gbstang Posted August 5, 2009 Report Share Posted August 5, 2009 For you guys that do not want to drill holes in your Bumper here is a great alternative! http://www.ccmustangbrackets.com/ I have had this on mine for quite a while and could not be more happier! also if you want to see it installed take a look at my gallery.. The cooolest thing is if you attend a show and want to ditch the plate fast it comes of lickety split! GNB Quote Link to comment Share on other sites More sharing options...
clark17357 Posted August 5, 2009 Report Share Posted August 5, 2009 For the SGT, this is the best set up. For those of us with the lower grill, the install is (so far for me) not possible without pulling off the front end. When I have my car back to the SAI Mod Shop for the cooling package, I hope to persuade Bud to have it installed while they have the front end off. Jim Quote Link to comment Share on other sites More sharing options...
motorjock205 Posted August 5, 2009 Report Share Posted August 5, 2009 It's a good idea, but like Jim, I too have the lower grille installed and I don't like how it still covers part of the lower grille intake...Why can't someone design one that sits a little higher where the bumper actually is so it doesn't block the lower intake area? Quote Link to comment Share on other sites More sharing options...
Dig-It Posted August 5, 2009 Report Share Posted August 5, 2009 Jim, Check out my solution for my Craig Bracket and lower grill here. Quote Link to comment Share on other sites More sharing options...
strong_j Posted August 5, 2009 Report Share Posted August 5, 2009 dig-it that LC plate looks really close to the ground ... do you scrape alot?? Quote Link to comment Share on other sites More sharing options...
clark17357 Posted August 5, 2009 Report Share Posted August 5, 2009 Jim,Check out my solution for my Craig Bracket and lower grill here. Kevin, You are a genius. What a straightforward solution to a problem that has vexed me for a good length of time. Jim Quote Link to comment Share on other sites More sharing options...
Dig-It Posted August 5, 2009 Report Share Posted August 5, 2009 dig-it that LC plate looks really close to the ground ... do you scrape alot?? Once - the first time I took it for a drive with it on, not since though (knocks on wood). Kevin, You are a genius. What a straightforward solution to a problem that has vexed me for a good length of time. Jim Quote Link to comment Share on other sites More sharing options...
clark17357 Posted August 6, 2009 Report Share Posted August 6, 2009 Kevin, I did the work tonight after getting home. In California it is just a fix it ticket so I will run without a plate and then mount the bracket in 5 minutes and have the ticket signed off and go back to my lawless ways. Great fix. Jim Quote Link to comment Share on other sites More sharing options...
gbstang Posted August 6, 2009 Author Report Share Posted August 6, 2009 It's a good idea, but like Jim, I too have the lower grille installed and I don't like how it still covers part of the lower grille intake...Why can't someone design one that sits a little higher where the bumper actually is so it doesn't block the lower intake area? It doesn't really cover the lower grill, I have a S/C and I have not had an issue with the lower grill area.. Also, the license plate covers about 75-85% of the bumper.. GNB Quote Link to comment Share on other sites More sharing options...
ilmor Posted August 6, 2009 Report Share Posted August 6, 2009 For you guys that do not want to drill holes in your Bumper here is a great alternative! http://www.ccmustangbrackets.com/ I have had this on mine for quite a while and could not be more happier! also if you want to see it installed take a look at my gallery.. The cooolest thing is if you attend a show and want to ditch the plate fast it comes of lickety split! GNB That's the one I have also - love it. Quote Link to comment Share on other sites More sharing options...
Dig-It Posted August 6, 2009 Report Share Posted August 6, 2009 Kevin, I did the work tonight after getting home. In California it is just a fix it ticket so I will run without a plate and then mount the bracket in 5 minutes and have the ticket signed off and go back to my lawless ways. Great fix. Jim I'm keeping mine in the trunk as well. I plan on using the "Oh shoot officer, I forgot to put my front plate back on after I washed my car", excuse. Glad I could help. Quote Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted August 7, 2009 Report Share Posted August 7, 2009 I'm keeping mine in the trunk as well. I plan on using the "Oh shoot officer, I forgot to put my front plate back on after I washed my car", excuse. Glad I could help. +1 That's what I do and the two times I've been stopped in over two years I've been let go. Quote Link to comment Share on other sites More sharing options...
jp1gt Posted August 7, 2009 Report Share Posted August 7, 2009 My wife did get a ticket in ca. Craig's frame is easy to put on with the lower grill, you just have to take the plastic panel off the bottom. Quote Link to comment Share on other sites More sharing options...
Dig-It Posted August 7, 2009 Report Share Posted August 7, 2009 It depends on which lower grill you get. Craig's bracket was not going to get through Quantum Performance's lower grill. Quote Link to comment Share on other sites More sharing options...
jp1gt Posted August 8, 2009 Report Share Posted August 8, 2009 It depends on which lower grill you get. Craig's bracket was not going to get through Quantum Performance's lower grill. Good for people to know. I think I got mine from Shelby. Quote Link to comment Share on other sites More sharing options...
