08 Mustang Posted October 6, 2009 Report Share Posted October 6, 2009 Cam---id paint it soon--dont wait on Ford.Grabbers looks better than new.Nice meeting you this weekend Will do, thanks. It was nice meeting you too. Look forward to seeing you again. I just noticed something wierd. The block pattern on your car tire is different from mine. Was there a design change later on? Anybody see what I'm seeing? Here's the rear tire from my car showing 6 rows of tread. Link to comment Share on other sites More sharing options...
OldSchool Posted October 6, 2009 Report Share Posted October 6, 2009 Testing? I've been testing mine for almost two years! That's encouraging though. What type of place did you take your car to get the underside rust issue taken care and the axle housing painted? Did you have your dealer do it, body shop, paint shop, where? Link to comment Share on other sites More sharing options...
Torched10 Posted October 6, 2009 Report Share Posted October 6, 2009 What type of place did you take your car to get the underside rust issue taken care and the axle housing painted? Did you have your dealer do it, body shop, paint shop, where? I did mine myself--if you have someone else do it they wont be as careful as you in taping off your car t0o prevent overspray.If its already rusty,youll have to use black, and several other colors,aluminum.cast iron,which are a bear if they get on your paint.Look at the post Grabber has made. I was lucky to have a friend who has a lift,.but id think if you could get the rear up on ramps you could get at it.I used a brush on inhbitor to cut down on the spray part then used a Krylon clear,since mine wasnt rusty yet,I really ;like the Eastwood paint products,which will match the current colors under the the car.Id use a semi-sloss, a gloss on the center piece, aluma Blast, and cast iron or spray grey near the wheelsGood luck Link to comment Share on other sites More sharing options...
6-Speed Posted October 6, 2009 Report Share Posted October 6, 2009 What type of place did you take your car to get the underside rust issue taken care and the axle housing painted? Did you have your dealer do it, body shop, paint shop, where? Was done in my garage with the car on jack stands and using a paint brush. Link to comment Share on other sites More sharing options...
BDrool Posted October 7, 2009 Report Share Posted October 7, 2009 08 Mustang Thanks for confirming. But your wheels (and your screen name) give the tire away as an 07-09. Dragpack just got his GT500. The '10 has a newly designed F1 tire and I confirmed on mine, 5 rows front and back. Unless, DragPack didn't get a '10 model and then that would answer my confusion. Link to comment Share on other sites More sharing options...
Torched10 Posted October 7, 2009 Report Share Posted October 7, 2009 Was done in my garage with the car on jack stands and using a paint brush. It really looks great--what type/brand paint did you use--where buy--its so smooth,did you use a special brush.Brushing it on would save alot of taping time Link to comment Share on other sites More sharing options...
2010 Grabber Blue Shelby Posted October 7, 2009 Report Share Posted October 7, 2009 Was done in my garage with the car on jack stands and using a paint brush. Where did you jack up the car from and where did you place the stands? I was told not to jack it from the pumpkin. Link to comment Share on other sites More sharing options...
6-Speed Posted October 8, 2009 Report Share Posted October 8, 2009 It really looks great--what type/brand paint did you use--where buy--its so smooth,did you use a special brush.Brushing it on would save alot of taping time Thanks. The finish isn't really as smooth as you'd think; there are some rough spots that I should have smoothed out after priming and prior to applying the top coat. I applied two coats of Master Series silver primer and one coat of Master Series Satin black Top Coat. Used a high quality bristle brush for the primer and a foam brush for the top coat. I only painted the axle tubes and brackets since back in 2007 Ford still painted the pumpkin. The photo shows the products I used to clean and finish the axle. I don't think I would use the Master Series top coat again as it was very thick and difficult to apply smooth. It is a 2-part paint. But the combination of the primer and the top coat makes for a very tough barrier to rust. Details in this thread. http://www.teamshelby.com/forums/index.php...l=master+series Link to comment Share on other sites More sharing options...
6-Speed Posted October 8, 2009 Report Share Posted October 8, 2009 Where did you jack up the car from and where did you place the stands? I was told not to jack it from the pumpkin. Then you don't want to hear my answer. Link to comment Share on other sites More sharing options...
Torched10 Posted October 8, 2009 Report Share Posted October 8, 2009 Thanks. The finish isn't really as smooth as you'd think; there are some rough spots that I should have smoothed out after priming and prior to applying the top coat. I applied two coats of Master Series silver primer and one coat of Master Series Satin black Top Coat. Used a high quality bristle brush for the primer and a foam brush for the top coat. I only painted the axle tubes and brackets since back in 2007 Ford still painted the pumpkin. The photo shows the products I used to clean and finish the axle. I don't think I would use the Master Series top coat again as it was very thick and difficult to apply smooth. It is a 2-part paint. But the combination of the primer and the top coat makes for a very tough barrier to rust. thanks--great input--where did you buy the paint??Seems to be holding up pretty well Link to comment Share on other sites More sharing options...
