Slabo Posted August 5, 2009 Report Share Posted August 5, 2009 Just wondering how SAI is wiring up the heat exchanger fans in the cooling package? Do they just attach to the cooling pump? Do they use the crimp on method? Link to comment Share on other sites More sharing options...
Slabo Posted August 6, 2009 Author Report Share Posted August 6, 2009 Here is the reply from the mod shop at SAI. They didn't mention if they clamp-on the pump wire or solder it on. "The fan setup has its own relays and fuses that come with the kit. We at Shelby do use the intercooler pump positive wire to trigger the relays for the fans." Link to comment Share on other sites More sharing options...
Revan Racing Posted August 7, 2009 Report Share Posted August 7, 2009 Here is the reply from the mod shop at SAI. They didn't mention if they clamp-on the pump wire or solder it on. "The fan setup has its own relays and fuses that come with the kit. We at Shelby do use the intercooler pump positive wire to trigger the relays for the fans." FYI. There are a number of different ways to trigger the fans. You can use a Litle Add-A-Fuse, you can solder the trigger wires to the fan pump positive (white with red stripe) at the relay power location. There are number of different ways to do it. For the record there are crimp connectors provided in the kit that are utilized to 'tap' the voltage for each fans 'trigger'. Link to comment Share on other sites More sharing options...
MY500SS Posted August 7, 2009 Report Share Posted August 7, 2009 FYI. There are a number of different ways to trigger the fans. You can use a Litle Add-A-Fuse, you can solder the trigger wires to the fan pump positive (white with red stripe) at the relay power location. There are number of different ways to do it. For the record there are crimp connectors provided in the kit that are utilized to 'tap' the voltage for each fans 'trigger'. And they work great. Link to comment Share on other sites More sharing options...
Slabo Posted August 7, 2009 Author Report Share Posted August 7, 2009 FYI. There are a number of different ways to trigger the fans. You can use a Litle Add-A-Fuse, you can solder the trigger wires to the fan pump positive (white with red stripe) at the relay power location. There are number of different ways to do it. For the record there are crimp connectors provided in the kit that are utilized to 'tap' the voltage for each fans 'trigger'. And they work great. It sounds like the SAI mod shop is using the included wiring components from the kit so I would assume the are using the crimp connectors as well. Link to comment Share on other sites More sharing options...
Revan Racing Posted August 8, 2009 Report Share Posted August 8, 2009 It sounds like the SAI mod shop is using the included wiring components from the kit so I would assume the are using the crimp connectors as well. Yes, they use the provided crimp connectors. Link to comment Share on other sites More sharing options...
