kharper Posted June 26, 2009 Report Share Posted June 26, 2009 Hi, I am looking to get a set of Drag Radial and an extra set of rims to mount them on permanently. So on a day I want to go to the track I will just bolt on the the DR's and go. I do not want to install TPMS on the 'track rims' unless the car requires them. Will the car go into any kind of fail safe mode with out the sensors? Or will the car work perfectly fine, but simply give a tire pressure warning on the dash? I can live with a light on at the track, as I may change the tire pressure in the tires anyway. But if the car goes into a fail safe, I will have to get sensors. Thanks Quote Link to comment Share on other sites More sharing options...
Innovator Posted June 26, 2009 Report Share Posted June 26, 2009 Just a light no problems. Quote Link to comment Share on other sites More sharing options...
mrfarmdog Posted June 26, 2009 Report Share Posted June 26, 2009 Just reset the error in your car if it comes on. It will go away when you reinstall the other tires. Sometimes mine doesn't even come on when I change tires. Quote Link to comment Share on other sites More sharing options...
kharper Posted June 26, 2009 Author Report Share Posted June 26, 2009 Thanks guys, This is just what I was hoping to hear Quote Link to comment Share on other sites More sharing options...
m81mclaren Posted June 26, 2009 Report Share Posted June 26, 2009 Just reset the error in your car if it comes on. It will go away when you reinstall the other tires. Sometimes mine doesn't even come on when I change tires. How do you reset the error? Is there a way to disable the TPM system? Quote Link to comment Share on other sites More sharing options...
Paleoc Posted June 27, 2009 Report Share Posted June 27, 2009 How do you reset the error? Is there a way to disable the TPM system? You push the reset button and the message goes away. The little flat tire image on dash stays but so what. The message comes back after 1/2 hr, push the button again and it doesn't come back until next time you start the car. Quote Link to comment Share on other sites More sharing options...