Torched10 Posted October 8, 2009 Report Share Posted October 8, 2009 Where did you jack up the car from and where did you place the stands? I was told not to jack it from the pumpkin. do a forum search--i recall jacking instrusions ahve been posted--maye by Grabber Orange Link to comment Share on other sites More sharing options...
6-Speed Posted October 8, 2009 Report Share Posted October 8, 2009 thanks--great input--where did you buy the paint??Seems to be holding up pretty well From Master Series: http://www.masterseriescoatings.com/index/ Link to comment Share on other sites More sharing options...
Grabber Posted October 9, 2009 Report Share Posted October 9, 2009 Where did you jack up the car from and where did you place the stands? I was told not to jack it from the pumpkin. Here's the 2010 jacking instructions. http://www.teamshelby.com/forums/index.php...st&p=733474 Link to comment Share on other sites More sharing options...
Grabber Posted October 9, 2009 Report Share Posted October 9, 2009 Where did you jack up the car from and where did you place the stands? I was told not to jack it from the pumpkin. This could help too. http://www.teamshelby.com/forums/index.php...ic=29264&hl= Link to comment Share on other sites More sharing options...
Burning Blue Star IV Posted October 12, 2009 Report Share Posted October 12, 2009 Finally crawled under my car to check out the rear axle rust today. Wasn't really too bad. Really not a big deal to me. But yes, I agree Ford should have just painted them in the first place. I got some Rustoleum Rust Reformer to treat it with. Got most of the areas covered. I'll hit the rest of it tomorrow. Link to comment Share on other sites More sharing options...
Torched10 Posted October 12, 2009 Report Share Posted October 12, 2009 Finally crawled under my car to check out the rear axle rust today. Wasn't really too bad. Really not a big deal to me. But yes, I agree Ford should have just painted them in the first place. I got some Rustoleum Rust Reformer to treat it with. Got most of the areas covered. I'll hit the rest of it tomorrow. Blue--are you paintin it,or just killing the rust.Spray or brush??I tretaed the rust,then cleared it back in July--still looks good,although havent been on wet roads yet Link to comment Share on other sites More sharing options...
Burning Blue Star IV Posted October 12, 2009 Report Share Posted October 12, 2009 Hi Torched10. The first product is a rust reformer or converter. It changes into a black primer when dry..it comes in a spray. Then I'm going to put on some sealer afterwards. Should be fine. I've driven my car in the rain...probably 10 times maybe more since I've had it. I think the design of bottom of the car helps keep the water splash up, etc to minimum. Link to comment Share on other sites More sharing options...
2010 Grabber Blue Shelby Posted October 12, 2009 Report Share Posted October 12, 2009 Here's the 2010 jacking instructions. http://www.teamshelby.com/forums/index.php...st&p=733474 Thanks. Jim Link to comment Share on other sites More sharing options...
Torched10 Posted October 12, 2009 Report Share Posted October 12, 2009 Hi Torched10. The first product is a rust reformer or converter. It changes into a black primer when dry..it comes in a spray. Then I'm going to put on some sealer afterwards. Should be fine. I've driven my car in the rain...probably 10 times maybe more since I've had it. I think the design of bottom of the car helps keep the water splash up, etc to minimum. Thanks--hope i dont have to test the water qualities of the underdesign--i know when we had 15in of rain 2 weeks ago,i drove my EXT thru some deep water,and got a check engine light.Called On Star and they diagnosed it remotely and told me it was an oxygen sensor.My buddie has a code anysis hand held unit,got the same code,cleared it and its been great since.I need to buy one of those units.Wish Ford had On Star. Link to comment Share on other sites More sharing options...
Burning Blue Star IV Posted October 12, 2009 Report Share Posted October 12, 2009 Thanks--hope i dont have to test the water qualities of the underdesign--i know when we had 15in of rain 2 weeks ago,i drove my EXT thru some deep water,and got a check engine light.Called On Star and they diagnosed it remotely and told me it was an oxygen sensor.My buddie has a code anysis hand held unit,got the same code,cleared it and its been great since.I need to buy one of those units.Wish Ford had On Star. I've had one of those hand held units for pulling codes for a long time. I assume the one I have works the same for the 2010 mustangs. Comes in handy at times. Wow...15 inches of rain! We are lucky to get an inch at a time. Link to comment Share on other sites More sharing options...
