Speed Bleeders
I've used them for years on both 4 wheel & 2 wheeled vehicles as well as on the motorcycle clutch hydrolics. They work great.
Jim
How are these different than the OEM ones? Do you do anything different while bleeding the brakes?
They have a check valve built into them, so you open 1/4 turn and nothing comes out, until you're actually pumping the brakes.
Once you stop pumping, the check valve closes. This prevents any air from entering the system. It allows you to bleed exactly as much fluid out as you want to. And it also makes doing this with one person infinitely easier.
Ken
It is speedbleeder.com and there number is 815-736-6296. The part # is sb 1010s m10x1.0. I bought the steel bleeders. You can buy stainless but if you are not showing your car with the wheels off then no one would notice. The biggest benefit to these is you take your wife out of the equation and any time you can do that ,it's a good thing.Great simple mod.Kenny
And that alone was the reason for this post!!!! So are these speed bleeders or wife eliminators? :hysterical:
I tried them on my race car a few years ago. they worked the first 6 or 7 bleedings, then the sealant on the threads wore out so they pulled air back in on the return stroke.
If you aren't bleeding your brakes 6 times on a weekend they would probably do fine. Otherwise plan to renew the sealant regularly. I never found a replacement sealant, but it may be available now.
I would like to see a design with a captured O-ring in the threads.
The site sells a bottle of sealent, which I bought as well. Their site says it only last for 6 or so turns...
Thread Sealant
Ah! I did not know that existed.
That means I would have to re-seal after every weekend.
Not sure it's worth that to me.
I've gotten so I just gravity-bleed anymore. Lots less work.
  • 2 years later...
2 years now since this thread was active - are all of you guys with the speed bleeders still happy with them?
I'm considering ordering a set, just want to be sure they hold up under the higher temps on the track. Or if they need replacement every couple years, that would be good to know going in.
I've been called a liar and every name in the book for saying this, but my bleeders failed and I'll never use them again. Apparently the check valve got stuck or something and it blew brake fluid all over my wheel well.
Well there you go. I was wondering if anyone had an issue like that. I'm sure it's not common, but certainly seems possible. My biggest concern was how the spring would hold up in the higher track temps that aren't seen on the street. Definitely a convenience item, but certainly, because of the construction, would be more prone to failure, so we obviously need to decide if the convenience is worth the risk.
I won't call you a liar or any other name in the book. Thanks for the feedback.
+1
Had them on my Brembos, now my Baer Extremes. Also on my factory rear calipers. Work perfect.
Jer
I haven't had a problem with mine... However, I have been to the track LESS in the past year or so...
Kurgan's problem is the first I have heard of them failing... But good info to know, just the same...
