andrewnagle1964 Posted June 15, 2009 Report Share Posted June 15, 2009 I took the SGT to Appalachian Performance in Black Mountain NC this afternoon and I am headed to New Orleans for a trade show..I'll be home in 8 days and am hoping the Shelby will be home too. Here is the list Swap Chromed Power Steering Pump with Stock One Meziere Electric Water Pump and new thermostat FRPP 62mm Dual Bore Throttle Body Weld axel tubes, Rust Treat and Paint Rear End with 4 step POR 15 J&M LCA Relocation Bracket FRPP 4.10 Gears & Rear Axle Girdle with Chrome Bolts & Lube Locker Gasket Moroso Modular Aluminum Oil Pan Steeda - Bumpsteer kit, X5 Ball Joints & Front Street End Link Kit American Racing 1 5/8” Long Tube Headers with H pipe with FRRP Header Bolts & Oxy Sensor Extensions FRPP KR500 Axle Back Mufflers Agent 47 front grille with fog lights Change brake fluid to ATE Super Blue and oil change (Mobil 1 5W20) FRPP Oil Filter New Tune and front end alignment Take Care and I will post lost of photos when it is done Andrew Link to comment Share on other sites More sharing options...
Guest hfrosso Posted June 16, 2009 Report Share Posted June 16, 2009 Link to comment Share on other sites More sharing options...
