted some opinions on the Eibachs.
I installed the Eibach Pro-Kit lowering springs on my 2008 GT500 and couldn't be any happier with it.
I am still using the stock struts and shocks (will replace later down the road), I did go ahead and install a set of camber bolts (everyone was 50/50 on these), I did get an alignment when I was finished (definitely recommend!) and I did need an adjustable pan-hard bar (was needed).
Hope that helps alittle..
Good Luck!
before
after
+1 Prop kit is perfect. Still a good ride but not extremely harsh, solid on the road, good handling, looks greaat.
I would advise checking alignment and you will definitely require an adjustable panhard bar. I would also recommend checking dif pinion alignment after lowering to ensure you are still within spec.
Pull the trigger and enjoy.
Thanks all. Sounds like an alignment and adj. panhard are in order whatever the lowering method.
An adjustable panhard bar is definitely needed, as are the alignment bolts (and alignment). With the pro kit springs, the panhard bar needs to be shorter (about 1 inch if i remember correctly) than stock.
If you can, I recommend changing the shocks while it's apart to avoid paying double labor. The lower springs will kill the stock shocks pretty quickly.
Dan
Dan
Excellent, thanks Dan. Just the type of feedback I was hoping for. So if I brought my car to you (hypothetically since I'm in PA and you're in Cali I think) you would recommend the lowering springs, shocks, adj panhard, alignment bolts and alignment? Do you know if the ford racing kit includes all of this except the panhard? I can do some research on my own but REALLY appreciate the opinion of someone who knows. Thanks again.
Short answer...yes. But the actual parts I recommend depends on your intended use of the car.
Yes, the Ford Racing kit includes springs, shocks, front/rear sway bars, and strut tower brace. Everything fits 07-10, but the strut tower brace only shows 07-09 GT500 for fitment. So you still need an adjustable panhard bar for proper installation.
It's essentially the same thing as Eibach's "Pro System Plus". It's part number 35115.680
Eibach GT500 suspension
Dan
Thanks man! Main reason is to lower the car for appearance. Don't want it radically lower/slammed. Just want the tires to fit the wheel wells and get rid of the "jacked up" look. No intention of tracking the car. I do want the handling to be crisp and tight. I would really appreciate your thoughts on this.
