AlloyDropTop Posted September 26, 2009 Report Share Posted September 26, 2009 We have a 5.4L Triton work truck with 20K miles and it makes lower end ticking noise, and a customer was in our lot the other day with a 50K mile 5.4 and it made the same noise. Link to comment Share on other sites More sharing options...
wulffy888 Posted September 26, 2009 Report Share Posted September 26, 2009 The Triton engines have a cam phaser which is notorious for making ticking noises, but the 4 valve engines dont have the phasers. I heard the tick a few times on my engine when it had about 800 miles brought on only after a dealer changed the oil for me, but it has never been back since. During that time I checked the oil to make sure they filled it to the correct amount, which it was. I saw a small, very small, piece of what I believe was filter media. The dealer installed the called for FL820s Motorcraft filter, so I though since the engine was new, the pressures were somewhere around 90 psi cold. My thoughts were maybe the high pressures tore some of the filter media loose and was blocking one of the small oil passages in the head? So I changed the oil again, but used a Ford Racing Filter this time. I also changed the plugs to Densos at this time and never heard the noise again. I currently have about 2300 miles on that same oil, but will be changing it again soon. I spoke to a couple of the regional traveling engineers, who stated that its common with the 4 valve engines to tick and to not be afraid to run the engine hard. My translation of that statement: We are aware of the problem, but dont know exactly what it is, so try and break it. This way we can identify the problem to fix it. I have also seen others who have had the Lash Adjusters either replaced or readjusted. They reported to have somewhat fixed the problem, to curing it. I wouldnt be afraid to run the car hard. Its a durable engine. Link to comment Share on other sites More sharing options...
Spring Lil Cobra Posted September 27, 2009 Report Share Posted September 27, 2009 i am very interested in hearing more on this topic. ChriisSD is breaking new ground here. We're all pulling for you brother! Link to comment Share on other sites More sharing options...
OldSchool Posted September 30, 2009 Report Share Posted September 30, 2009 ChrisSD, Drop us a line and let us know where things stand.. Link to comment Share on other sites More sharing options...
Torched10 Posted September 30, 2009 Report Share Posted September 30, 2009 what code racing filter did you use?? Link to comment Share on other sites More sharing options...
Rag Top Day Posted October 1, 2009 Report Share Posted October 1, 2009 Ford just posted this in response to the noise concerns, 2755 - 2007-2010 MUSTANG SHELBY GT500 NORMAL ENGINE NOISE SOME 2007-2010 MUSTANG GT500 VEHICLES EQUIPPED WITH A 5.4L ENGINE MAY EXHIBIT CLATTER/TICK/TAP CHARACTERISTIC ENGINE NOISE. THE NOISE MAY BE CAUSED BY TOLERANCE STACK UP, NOT A SINGLE COMPONENT. DUE TO MANUFACTURING VARIANCES, ALL OF THESE ENGINES WILL EXHIBIT SOME LEVEL OF NOISE. AUDIBLE NOISE MAY BE MORE NOTICEABLE THROUGH THE WHEEL WELL, UNDER THE VEHICLE AND WITH AN OPEN HOOD, REFER TO WORKSHOP MANUAL (WSM) SECTION 303-00. UNDER CERTAIN OPERATING CONDITIONS SUCH AS COLD ENGINE STARTS AND ENGINE STARTUP AFTER PROLONGED PERIODS, AUDIBLE NOISE MAY BE MORE NOTICEABLE DURING ENGINE WARM UP PERIOD. THOROUGH TESTING HAS FOUND NO DURABILITY OR PERFORMANCE LOSS FROM THIS CONDITION just thought you would want to know. Link to comment Share on other sites More sharing options...
ChrisSD Posted October 1, 2009 Author Report Share Posted October 1, 2009 Blah. I wonder if they'll name the TSB after me? Well, it's annoying, but I guess I am now less annoyed knowing there is "nothing wrong" functionally and reliability wise. I'll definitely have to thank all those involved. Ford needs to recheck what they think are acceptable tolerances. It's not fun having people ask me why my "lifters are ticking" every time I start my car. Link to comment Share on other sites More sharing options...
Spring Lil Cobra Posted October 1, 2009 Report Share Posted October 1, 2009 Blah. I wonder if they'll name the TSB after me? Well, it's annoying, but I guess I am now less annoyed knowing there is "nothing wrong" functionally and reliability wise. I'll definitely have to thank all those involved. Ford needs to recheck what they think are acceptable tolerances. It's not fun having people ask me why my "lifters are ticking" every time I start my car. Great work Chris. Thanks for driving this issue. It is good to know that nothing internally is wrong. Link to comment Share on other sites More sharing options...
AlloyDropTop Posted October 2, 2009 Report Share Posted October 2, 2009 Chris, Thanks for pursuing this! Now we can at least relax knowing we don't have a bad part, etc... Link to comment Share on other sites More sharing options...
ChrisSD Posted October 2, 2009 Author Report Share Posted October 2, 2009 I spoke with the FSE when I picked up my car. Was a very nice guy and smart as could be. Knew everything about these cars and explained everything to me. In my case Ford went above and beyond. Obviously I don't like the tick but I am not freaked out about it anymore. Ford and the dealer addressed my other concerns and fixed them. I will make a new post detailing my issues and the resolutions, maybe it will help others out. Obviously if you have a tick you should always get it checked out, your issue may be different than mine. Ford has thoroughly documented mine though so at least it is in the system now and other dealer techs can draw from the experience. Link to comment Share on other sites More sharing options...
Grabber Posted October 2, 2009 Report Share Posted October 2, 2009 Ford just posted this in response to the noise concerns,2755 - 2007-2010 MUSTANG SHELBY GT500 NORMAL ENGINE NOISE SOME 2007-2010 MUSTANG GT500 VEHICLES EQUIPPED WITH A 5.4L ENGINE MAY EXHIBIT CLATTER/TICK/TAP CHARACTERISTIC ENGINE NOISE. THE NOISE MAY BE CAUSED BY TOLERANCE STACK UP, NOT A SINGLE COMPONENT. DUE TO MANUFACTURING VARIANCES, ALL OF THESE ENGINES WILL EXHIBIT SOME LEVEL OF NOISE. AUDIBLE NOISE MAY BE MORE NOTICEABLE THROUGH THE WHEEL WELL, UNDER THE VEHICLE AND WITH AN OPEN HOOD, REFER TO WORKSHOP MANUAL (WSM) SECTION 303-00. UNDER CERTAIN OPERATING CONDITIONS SUCH AS COLD ENGINE STARTS AND ENGINE STARTUP AFTER PROLONGED PERIODS, AUDIBLE NOISE MAY BE MORE NOTICEABLE DURING ENGINE WARM UP PERIOD. THOROUGH TESTING HAS FOUND NO DURABILITY OR PERFORMANCE LOSS FROM THIS CONDITION just thought you would want to know. Another Broadcast message. No TSB on this one because there is no fix. Link to comment Share on other sites More sharing options...
