07SGT5036 Posted August 23, 2009 Report Share Posted August 23, 2009 Has anyone put an Eleanor Style center fog lights on the Shelby. I used all of the stock parts and wires at the grill. they all plug in just fine but no fog lights... Did the Shelby guys do somthing when they took out the old one and put in the new grill? I want to use the stock control that came with the GT, it will turn on the parking and head lights.. pul it out and fog lights will come on.. that is what the book has in it.... HELP.................. Gary 07SGT5036 Link to comment Share on other sites More sharing options...
tekheavy Posted August 23, 2009 Report Share Posted August 23, 2009 Has anyone put an Eleanor Style center fog lights on the Shelby. I used all of the stock parts and wires at the grill. they all plug in just fine but no fog lights... Did the Shelby guys do somthing when they took out the old one and put in the new grill? I want to use the stock control that came with the GT, it will turn on the parking and head lights.. pul it out and fog lights will come on.. that is what the book has in it.... HELP.................. Gary 07SGT5036 My grille lights worked fine with the stock plug under the hood and stock switch. I have heard others say that some had to replace the fuse that was removed during the Shelby mod. Link to comment Share on other sites More sharing options...
07SGT4578 Posted August 23, 2009 Report Share Posted August 23, 2009 replace the fuse that was removed during the Shelby mod. Link to comment Share on other sites More sharing options...
SGT/SC2873 Posted August 23, 2009 Report Share Posted August 23, 2009 My grille lights worked fine with the stock plug under the hood and stock switch. I have heard others say that some had to replace the fuse that was removed during the Shelby mod. +1 When I wired mine the 15amp fuse was not in place. Once I put it in everything worked fine. Craig Link to comment Share on other sites More sharing options...
WildAzCat Posted August 23, 2009 Report Share Posted August 23, 2009 +1 When I wired mine the 15amp fuse was not in place. Once I put it in everything worked fine. Craig Same here. Also the lights only go on when the car is on. They"re dead if you try turning them on otherwise. Link to comment Share on other sites More sharing options...
SHELBYBRO Posted August 23, 2009 Report Share Posted August 23, 2009 Same here. I haven't put any fog lights on mine but when I checked to see what it would need , I found that there was no fuse installed. I am glad that all the wiring and switch is there. Should make for an easy install. Link to comment Share on other sites More sharing options...
Glenn Greenwell Posted August 23, 2009 Report Share Posted August 23, 2009 Check one of the PIAA fog light installs posted on this forum or TMS, as I recall someone posted a picture of the Shelby Fuse box and the 15 amp fuse was removed by Shelby. There was a really good pic of the fuse box posted as they went through the install process. I have some interest in doing the GT-H type fog lights as a future modification and am glad to know the switch does work and the wiring is intact. Just my thoughs, cheers GG Link to comment Share on other sites More sharing options...
shelbymotorsports Posted August 23, 2009 Report Share Posted August 23, 2009 Check for the missing fuse and remember that the fogs only work on low beam. Steve Link to comment Share on other sites More sharing options...
Budman340 Posted August 24, 2009 Report Share Posted August 24, 2009 Yes, we did remove the 15amp fuse from the spot and put in the spot for the spares. This was done incase any water contacted any open plug ends so it would not short out. When I get back in Monday morning, I will post some pics of the fuse before and after the lights are hooked up. Bud Link to comment Share on other sites More sharing options...
RACERX009 Posted August 24, 2009 Report Share Posted August 24, 2009 Has anyone put an Eleanor Style center fog lights on the Shelby. I used all of the stock parts and wires at the grill. they all plug in just fine but no fog lights... Did the Shelby guys do somthing when they took out the old one and put in the new grill? I want to use the stock control that came with the GT, it will turn on the parking and head lights.. pul it out and fog lights will come on.. that is what the book has in it.... HELP.................. Gary 07SGT5036 Under hood fuse box you have to install fuse for foglights!!! Link to comment Share on other sites More sharing options...
stormeaston Posted August 24, 2009 Report Share Posted August 24, 2009 Mine(15 amp) was just lying in the fuse box, I just plugged her in and it worked fine. Link to comment Share on other sites More sharing options...
wnenn Posted August 25, 2009 Report Share Posted August 25, 2009 I hooked up mine last evening and I think its fuse number 58,,,,,,15 amp and it was plugged into the spare fuse slots. I just moved it to where it was supposedd to be. Wnenn Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted August 25, 2009 Report Share Posted August 25, 2009 Has anyone put an Eleanor Style center fog lights on the Shelby. I used all of the stock parts and wires at the grill. they all plug in just fine but no fog lights... Did the Shelby guys do somthing when they took out the old one and put in the new grill? I want to use the stock control that came with the GT, it will turn on the parking and head lights.. pul it out and fog lights will come on.. that is what the book has in it.... HELP.................. Gary 07SGT5036 HEY GARY, I HAVE REPLACED MY GRILL AND USED THE ELEANOR STYLE CENTER FOG LAMPS AND I HAD TO GET A FUSE FOR THEM TO WORK. YOU CAN FIND THE LOCATION OF THE FUSE FOR THE STOCK FOGS AND IT'S AMPS IN YOUR OWNERS MANUAL. HERE IS A COUPLE PIC'S OF WHAT MY FOGS LOOK LIKE. SCOTTY Link to comment Share on other sites More sharing options...
jplanders Posted August 26, 2009 Report Share Posted August 26, 2009 HEY GARY, I HAVE REPLACED MY GRILL AND USED THE ELEANOR STYLE CENTER FOG LAMPS AND I HAD TO GET A FUSE FOR THEM TO WORK. YOU CAN FIND THE LOCATION OF THE FUSE FOR THE STOCK FOGS AND IT'S AMPS IN YOUR OWNERS MANUAL. HERE IS A COUPLE PIC'S OF WHAT MY FOGS LOOK LIKE. SCOTTY Scotty, I love the look of your fogs. Did you consider retaining the billet grill? jpl Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted August 27, 2009 Report Share Posted August 27, 2009 Scotty, I love the look of your fogs. Did you consider retaining the billet grill? jpl THANKS JP I LOVE THE LOOK OF THE CENTER FOGS TOO , AND I WILL KEEP THE STOCK GRILL FOR WHEN I SAVE UP FOR THE LOWER SHELBY GRILL AND THE PIA FOGS. SCOTTY Link to comment Share on other sites More sharing options...
wnenn Posted September 1, 2009 Report Share Posted September 1, 2009 Here's my "hidden" driving lights. I used 06 Freestyle assemblies. I had to change the plugs (they are available at Ford parts for wreck rebuilds). Mounted on some stainless bolts with nylon spacers. Wnenn Link to comment Share on other sites More sharing options...
