justindewoody Posted September 27, 2009 Report Share Posted September 27, 2009 OK, I have installed the Ford Racing Dampers and Springs in the front, and the springs in the rear. But I can't get the rear shocks off!!!!!!!!! When you try to unscrew the nut that holds it in place, the stem just turns with the nut!!!! I have tried to use pliers, small 6mm and 7mm wrenches, and everything else I could think of to hold the stem in place while trying to unscrew the nut, and nothing F**KING WORKS!!!!!!!!!!!!! WHAT THE F!?!?!?!?!??! CAN ANYONE SHED SOME LIGHT ON THIS PLEASE!!?!?!?!?!?! Link to comment Share on other sites More sharing options...
zeindog Posted September 27, 2009 Report Share Posted September 27, 2009 The way you are doing it is the right way. You should try a cresent wrech to hold the small stem and a larger box wrech to turn the nut. Its probably on there pretty good, I know I had issues with the front shocks, they were torqued down pretty damn good. Link to comment Share on other sites More sharing options...
justindewoody Posted September 27, 2009 Author Report Share Posted September 27, 2009 The way you are doing it is the right way. You should try a cresent wrech to hold the small stem and a larger box wrech to turn the nut. Its probably on there pretty good, I know I had issues with the front shocks, they were torqued down pretty damn good. I have tried that. Maybe I will spray some WD-40 on the stem's threads and let it soak for a while and try again. I'm getting extremely frustrated. I might end up having to take it to the dealer and let them install them for me. What's really pissing me off is the fact I know what I'm doing, I'm very mechanically inclined, I have done all the work on my car myself, etc. You know what I mean? It just pisses me off. Link to comment Share on other sites More sharing options...
07-2937 Posted September 27, 2009 Report Share Posted September 27, 2009 air impact wrench is the only way I have seen it done We did 10k shocks that way... Link to comment Share on other sites More sharing options...
justindewoody Posted September 27, 2009 Author Report Share Posted September 27, 2009 I got it done! I sprayed the threads with WD-40 and let it soak for a few minutes. Then I held the stem with a crescent wrench while turning the nut with a box end wrench. Done deal. Thanks for your help! Link to comment Share on other sites More sharing options...
justindewoody Posted September 27, 2009 Author Report Share Posted September 27, 2009 My rear springs are making some popping sounds when driving. They are the Ford Racing lowering springs. Anyone have this problem? Any suggestions? Thanks. Link to comment Share on other sites More sharing options...
blkGT500nCA Posted September 27, 2009 Report Share Posted September 27, 2009 I got it done! I sprayed the threads with WD-40 and let it soak for a few minutes. Then I held the stem with a crescent wrench while turning the nut with a box end wrench. Done deal. Thanks for your help! That's how I did it. We don't need no stinkin air tools. LOL My rear springs are making some popping sounds when driving. They are the Ford Racing lowering springs. Anyone have this problem? Any suggestions? Thanks. Ah , you sure you got the shocks re-tightened back up? Did you replace them, or just disconnect them to get the springs out? Link to comment Share on other sites More sharing options...
justindewoody Posted September 27, 2009 Author Report Share Posted September 27, 2009 That's how I did it. We don't need no stinkin air tools. LOL Ah , you sure you got the shocks re-tightened back up? Did you replace them, or just disconnect them to get the springs out? Yes, they are tightened and installed properly, definitely. The popping is coming from the springs, I think up inside the body where they sit. I probably need to find some rubber bushings to go up in there. Link to comment Share on other sites More sharing options...
blkGT500nCA Posted September 27, 2009 Report Share Posted September 27, 2009 Yes, they are tightened and installed properly, definitely. The popping is coming from the springs, I think up inside the body where they sit. I probably need to find some rubber bushings to go up in there. That suck. Report back and let us know what you find. Don't you just love explaining to the Mrs. how the modifications you just added are now causing problems. LOL. I wonder sometimes why we put ourselves through so much. Link to comment Share on other sites More sharing options...
6-Speed Posted September 27, 2009 Report Share Posted September 27, 2009 Yes, they are tightened and installed properly, definitely. The popping is coming from the springs, I think up inside the body where they sit. I probably need to find some rubber bushings to go up in there. There already is a rubber isolator in the spring pocket, at least there was in the 07-09 models. Don't know why the 2010 model would be any different. If you replaced the rear shocks - perhaps the shocks themselves are the culprit. Link to comment Share on other sites More sharing options...
justindewoody Posted September 27, 2009 Author Report Share Posted September 27, 2009 There already is a rubber isolator in the spring pocket, at least there was in the 07-09 models. Don't know why the 2010 model would be any different. If you replaced the rear shocks - perhaps the shocks themselves are the culprit. AHA!!!! I must not have lined the springs up to the notch inside there! I will have to check that out and re-align them. EXTREMELY HELPFUL POST!!!! THANK YOU!!!! Link to comment Share on other sites More sharing options...
justindewoody Posted September 27, 2009 Author Report Share Posted September 27, 2009 I adjusted the positioning of the rear springs and BINGO! Problem solved. That post with the shot of the spring hole was extremely helpful. There is no more popping or any other noises. THANKS!!!! Link to comment Share on other sites More sharing options...
6-Speed Posted September 28, 2009 Report Share Posted September 28, 2009 Glad you found and fixed the problem. Link to comment Share on other sites More sharing options...
