edgecomb Posted October 12, 2009 Report Share Posted October 12, 2009 Well, my saga continues, finally picked the car up Friday, drove it for most of the weekend and sometime during sunday afternoon, it started leaking oil. I kinda suspected something when I picked it up, since I could smell something burning off, but I wrote it off as the new car smell breaking in. The leak is significant, it's leaving a small pool of oil in the garage and when I backed out you could see the drops forming a line. I just dropped it back off at the dealer, but I was wondering if anyone else is experiencing any type of leaks in the '10. Link to comment Share on other sites More sharing options...
Alansvt Posted October 12, 2009 Report Share Posted October 12, 2009 Well, my saga continues, finally picked the car up Friday, drove it for most of the weekend and sometime during sunday afternoon, it started leaking oil. I kinda suspected something when I picked it up, since I could smell something burning off, but I wrote it off as the new car smell breaking in. The leak is significant, it's leaving a small pool of oil in the garage and when I backed out you could see the drops forming a line. I just dropped it back off at the dealer, but I was wondering if anyone else is experiencing any type of leaks in the '10. First I have heard of any leaks. I will keep a look out though. Alan Link to comment Share on other sites More sharing options...
ChrisSD Posted October 12, 2009 Report Share Posted October 12, 2009 Oil galley plugs being loose has been a long standing problem. A good tech can get them tightened without removing anything. Link to comment Share on other sites More sharing options...
Burning Blue Star IV Posted October 12, 2009 Report Share Posted October 12, 2009 No leaks to report with my '10 so far. First I've heard of this problem. Link to comment Share on other sites More sharing options...
tdusseau Posted October 12, 2009 Report Share Posted October 12, 2009 Just under mine 2 days ago. Still clean and dry, just passed the 1k mi mark Friday. Link to comment Share on other sites More sharing options...
67gt 500 Posted October 12, 2009 Report Share Posted October 12, 2009 I just got a 2010 and had an oil leak issue and it was the oil cooler. You might want to check that out. The oil from the factory has a dye in it and can be seen with a special light. Link to comment Share on other sites More sharing options...
Still Intense Posted October 12, 2009 Report Share Posted October 12, 2009 No problems with mine yet, and this is also the first that I've heard of this....hopefully this will be an easy fix for you...... Link to comment Share on other sites More sharing options...
fatboy Posted October 12, 2009 Report Share Posted October 12, 2009 aww hell. hope its not major. Link to comment Share on other sites More sharing options...
edgecomb Posted October 12, 2009 Author Report Share Posted October 12, 2009 Just I just got a 2010 and had an oil leak issue and it was the oil cooler. You might want to check that out. The oil from the factory has a dye in it and can be seen with a special light. . I heard from the dealer, its the oil cooler as well, how long did it take them to fix yours?, they're saying wednesday Link to comment Share on other sites More sharing options...
67gt 500 Posted October 12, 2009 Report Share Posted October 12, 2009 I heard from the dealer, its the oil cooler as well, how long did it take them to fix yours?, they're saying wednesday The dealer had to get the oil cooler out of state and it took 2 days to get the car back. its inconvenient but it will be like new. Link to comment Share on other sites More sharing options...
jpierson Posted October 13, 2009 Report Share Posted October 13, 2009 Do you guys hear your oil cooler working in your cars? I can hear a fluid circulation noise when I'm idling. Link to comment Share on other sites More sharing options...
tdusseau Posted October 13, 2009 Report Share Posted October 13, 2009 Do you guys hear your oil cooler working in your cars? I can hear a fluid circulation noise when I'm idling. Does it sound like when you turn the key to run? I am willing to bet you are hearing the fuel pump. But if you are hearing it at idle that is not good either. Usually a loud stock fuel pump while engine is running is a sign something is wrong with it. Can hear mine at startup when it primes the system, but is quiet after that. Link to comment Share on other sites More sharing options...
jpierson Posted October 13, 2009 Report Share Posted October 13, 2009 I don't remember hearing it right away at ignition. I can hear it though if I press down on the clutch or rev the engine a little bit to get her warmed up when I'm stopped. Link to comment Share on other sites More sharing options...
