kharper Posted June 3, 2009 Report Share Posted June 3, 2009 Hi, I have a 2008 built in Feb of 2008. I am lined up for the TSB but I am wondering if the input shaft will have to be replaced on mine since I have the new transmission version...I assume the replacement version is the same as the one already in my transmission. I would prefer they do not crack open the tranny if not needed. Or are the input shaft and syncros replaced even if they are not defective? Thanks, Kurtis Link to comment Share on other sites More sharing options...
03reptile Posted June 4, 2009 Report Share Posted June 4, 2009 Hi, I have a 2008 built in Feb of 2008. I am lined up for the TSB but I am wondering if the input shaft will have to be replaced on mine since I have the new transmission version...I assume the replacement version is the same as the one already in my transmission. I would prefer they do not crack open the tranny if not needed. Or are the input shaft and syncros replaced even if they are not defective? Thanks, Kurtis My understanding is that if you have the newer trans., it has the updated input shaft in it and does not need to be opened up unless you've had synchro damage. I had the old Tuet 5800 and they gave me a new trans as they had recently lost their trans. tech and therefore opted to replace the whole trans. Everything is fine, but still have the dreaded first gear shudder on take off. I don't think they will replace the shaft and synchros if you have the newer trans. I believe the up-dated input shaft is the same one that is in your newer trans. Hope this helps. P.S. According to Grabber's research the newer trans.( Tuet 8175B) has the updated shaft in it. Since yours is a Feb 08 car I think you are safe. Link to comment Share on other sites More sharing options...
kharper Posted June 5, 2009 Author Report Share Posted June 5, 2009 My understanding is that if you have the newer trans., it has the updated input shaft in it and does not need to be opened up unless you've had synchro damage. I had the old Tuet 5800 and they gave me a new trans as they had recently lost their trans. tech and therefore opted to replace the whole trans. Everything is fine, but still have the dreaded first gear shudder on take off. I don't think they will replace the shaft and synchros if you have the newer trans. I believe the up-dated input shaft is the same one that is in your newer trans. Hope this helps. P.S. According to Grabber's research the newer trans.( Tuet 8175B) has the updated shaft in it. Since yours is a Feb 08 car I think you are safe. Perfect thanks for the reply. This is good news as I do not want them changing un-needed parts Link to comment Share on other sites More sharing options...
kharper Posted June 5, 2009 Author Report Share Posted June 5, 2009 duplicate post Link to comment Share on other sites More sharing options...
SicShelby Posted June 5, 2009 Report Share Posted June 5, 2009 I thought the updated equipment didn't start going in until September of '08?? Kharper, mine was built in January 2008 and I needed everything including the input shaft and synchros. If you get the TSB, you need to have the full repair done, as it is specific to the pre-9/08 builds. I would *not* advise leaving any portion of the TSB repair out. Grabber - TSB Thread Post #14 has a couple of more links to other threads. Link to comment Share on other sites More sharing options...
Grabber Posted June 5, 2009 Report Share Posted June 5, 2009 My input on the input shaft. See post #16 http://www.teamshelby.com/forums/index.php...st&p=348408 note the tranny manufacture date not the car manufacture date. Link to comment Share on other sites More sharing options...
kharper Posted June 5, 2009 Author Report Share Posted June 5, 2009 My input on the input shaft. See post #16 http://www.teamshelby.com/forums/index.php...st&p=348408 note the tranny manufacture date not the car manufacture date. Thanks grabber, I was being short sighted by looking at the car build date and not the tranny build date Link to comment Share on other sites More sharing options...
