battalion chief Posted October 1, 2009 Report Share Posted October 1, 2009 Have been having loud crunching sound when going over speed bumps, etc. and suspension articulates. Carried in to dealer ('07 GT 500 with only 6271 miles). Found front lower control arm bushings had separated. They had to replace both lower arms with an "upgraded" set. Has anyone else had this problem? Link to comment Share on other sites More sharing options...
m81mclaren Posted October 2, 2009 Report Share Posted October 2, 2009 Have been having loud crunching sound when going over speed bumps, etc. and suspension articulates. Carried in to dealer ('07 GT 500 with only 6271 miles). Found front lower control arm bushings had separated. They had to replace both lower arms with an "upgraded" set. Has anyone else had this problem? Can you give us the part#'s on the upgraded set? Link to comment Share on other sites More sharing options...
6-Speed Posted October 2, 2009 Report Share Posted October 2, 2009 Have been having loud crunching sound when going over speed bumps, etc. and suspension articulates. Carried in to dealer ('07 GT 500 with only 6271 miles). Found front lower control arm bushings had separated. They had to replace both lower arms with an "upgraded" set. Has anyone else had this problem? Is your car lowered or at stock height? Link to comment Share on other sites More sharing options...
battalion chief Posted October 3, 2009 Author Report Share Posted October 3, 2009 Can you give us the part#'s on the upgraded set? Best I can make out, they are: AR32*3078*B and AR32*3079*B. Link to comment Share on other sites More sharing options...
battalion chief Posted October 3, 2009 Author Report Share Posted October 3, 2009 Is your car lowered or at stock height? I'm stock! Link to comment Share on other sites More sharing options...
AlloyDropTop Posted October 5, 2009 Report Share Posted October 5, 2009 Are these the big can mounted bushings to the rear or the smaller bushings up front, on the lower control arms? Link to comment Share on other sites More sharing options...
battalion chief Posted October 5, 2009 Author Report Share Posted October 5, 2009 Are these the big can mounted bushings to the rear or the smaller bushings up front, on the lower control arms? Not sure, I didn't see them myself. I'll try to get in touch with my Tech when I get a chance. Link to comment Share on other sites More sharing options...
VaporDude Posted October 5, 2009 Report Share Posted October 5, 2009 Did that help solve any wheel hop issues? Link to comment Share on other sites More sharing options...
battalion chief Posted October 5, 2009 Author Report Share Posted October 5, 2009 Did that help solve any wheel hop issues? These are the FRONT lower control arms. I tried to talk to my Tech today, but he's off for a few days. Link to comment Share on other sites More sharing options...
chuckstang Posted October 6, 2009 Report Share Posted October 6, 2009 my tech told me this is costly if out of warranty and very common oh oh Link to comment Share on other sites More sharing options...
AlloyDropTop Posted October 7, 2009 Report Share Posted October 7, 2009 Can you give a more detailed discription of the noise? When it happens, etc... ? Link to comment Share on other sites More sharing options...
battalion chief Posted October 8, 2009 Author Report Share Posted October 8, 2009 Can you give a more detailed discription of the noise? When it happens, etc... ? The best way to describe the noise is like a loud "scrunch" sound, like metal rubbing together. Mine was most noticable when turning hard to the left or right and the suspension articulating up and down going over uneven pavement. Link to comment Share on other sites More sharing options...
battalion chief Posted October 15, 2009 Author Report Share Posted October 15, 2009 Are these the big can mounted bushings to the rear or the smaller bushings up front, on the lower control arms? Sorry for being so long in getting back! My Tech said it was the smaller front bushing. Link to comment Share on other sites More sharing options...
battalion chief Posted October 15, 2009 Author Report Share Posted October 15, 2009 Can you give us the part#'s on the upgraded set? Sorry to take so long in getting this info put up, but it's been busy around here. Service advisor stated it was covered under TSB 07-23-1 and covered cars built before 28 Feb. 2007. Link to comment Share on other sites More sharing options...
6-Speed Posted October 16, 2009 Report Share Posted October 16, 2009 Sorry to take so long in getting this info put up, but it's been busy around here.Service advisor stated it was covered under TSB 07-23-1 and covered cars built before 28 Feb. 2007. TSB 07-23-1 applies to the 2005-2007 Mustangs 4.0L/4.6L with a build date before 2/28/2007. Here are the parts called out on the TSB: 7R3Z-3078-A Arm Assembly-Front Suspension - RH 7R3Z-3079-A Arm Assembly-Front Suspension - LH I understand the GT500 uses a different LCA than the Mustang. Do the replacement part numbers from your invoice match these? Here are the LCAs for the GT500. http://www.fordracingparts.com/parts/part_...rtKeyField=9632 Link to comment Share on other sites More sharing options...
battalion chief Posted October 16, 2009 Author Report Share Posted October 16, 2009 TSB 07-23-1 applies to the 2005-2007 Mustangs 4.0L/4.6L with a build date before 2/28/2007. Here are the parts called out on the TSB: 7R3Z-3078-A Arm Assembly-Front Suspension - RH 7R3Z-3079-A Arm Assembly-Front Suspension - LH I understand the GT500 uses a different LCA than the Mustang. Do the replacement part numbers from your invoice match these? Here are the LCAs for the GT500. http://www.fordracingparts.com/parts/part_...rtKeyField=9632 Yes, he explained that the TSB upgrades the control arm on the GT (see the statement in the FRPP ad you quote) to the GT 500 spec ones and he used this fact to replace mine without a lot of hassle from Ford; apparently Ford is aware of the problem and is less than happy with having to replace them. My 3 year warranty was due to run out in a couple of days and he was tring to help me out; correct parts for my car, no questions asked! My dealer goes the extra mile! Link to comment Share on other sites More sharing options...
6-Speed Posted October 16, 2009 Report Share Posted October 16, 2009 Yes, he explained that the TSB upgrades the control arm on the GT (see the statement in the FRPP ad you quote) to the GT 500 spec ones and he used this fact to replace mine without a lot of hassle from Ford; apparently Ford is aware of the problem and is less than happy with having to replace them. My 3 year warranty was due to run out in a couple of days and he was tring to help me out; correct parts for my car, no questions asked! My dealer goes the extra mile! Makes Sense - glad all is well now. Link to comment Share on other sites More sharing options...
NICK82 Posted October 16, 2009 Report Share Posted October 16, 2009 The stock lower control arms and bushings are pitiful. Link to comment Share on other sites More sharing options...
sandyman Posted October 16, 2009 Report Share Posted October 16, 2009 my tech told me this is costly if out of warranty and very common oh oh Just find another dealer if it's a problem. Link to comment Share on other sites More sharing options...
chuckstang Posted October 17, 2009 Report Share Posted October 17, 2009 Just find another dealer if it's a problem. My tech told me and I quote Better get the extended warranty! wow ya thats the attitude! Link to comment Share on other sites More sharing options...
