09KR0058 Posted July 31, 2009 Report Share Posted July 31, 2009 Every time I clean my KR, its such a pain in the butt to clean the brake dust & dirt out of the recessed lettering on the aluminum wheels. I'm scared to use any kind of brush, for fear of eventually getting scratches on the wheels. How do you other KR owners do it? Link to comment Share on other sites More sharing options...
clark17357 Posted July 31, 2009 Report Share Posted July 31, 2009 No KR in my garage but I would suggest using a pressure washer from a respectful distance and that will do the trick. A pressure washer, used from a distance, produces a gentle spray of water and only becomes forceful when you get close. Should work like a charm. Jim Link to comment Share on other sites More sharing options...
09KR0058 Posted July 31, 2009 Author Report Share Posted July 31, 2009 No KR in my garage but I would suggest using a pressure washer from a respectful distance and that will do the trick. A pressure washer, used from a distance, produces a gentle spray of water and only becomes forceful when you get close. Should work like a charm. Jim Yeah, I thought about that, but was hoping for another idea. Its a pain to haul out my pressure washer, hook it up and use it for just a couple of minutes. Link to comment Share on other sites More sharing options...
Stalwart Posted July 31, 2009 Report Share Posted July 31, 2009 Mine clean very well with a microfiber wash mit . . . you can also use a SOFT bristle brush. Link to comment Share on other sites More sharing options...
GT500-2007 Posted July 31, 2009 Report Share Posted July 31, 2009 Soft childs toothbrush works like a charm on the Alcoas on my SS.... GT Link to comment Share on other sites More sharing options...
09KR0058 Posted August 3, 2009 Author Report Share Posted August 3, 2009 Soft childs toothbrush works like a charm on the Alcoas on my SS.... GT That worked perfectly. Thanks Link to comment Share on other sites More sharing options...
Imatk Posted August 4, 2009 Report Share Posted August 4, 2009 That worked perfectly. Thanks I'd be careful with a toothbrush, I use Q-Tips on my SS wheels, squirt a little detail spray in there or just some simple soap and water with the Q Tip works lieka a charm. Link to comment Share on other sites More sharing options...
