Torched10 Posted September 29, 2009 Report Share Posted September 29, 2009 I havent had issues hooking up like some have had.I am wondering could it have to do with the dfference in weight ratios between the coupe and verts.The coupe i believe ive seen at 56:44 and the verts are 50:50.Have you folks with verts experened better launches,or is my car just slow Link to comment Share on other sites More sharing options...
ChrisSD Posted September 29, 2009 Report Share Posted September 29, 2009 Verts aren't 50/50. Coupe is 57/43 vert is 56/44 I believe. Or 1 point higher on each side. Link to comment Share on other sites More sharing options...
Torched10 Posted September 29, 2009 Author Report Share Posted September 29, 2009 thanks--now i have to go find the article that states the weight ratio differences.Im usually pretty good with numbers,being an engineer,but who knows---ill look. Link to comment Share on other sites More sharing options...
ChrisSD Posted September 29, 2009 Report Share Posted September 29, 2009 thanks--now i have to go find the article that states the weight ratio differences.Im usually pretty good with numbers,being an engineer,but who knows---ill look. I think I saw the same article. You are remembering correctly. The author is just wrong. Link to comment Share on other sites More sharing options...
F150 Duke Posted September 29, 2009 Report Share Posted September 29, 2009 Instead of weight differences could it be a difference in suspension and tires? Link to comment Share on other sites More sharing options...
ChrisSD Posted September 29, 2009 Report Share Posted September 29, 2009 Instead of weight differences could it be a difference in suspension and tires? Verts are softer, this aids weight transfer which should improve launch. Link to comment Share on other sites More sharing options...
Torched10 Posted September 29, 2009 Author Report Share Posted September 29, 2009 In my pursuit of trivial info,i found a refernce that shows verts at 52:48,and coupes at 58:42--whatever that means.The input on the softness factors and smaller wheels must be the reason.If i just completlty floor it fro, m a full stop, i just bearly get a chirp.If i dump the clutch at 2000 it leaves alot more rubber,and if i go thru the first 3 gears it will move me sideways,and finally,if Im in 1st or 2nd and hit it, ill leave rubber easily if i floor it. Link to comment Share on other sites More sharing options...
