kahmann Posted July 4, 2009 Report Share Posted July 4, 2009 Now that I need to uninstall my relatively new Steeda underdrive pulleys, to make way for the Paxton install, I'm trying to find info on aftermarket, OEM size dampers. The only one I've found is this ATI damper from Summit, but under 'application' it says 2005 Mustang only. Any info on whether this works for all S197's (not sure why it wouldn't)? Or does anyone know of any other reputable brand and/or where to find them? Ken http://www.summitracing.com/parts/ATI-918039/?image=large Quote Link to comment Share on other sites More sharing options...
GT500-07 Posted July 4, 2009 Report Share Posted July 4, 2009 give Jared a call http://www.lethalperformance.com/05-09-mus...-c-576_812_3009 Quote Link to comment Share on other sites More sharing options...
RogerS Posted July 4, 2009 Report Share Posted July 4, 2009 You can by direct from innovators west. Roger Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted July 4, 2009 Report Share Posted July 4, 2009 give Jared a call http://www.lethalperformance.com/05-09-mus...-c-576_812_3009 Ken +1 .....same as thing as they said Innovators West is the bomb ! I got mine from Lethal, even though you can buy direct, I like to support Jared. Take Care Andrew Quote Link to comment Share on other sites More sharing options...
kahmann Posted July 4, 2009 Author Report Share Posted July 4, 2009 Ken +1 .....same as thing as they said Innovators West is the bomb ! I got mine from Lethal, even though you can buy direct, I like to support Jared. Take Care Andrew Looks great! I'll definitely look into this on Monday. Did you go with an OEM size or an OD pulley? Ken Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted July 4, 2009 Report Share Posted July 4, 2009 Looks great! I'll definitely look into this on Monday. Did you go with an OEM size or an OD pulley? Ken Went with OEM size (not sure why I did) It is a thing of beauty...especially compared to the rusty stock one. Take care, Andrew Quote Link to comment Share on other sites More sharing options...
kahmann Posted July 4, 2009 Author Report Share Posted July 4, 2009 (edited) Went with OEM size (not sure why I did) It is a thing of beauty...especially compared to the rusty stock one. Take care, Andrew I'm thinking of doing the same, but I just wanted to double check. 6 rib or 8 rib?? It ought to match my Steeda billet idler pulleys very nicely! :happy feet: Ken Edited July 4, 2009 by kahmann Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted July 5, 2009 Report Share Posted July 5, 2009 I'm thinking of doing the same, but I just wanted to double check. 6 rib or 8 rib??It ought to match my Steeda billet idler pulleys very nicely! :happy feet: Ken I got the 6 rib but if I were to do it again I would have gotten the 8 rib to keep my options open . Andrew Quote Link to comment Share on other sites More sharing options...
kahmann Posted July 5, 2009 Author Report Share Posted July 5, 2009 I got the 6 rib but if I were to do it again I would have gotten the 8 rib to keep my options open . Andrew Yeah that's probably a good call. Although it's already a really tight job as it is. Those extra ribs aren't gonna make it any easier! Ken Quote Link to comment Share on other sites More sharing options...
kahmann Posted July 6, 2009 Author Report Share Posted July 6, 2009 I sent Jared an email about the OEM vs. 10% OD pulley. Sounds like a great option for guys needing some more power. But I think I'll stick to the standard size this go around. Here's what he had to say. "All of Innovators West's products are top notch. The only difference between the standard size balancer and the 10% one is that the 10% will increase your blower rpm's which in turn will make more boost. I'm not sure how much boost you're making right now but you'll probably see a 2-3psi increase with the 10% balancer. I highly suggest getting your tuner to make the necessary changes to your tune to to compensate for the additional/boost and power. You should see anywhere from a 20-35hp gain with the additional boost. Please let us know if you have any other questions. Thanks, Jared" Quote Link to comment Share on other sites More sharing options...
uno Posted July 7, 2009 Report Share Posted July 7, 2009 did you have the UD pulleys before and uninstalling them because they are going to underdrive your supercharger? Quote Link to comment Share on other sites More sharing options...
kahmann Posted July 7, 2009 Author Report Share Posted July 7, 2009 did you have the UD pulleys before and uninstalling them because they are going to underdrive your supercharger? Yeah that's the only reason I'm pulling the UD's. Ken Quote Link to comment Share on other sites More sharing options...
