kahmann Posted May 21, 2009 Report Share Posted May 21, 2009 My 4 speed toploader has been installed and it's become evident that it will NOT work with the custom built Hedman long tubes and Flaming River manual rack/pinion steering kit. Both are interfering with the clutch linkage, making it impossible to use the mechanical setup. A cable clutch isn't offered for the old 4 speed, since the design is completely opposite (pull vs. push). I don't want to hack something together as a short term fix. So I'm looking for a Tremec. Any leads here? New is fine, but used is better. Thanks for any help. Ken EDIT: What about a hydraulic clutch kit for my 4 speed? I've found a couple sites that mention that this is an option. That would be a lot cheaper than a $3k tranny swap. Link to comment Share on other sites More sharing options...
GR40Freak Posted July 24, 2009 Report Share Posted July 24, 2009 Have you asked John about a T5. They may have some or may know where you can get one. Link to comment Share on other sites More sharing options...
devildog350 Posted July 24, 2009 Report Share Posted July 24, 2009 My 4 speed toploader has been installed and it's become evident that it will NOT work with the custom built Hedman long tubes and Flaming River manual rack/pinion steering kit.Both are interfering with the clutch linkage, making it impossible to use the mechanical setup. A cable clutch isn't offered for the old 4 speed, since the design is completely opposite (pull vs. push). I don't want to hack something together as a short term fix. So I'm looking for a Tremec. Any leads here? New is fine, but used is better. Thanks for any help. Ken EDIT: What about a hydraulic clutch kit for my 4 speed? I've found a couple sites that mention that this is an option. That would be a lot cheaper than a $3k tranny swap. Go with the Hydraulic clutch, simple install. Link to comment Share on other sites More sharing options...
