ShowCar Posted August 26, 2009 Report Share Posted August 26, 2009 Ive been researching pillar pods, the shelby dash pod with three gauges, CDC gauge pod and found this simple little thing on Roush's website. The new 2010 427R has the same setup so I contacted roush and found it. For $29.00 per gauge you have a clean install with no interior butchering, wires exposed thru the winshield defroster vents, or hitting the A-pillar pod everytime you grab the steering wheel. The vent still works like it should except it cant be closed or directed. The best part is the drivers side dash is very easily accessible thru the side to run the wires, hose, and pull out the light switch. The total install took one hour. Minus a run to the auto store for a universal vacuum T-fitting. Plus if you like to have multiple gauges the center ones work the same way. It is just tighter inside the dash area to run wires and stuff. It fits 2 1/16th gauges, either mechanical or electric. I may change the gauge for a different one in the future. Im not so sure about the white face. I would like a carbon fiber shelby gauge but I cant find one that is 2/16 yet. Link to comment Share on other sites More sharing options...
Redlinetoys Posted August 26, 2009 Report Share Posted August 26, 2009 Interesting mount! It would be great to see a picture from further back, showing the overall new appearance. Link to comment Share on other sites More sharing options...
ShowCar Posted August 26, 2009 Author Report Share Posted August 26, 2009 Heres more pictures This is the access panel. Link to comment Share on other sites More sharing options...
WildAzCat Posted August 26, 2009 Report Share Posted August 26, 2009 That looks very cool.. But seriously, I like it. Link to comment Share on other sites More sharing options...
ShowCar Posted August 26, 2009 Author Report Share Posted August 26, 2009 That looks very cool.. But seriously, I like it. Good One. Link to comment Share on other sites More sharing options...
RACERX009 Posted August 26, 2009 Report Share Posted August 26, 2009 Ive been researching pillar pods, the shelby dash pod with three gauges, CDC gauge pod and found this simple little thing on Roush's website. The new 2010 427R has the same setup so I contacted roush and found it. For $29.00 per gauge you have a clean install with no interior butchering, wires exposed thru the winshield defroster vents, or hitting the A-pillar pod everytime you grab the steering wheel. The vent still works like it should except it cant be closed or directed. The best part is the drivers side dash is very easily accessible thru the side to run the wires, hose, and pull out the light switch. The total install took one hour. Minus a run to the auto store for a universal vacuum T-fitting. Plus if you like to have multiple gauges the center ones work the same way. It is just tighter inside the dash area to run wires and stuff. It fits 2 1/16th gauges, either mechanical or electric. I may change the gauge for a different one in the future. Im not so sure about the white face. I would like a carbon fiber shelby gauge but I cant find one that is 2/16 yet. nice!!!!!! Link to comment Share on other sites More sharing options...
AstroDan Posted August 26, 2009 Report Share Posted August 26, 2009 That really does fit nicely there. Only thing, don't you miss that vent on hot days? Link to comment Share on other sites More sharing options...
ARMORINE Posted August 26, 2009 Report Share Posted August 26, 2009 That really does fit nicely there.Only thing, don't you miss that vent on hot days? it still works it flows around the mount. i have seen those before Link to comment Share on other sites More sharing options...
ingram4868 Posted August 26, 2009 Report Share Posted August 26, 2009 The guy that designed that trick little kit was (and might still be) a member here. He sold them to other members until he sold the rights to Roush a few years back. The air still flows around the gauge to the driver. Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted August 26, 2009 Report Share Posted August 26, 2009 Be cool to have two gauges on either side of the CSM plate. That would look cool! Link to comment Share on other sites More sharing options...
AstroDan Posted August 26, 2009 Report Share Posted August 26, 2009 The guy that designed that trick little kit was (and might still be) a member here. He sold them to other members until he sold the rights to Roush a few years back. The air still flows around the gauge to the driver. That is cool. Too bad I already have the gauges... Link to comment Share on other sites More sharing options...
