jared@lethal Posted July 1, 2009 Report Share Posted July 1, 2009 We're proud to announce that the Fore Precision Works IRS Billet Differential Cover is now shipping here at Lethal Performance. It's been a long wait but it's finally here and it was done right which is most important. Quantities are limited on the first batch so if you haven't pre-ordered one and are looking to purchase one please feel free to order online or by giving us a call. http://www.lethalperformance.com/03-04-svt...l-cover-p-28522 Here's some information on the Fore Precision Works IRS Differential Cover. Engineered, high rigidity design for maximum strength Billet 6061-T6 material is highly resistant to failure Axle bearing cap pre-load bolts for maximum differential strength and reliability Bottom accessible drain plug for simple draining Higher fluid volume for increased heat capacity O-ring seal will not leak and does not require silicone for easy and clean installation and removal. Integrated cooling fins for maximum heat dissipation Additional feed and return ports for differential cooler http://www.lethalperformance.com/03-04-svt...l-cover-p-28522 Link to comment Share on other sites More sharing options...
