Willie Posted August 21, 2009 Report Share Posted August 21, 2009 I can't believe I sheared a bolt head off a lower intake manifold bolt with my torque wrench set at 20 ft-lbs! If anyone has a shop manual or knows of a site that has torque specs, I'd certainly appreciate what value these bolts should be torqued down to. It's the perimeter bolts (10mm head) for the lower intake / housing for the intercooler. Thanks all. Link to comment Share on other sites More sharing options...
SSGT500 Posted August 22, 2009 Report Share Posted August 22, 2009 I can't believe I sheared a bolt head off a lower intake manifold bolt with my torque wrench set at 20 ft-lbs! If anyone has a shop manual or knows of a site that has torque specs, I'd certainly appreciate what value these bolts should be torqued down to. It's the perimeter bolts (10mm head) for the lower intake / housing for the intercooler. Thanks all. http://iihs.net/fsm/?dir=41 Link to comment Share on other sites More sharing options...
Willie Posted August 22, 2009 Author Report Share Posted August 22, 2009 Perfect. Thank you! Willie Link to comment Share on other sites More sharing options...
