regalt87 Posted May 27, 2009 Author Report Share Posted May 27, 2009 I was able to successfully sand out the sag and now I have sanded the dust nibs and entire hood with 2500 grit. I will use a medium cut compound and wool pad. (did you know there are different grits of wool pads?) for the first stage of buffing. The second stage of bugging will also be with a wool pad but a much finer compound. The last stage is a polish with foam pad that eliminates swirls left by the wool pad and appears to remove a slight haze left from the compound. You have to let it work at the grabbing point not just fill the scratches. A variable speed buffer is a must as you have to be very careful. This one is a Dewalt and it has held up great. It has speed settings and also varible trigger speed. I can't' believe how heavy my 30 year old SUE buffer is compared to the Dwalt. Its retired now. There are many opportunities the screw up a job or just have something happen. After all these years I believe I should write about what not to do. Funny how you remember these as some of them hit you hard in the pocket book. I will let the hood sit a few days and kick before I flip it and glue the vents on the bottom. Link to comment Share on other sites More sharing options...
HDFXDWG2005 Posted May 28, 2009 Report Share Posted May 28, 2009 Thanks Scott. I have known him since dinosaurs roamed the area, I would NOT trust anyone to do the hood project. As you can see the job is perfect. I am new at this forum ideas, I finally got a pic of my car to go with my name, I have some pics I will try to upload of the under hood project, (one will be top secret until completion). I am new at this, if it fails pleae send some ideas ti upload pics to post (Thanks) Link to comment Share on other sites More sharing options...
HDFXDWG2005 Posted May 28, 2009 Report Share Posted May 28, 2009 more pics Link to comment Share on other sites More sharing options...
HDFXDWG2005 Posted May 28, 2009 Report Share Posted May 28, 2009 more.......... Link to comment Share on other sites More sharing options...
HDFXDWG2005 Posted May 28, 2009 Report Share Posted May 28, 2009 messed up, sent two of same pic, this is last pic........ Link to comment Share on other sites More sharing options...
nlights33 Posted May 29, 2009 Report Share Posted May 29, 2009 I am doing a Super Snake hood for a friend of mine and I thought I would include the paint prep and paint step by step for any one who is interested.Impression of the hood is that it is a quality piece. Much better than other fiberglass hoods that I have done over the years. I do not know what kind of primer Shelby used but guessing by the way it sanded it was similar to a catalyzed high build possibly a epoxy. They were generous with the amount or primer also. There were 2 little cracks in the front that I ground out and added resin. This is not unusual to see as this happens sometimes during shipping. This has to be repaired as the paint will not fill and seal them. The first step was to rough fit the hood. The after market hood hinges (I believe they were Shelby) spaced the hood too far up on one side to use. we went back to the factory hinges as I believe Shelby does any way. I had to repair a slight imperfection at the corner. Hey what type of hood lifters is your friend using for the SS hood? I have the same color but was made in 09, my shop has taken 1 month to do the hood (what a mission) Link to comment Share on other sites More sharing options...
HDFXDWG2005 Posted May 30, 2009 Report Share Posted May 30, 2009 Hey what type of hood lifters is your friend using for the SS hood?I have the same color but was made in 09, my shop has taken 1 month to do the hood (what a mission) The Shelby gas lifters can barely hold the hood up, so I am going to use the hood prop rod in conjunction with the lifters. I CANNOT aford to have the hood close during a show. I cant remember where I read it, but I saw a post that the hood can sag in the middle due to the front end being so heavy, Shelby uses the prop rod only. Link to comment Share on other sites More sharing options...
regalt87 Posted June 6, 2009 Author Report Share Posted June 6, 2009 Whatt has taken the hood to the air brush shop and will be back in a couple of weeks and I will have more pics then. Including the air brush work that you gotta see. When we were studying the hood pin crush nuts that Ford put in for him we didn't feel like there was enough hold to them. High speeds create a lot of lift. I don't want to say the current design is faulty but we felt the need to make it better. Link to comment Share on other sites More sharing options...
regalt87 Posted June 6, 2009 Author Report Share Posted June 6, 2009 This was easily slid into the radiator support via air gun in to it's place, no cutting or modification to the support. Link to comment Share on other sites More sharing options...
