Best oil for Shelby GT?
Hi,
soon my 07SGT will need its first oil change and i was wondering whats the best oil to use? Is anything better than motorcraft? hows castrol? royal purple? or mobil 1? someone told me redline is best, is that true? let me know what you run on your SGT.
THX :baby:
Hi,
THX :baby:
I use Motorcraft 5W-20 Premium Sythetic Blend. They sell it at Walmart.
This is your first oil change on an 07?? How many miles do you have on it??
I use Motorcraft 5W-20 Premium Sythetic Blend. They sell it at Walmart. This is your first oil change on an 07?? How many miles do you have on it??
only 28xx miles on it. actually, i could't find motorcraft oil at Walmart here. only mobil1 and castrol. anyway, thx your info.
btw, your car is awesome.
Thank you and welcome to Team Shelby. Post up some pics of your car when you get a chance.
I use Motorcraft 5W-20 Premium Sythetic Blend, also.
No problems with it.
2nd oil change for my SGT, I change oil and filter every 5000 miles.
My Bronco II has 285,000 miles on the 2.9L and the engine
has never needed to be opened up. I changed that oil every
5000 miles also with Valvoline regular 10w-40 conventional high
detergent and it still runs, the body is crap but it runs. :)
Phil
Williamsport, Pa.
I use the same, highly rated and price is right not to mention it is what Ford tells you to use..........
My opinion, based on received wisdom and interpretations of the various studies: any oil that meets Mr Ford's requirements per the owner's manual will be fine and good.
I believe it is worthwhile to change to a (any major brand) full synthetic. The Purple and Ams products probably won't hurt anything but your pocketbook.
Any improvements in lubricity or "cling" offered at premium prices may be real, but not significant in actual use. Think about your polished intake passages. Increments in flow rate might be measurable, but are proportionally within production-tolerance bandwidth, in actual effect. It's good for your mind to know they are there, though. Same with expensive oil.
I'm a former Castrol apostle, now specifying the dealer's best full synthetic.
After my warranty expires, I'm going with Mobil 1. Which oil is better is a debate with no ending.
Mobile 1 is good stuff, I think they're all good to tell the truth, but I use Royal Purple for years just because it looks kool, and they always sponser the Hot Rod Power Tour so WTH.
The corvette and viper recommend mobil 1 and they are certainly high-performance engines. I use mobil 1 but just about any synthetic will do. Mobil 1 and royal purple are probably the most popular. Whatever you use in your daily driver should be sufficient but be sure to go with the manufactures weight. I change oil once a year but i only drive 2500 to 3000 miles per year.I change mine because of the age more than the mileage.
:shift: Just finished first oil change at 1500 miles using Mobil1 5/20 Synthetic with Ford Racing Oil Filter.
Wanted to complete first oil change at 1500 miles will probably change every additional 2500 from here on.
I use Mobil 1, best synthetic out there.. I use the Pensoil for everything else.. I worked in the petro chemical industry for a while, my ex was a chemist for Pensoil R&D, knowing the testing, oil packages etc. clues you into my choice.
2-cents,,,all I got!
I have 1396 miles on my '08, but have had it for 13 months now and planning to get my first oil change soon. Planning to use Mobil 1 and the Ford Racing Filter (which is what came on it stock from Shelby).
For those of you who use the Ford racing filter, were you able to get it through your dealer, did you order it through SPP or somewhere else? The model in the SPP catalog is $15.
Thanks,
Matt
I had my first oil change on my 2007 Shelby GT at 1864 miles. I didn't like the fact that the factory oil had been in her for so long (time not miles).
I used 5w20 Motorcraft with a Ford Racing filter. I have been using Mobile1 in my other cars but went with the owners manual with this one.
Thanks,
Matt
I ordered two from SPP, but my local ford dealer said he can get them but it take a couple of days. A couple of days seam OK to me, will try when i use my second filter.
Loy
Thanks,
Matt
Matt
I get my FRRP filter through Blue Oval Industries and usually get a couple at a time to reduce the shipping
Take Care
Andrew
I used to go through Blue oval industries for parts, too many times I have placed an order from those guys and never get a email saying something is on back order etc. Since I am in Korea, it could take up to 6-8 weeks to receive stuff. My last order I placed with them I sent an email after 6 weeks of waiting, to get tracking info etc and that is when they said they did not ship my parts due to back order (I had to call them!). I would think those guys would have the courtesy to at least inform the customer during the order process that the item is not instock, alot of reputable sites do, these guys just take your money for the parts and then they don't even send a courtesy email. I will not do business with them as they do not answer emails etc, the only communication is if you call them..
Bad business..
I will go with Ford or other better businesses, like JBA, Ford etc.
I'd be careful using a racing filter. Wix makes as good a racing filter as anyone, but they will tell you it's a low-restriction design for racing. Their regular filter does a better job of filtering.
As for oil, I use generic synthetic once I determine who makes it. Right now I'm using Parts Plus full synthetic, which is made by Valvoline. The Valvoline people assure me it's the exact same product, without the advertising expenses. It costs only a little more than name-brand conventional oil. Most other store-brand synthetics are likely made by Valvoline. I use 10W30 for the added cushion, and change it at 5000.
But the oil brand debate has been going on since I was a small boy.
If you are really interested, here's where the info is: http://www.bobistheoilguy.com/
Matt
Take Care
Andrew
Thanks for the link Andrew... appreciate you pointing me right to product page for the correct filter. Just ordered two.
Thanks,
Matt
