magrag Posted October 4, 2009 Report Share Posted October 4, 2009 Car is 2008 with 8000 miles Ford racing cold air and VMP tune. Drove car into town this AM about 5 miles, on way home noticed engine jerking (missing) like a one cyl was not firing. Babied it for about 2 miles (country road) then said what the heck, put it 3rd and let it rip. Miss when away, drove it later and no problem. Anyone had anything like this and what do you think it is was??? Quote Link to comment Share on other sites More sharing options...
Bloomy63 Posted October 4, 2009 Report Share Posted October 4, 2009 Car is 2008 with 8000 miles Ford racing cold air and VMP tune. Drove car into town this AM about 5 miles, on way home noticed engine jerking (missing) like a one cyl was not firing. Babied it for about 2 miles (country road) then said what the heck, put it 3rd and let it rip. Miss when away, drove it later and no problem. Anyone had anything like this and what do you think it is was??? Mine acts exactly as yours, except it seems to do it after it has sit for a couple of weeks, and only on the initial start up. If when I start it and drive away and it misses, I shut it down, then start it back up and all is fine. Hopefully someone can give some insight as to what is going on. Quote Link to comment Share on other sites More sharing options...
cobra 07 Posted October 4, 2009 Report Share Posted October 4, 2009 noticed engine jerking --- on or off ??? put it 3rd and let it rip.--- bandaids cures all along with a little kiss Miss when away Do you miss her now??????????? after she left Quote Link to comment Share on other sites More sharing options...
svtbird91 Posted October 4, 2009 Report Share Posted October 4, 2009 Possible fuel injector spray pattern issue, maybe slight clog affecting spray. Try a can of fuel injector cleaner in fuel tank. Would be an easy fix certainly worth a try anyway. Quote Link to comment Share on other sites More sharing options...
Kostas Posted October 4, 2009 Report Share Posted October 4, 2009 Car is 2008 with 8000 miles Ford racing cold air and VMP tune. Drove car into town this AM about 5 miles, on way home noticed engine jerking (missing) like a one cyl was not firing. Babied it for about 2 miles (country road) then said what the heck, put it 3rd and let it rip. Miss when away, drove it later and no problem. Anyone had anything like this and what do you think it is was??? It could also be bad fuel. You should take it to the dealer and have them check the car out.... Quote Link to comment Share on other sites More sharing options...
mrfarmdog Posted October 4, 2009 Report Share Posted October 4, 2009 Just a thought but when did you change your plugs last? Quote Link to comment Share on other sites More sharing options...
Slabo Posted October 4, 2009 Report Share Posted October 4, 2009 Just a thought but when did you change your plugs last? +1 pull your plugs and look at them. If you post high res pics of the plugs there are some folks on this forum that are good at reading them. Quote Link to comment Share on other sites More sharing options...
Bloomy63 Posted October 22, 2009 Report Share Posted October 22, 2009 (edited) I pulled the plugs, and they looked fine. Checked the gap and some were a little big @ .044-.049. Gapped them to .042. I took it for a ride today, it idles finem but when i started driving it still was missing for about the first .5 miles. I picked up a set of NGK tr6's. I'll give them a try. Hopefully the new plugs clear it up. I'll also check for codes. magreg, did you have any luck with your's? Edited October 22, 2009 by Bloomy63 Quote Link to comment Share on other sites More sharing options...
Bloomy63 Posted November 8, 2009 Report Share Posted November 8, 2009 I've had the car out several times since I changed the plugs to ngk tr6's and the bucking is gone. I wouldn't of guessed that the plugs were causing the problem with such low mileage on them. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
blkGT500nCA Posted November 9, 2009 Report Share Posted November 9, 2009 Maybe gap the NGK's to .035-.040 and change them often. I swap them out every oil change. For $20 it's cheap insurance. Quote Link to comment Share on other sites More sharing options...
Bloomy63 Posted November 9, 2009 Report Share Posted November 9, 2009 Maybe gap the NGK's to .035-.040 and change them often. I swap them out every oil change. For $20 it's cheap insurance. Yup, that's exactly what I was planning to do, change them every oil change. Quote Link to comment Share on other sites More sharing options...
