Ken Smith Posted July 4, 2009 Report Share Posted July 4, 2009 Hi Guys This will be my first time on the drag strip. I have a 2008 GT500 that is totally stock from the factory. I currently get a lot of rear axle tramp when I take off quite quickly out on the street. Would installing a set of Steeda Billett Lower Control Arms fix this? What advise can anyone give me to enable successful launches with out to much wheel spin. Should I have the traction control on or off? I would appreciate any other advise. Many thanks. Quote Link to comment Share on other sites More sharing options...
sharabi Posted July 4, 2009 Report Share Posted July 4, 2009 Hi Guys This will be my first time on the drag strip. I have a 2008 GT500 that is totally stock from the factory. I currently get a lot of rear axle tramp when I take off quite quickly out on the street. Would installing a set of Steeda Billett Lower Control Arms fix this? What advise can anyone give me to enable successful launches with out to much wheel spin. Should I have the traction control on or off? I would appreciate any other advise. Many thanks. Since you do it stock, best advice is to get it easy out of the hole for second then go hard on the gas, otherwise it will hop like a bunny, the time you will lose in wheel hopping if you rev high and drop the clutch is more than the slightly rolling time before pushing the pedal to the metal. the best alternative is to get the LCA which will significantly diminish the wheel hop. if you want to do it right then include the UCA. Quote Link to comment Share on other sites More sharing options...
rsfdiver Posted July 6, 2009 Report Share Posted July 6, 2009 Since you do it stock, best advice is to get it easy out of the hole for second then go hard on the gas, otherwise it will hop like a bunny, the time you will lose in wheel hopping if you rev high and drop the clutch is more than the slightly rolling time before pushing the pedal to the metal. the best alternative is to get the LCA which will significantly diminish the wheel hop. if you want to do it right then include the UCA. another suggestion: when you get to second gear don't just stomp on it if is your first run or you may end up in the wall. get a feel for the track and the car before you go all out. Try it with the traction control on first then go without it as you get the feel of it. I also just replaced the upper control arm bushings only, and have no wheel hop with 550hp/tq at the wheels. Quote Link to comment Share on other sites More sharing options...
sharabi Posted July 6, 2009 Report Share Posted July 6, 2009 another suggestion: when you get to second gear don't just stomp on it if is your first run or you may end up in the wall. get a feel for the track and the car before you go all out. Try it with the traction control on first then go without it as you get the feel of it.I also just replaced the upper control arm bushings only, and have no wheel hop with 550hp/tq at the wheels. every time i look at your sig i cannot stop admiring the trees, man that is from heaven. no LCAs? did you lower the car with ford racing? i got the wheel hop again on a crappy road with LCA only. advice well taken since the track can be slick. Quote Link to comment Share on other sites More sharing options...
rsfdiver Posted July 6, 2009 Report Share Posted July 6, 2009 (edited) First time at the track ever, I spin out in first, grabbed second, hooked up and thought Lets Go, hit the power band and headed for the wall. Thank goodness for good brakes and the fact I was in the left lane aiming for the right wall. I did the upper control arm bushings and have good results with 550rwhp & tq with stock tires and MT 305/35/18's. the car is not lowered for I like the stock height. About my yard in the picture my wife informed me that my new huskervarna lawn tractor was just put out by the local fire department... Edited July 6, 2009 by rsfdiver Quote Link to comment Share on other sites More sharing options...
