Still Intense Posted September 23, 2009 Report Share Posted September 23, 2009 Need to know the general opinion on this question: I've added FRPP springs to the Shelby and it lowered the car 1.25 inches at all four corners. Have also put on an adjustable Panhard bar, Panhard bar brace, and adjustable third link. What is everyone's opinion on the need to ALSO add lower control arm relocation brackets? Lower control arms are stock and are still in the stock location; relocating them is turning into a challenge; the car is not raced but is driven hard on the street and I don't want to cause problems.... Thanks in advance for your advice! Link to comment Share on other sites More sharing options...
chuckstang Posted September 23, 2009 Report Share Posted September 23, 2009 Simple Don't do it Not needed Why do you want to anyway, are you haveing problems now still with wheel hop, traction? If its traction, get some better tires. I don't even run an adj UCA and have no issues. I'd leave it alone, thank me later Link to comment Share on other sites More sharing options...
Still Intense Posted September 23, 2009 Author Report Share Posted September 23, 2009 Chuck, once again you have provided the kind of answers that I appreciate: direct and brief. Appreciate the info; it was getting to be too much effort for too little gain. Anyone else have a differing opinion? Link to comment Share on other sites More sharing options...
LuisA Posted September 23, 2009 Report Share Posted September 23, 2009 If you drive hard you will get wheel hop, if you do, install the J&M UCA and LCA........they work very well.....tested up to 624RWHP on my previous GT500. Link to comment Share on other sites More sharing options...
Still Intense Posted September 23, 2009 Author Report Share Posted September 23, 2009 Got it Luis. So aftermarket LCAs. What about relocation brackets for the LCAs? The new LCAs would still use the factory mounting locations otherwise....or doesn't that matter in your opinion? Link to comment Share on other sites More sharing options...
LuisA Posted September 24, 2009 Report Share Posted September 24, 2009 I did not use relocation brackets. In my opinion you do not need them for street driving. You may also want to look into the Fays2 watts link.....it made a signifficant difference. Link to comment Share on other sites More sharing options...
Still Intense Posted September 24, 2009 Author Report Share Posted September 24, 2009 Got it Luis. As I suspected, too much work for nearly zero return. Thanks for the help... Link to comment Share on other sites More sharing options...
