TexasShelby Posted October 11, 2009 Report Share Posted October 11, 2009 In aviation, there are a small blue absorbent footies that go over the shoe and has elastic and them. They are used to cover your shoe when walking in expensive interiors to guard from tracking stuff in. They would probably fit over the breather and contain or absorb any oil that came out. Just a thought Link to comment Share on other sites More sharing options...
Alloy Snake Posted October 13, 2009 Report Share Posted October 13, 2009 This mod should stop the oil residue buildup I found on the Intercooler fins last time I had the supercharger off,It would have to come from the pcv system.I still think a good oil sample test from Blackstone would be in order after the mod is done to verify what is going on in the crankcase. Link to comment Share on other sites More sharing options...
70SCJ Posted October 14, 2009 Report Share Posted October 14, 2009 Are there any part numbers for the filter and the plugs? I may try a catch can as well. Link to comment Share on other sites More sharing options...
bhcsteve Posted October 15, 2009 Report Share Posted October 15, 2009 Are there any part numbers for the filter and the plugs? I may try a catch can as well. What you say is exactly what I am planning on doing. I have a catch can on order and will mount it with a "T" inline and run both pcv lines from each valve cover to the catch can. I bought a mesh breather cap from Auto Zone and with a little trimming of the rubber bushing, was able to screw it in the oil filler nice and tight. The plugs I haven't gotten yet, but I am sure they're just standard rubber caps that you can slip on. Steve Bullhead City, AZ Link to comment Share on other sites More sharing options...
70SCJ Posted October 19, 2009 Report Share Posted October 19, 2009 What you say is exactly what I am planning on doing. I have a catch can on order and will mount it with a "T" inline and run both pcv lines from each valve cover to the catch can. I bought a mesh breather cap from Auto Zone and with a little trimming of the rubber bushing, was able to screw it in the oil filler nice and tight. The plugs I haven't gotten yet, but I am sure they're just standard rubber caps that you can slip on. Steve Bullhead City, AZ Where are you going to route your catch can discharge line to? Or will you add another breather? Link to comment Share on other sites More sharing options...
mr ford Posted October 19, 2009 Report Share Posted October 19, 2009 My take on the extra power you are feeling is indeed from the cool affect from removing the pcv and Also the affect on the tune,which would be a richer condition so you should be fine. You have removed the pcv, which is a metered air leak in its self. Thats my take. I would also caution that you may create an oil sludge condition over time in the engine due to the gases not being removed. Link to comment Share on other sites More sharing options...
bhcsteve Posted October 20, 2009 Report Share Posted October 20, 2009 Where are you going to route your catch can discharge line to? Or will you add another breather? I just installed the catch can inline back to the nipple on the bottom of the s/c. Decided to just put the catch can on and leave the rest status quo. I removed the stock line and used the stock fittings cutting them off the stock line with about 1 inch line left to fit 5/8ths rubber hose over. Turned out looking like a nice clean install. I thought about discon. the pcv lines entirely but mentioned it to a motorhead friend of mine and he didn't think it would be a good idea because of the lack of proper crankcase ventilation. He did suggest leaving on the oil breather cap which I did and said to try it and see if there feels like any benefit. Said under s/c boost there is an enormous amount of pressure build up in the crankcase and the breather oil cap may help in relieving a lot of that pressure which "may" make a little difference in quicker acceleration. Heck I don't know but I'll try it and if it dosen't seem to make a difference or a oil mess, I'll put the stock oil fill cap back on and leave the catch can of course. Steve BHC Link to comment Share on other sites More sharing options...
Purvis Posted October 23, 2009 Report Share Posted October 23, 2009 Would be interesting to see a before and after on a dyno. Link to comment Share on other sites More sharing options...
70SCJ Posted October 23, 2009 Report Share Posted October 23, 2009 Would hooking up a catch can with a breather on the downstream side while leaving the driver alone be a feasible option? This would still allow the crankcase to be positively ventilated with intake air, however would this "metered leak" be a problem since it was not going back into the engine? Link to comment Share on other sites More sharing options...