Torch_Vert Posted June 8, 2009 Report Share Posted June 8, 2009 This was easily slid into the radiator support via air gun in to it's place, no cutting or modification to the support. Any chance you might be persuaded to make another set of those for a bit of cash? Link to comment Share on other sites More sharing options...
regalt87 Posted June 9, 2009 Author Report Share Posted June 9, 2009 Any chance you might be persuaded to make another set of those for a bit of cash?I will be talking to Wyatt in a couple days and will ask him. Probably not a problem. Link to comment Share on other sites More sharing options...
Torch_Vert Posted June 9, 2009 Report Share Posted June 9, 2009 I will be talking to Wyatt in a couple days and will ask him. Probably not a problem. great, much appreciated Link to comment Share on other sites More sharing options...
regalt87 Posted July 15, 2009 Author Report Share Posted July 15, 2009 It's done. 40 MPH and 50 feet away it looks great!!!! Link to comment Share on other sites More sharing options...
regalt87 Posted July 15, 2009 Author Report Share Posted July 15, 2009 Under the black light. Link to comment Share on other sites More sharing options...
regalt87 Posted July 15, 2009 Author Report Share Posted July 15, 2009 Out side. Link to comment Share on other sites More sharing options...
regalt87 Posted July 15, 2009 Author Report Share Posted July 15, 2009 More Link to comment Share on other sites More sharing options...
regalt87 Posted July 15, 2009 Author Report Share Posted July 15, 2009 more Link to comment Share on other sites More sharing options...
regalt87 Posted July 15, 2009 Author Report Share Posted July 15, 2009 Last one. and I will also add that Wyatt and his car was in a local commercial for Bartow Ford. Kind of neat. This is quite a different car than it was a couple months ago. It now has the KB supercharger. A post Gauges, side quarter window covers, I believe BMR rear sway bar (ties to rear end like a Watts link) Tokico shocks as well. KR mufflers and H pipe. (sounds good) I will have Wyatt pop in and talk about the upgrades. Link to comment Share on other sites More sharing options...
regalt87 Posted July 15, 2009 Author Report Share Posted July 15, 2009 Any chance you might be persuaded to make another set of those for a bit of cash? Wyatt said he would make you some. Link to comment Share on other sites More sharing options...
Torch_Vert Posted July 16, 2009 Report Share Posted July 16, 2009 Wyatt said he would make you some. Thanks, I need to get in touch with him. My car blew out a blower discharge manifold gasket a couple weeks back, took me a while to diagnose and then time to pull everything apart and fix it. Everything else sort of got back burnered... Link to comment Share on other sites More sharing options...
VENOM 7 Posted July 16, 2009 Report Share Posted July 16, 2009 My SuperSnake hood is at the painters...will be done tomorrow...any problems installing the hoodpins?....I got the GT500 hoodpins instead of the flat ones...shelby said I had to put a slight angle in the pin for clearance....Any sugestions? I am doing a Super Snake hood for a friend of mine and I thought I would include the paint prep and paint step by step for any one who is interested.Impression of the hood is that it is a quality piece. Much better than other fiberglass hoods that I have done over the years. I do not know what kind of primer Shelby used but guessing by the way it sanded it was similar to a catalyzed high build possibly a epoxy. They were generous with the amount or primer also. There were 2 little cracks in the front that I ground out and added resin. This is not unusual to see as this happens sometimes during shipping. This has to be repaired as the paint will not fill and seal them. The first step was to rough fit the hood. The after market hood hinges (I believe they were Shelby) spaced the hood too far up on one side to use. we went back to the factory hinges as I believe Shelby does any way. I had to repair a slight imperfection at the corner. Link to comment Share on other sites More sharing options...
regalt87 Posted July 17, 2009 Author Report Share Posted July 17, 2009 My SuperSnake hood is at the painters...will be done tomorrow...any problems installing the hoodpins?....I got the GT500 hoodpins instead of the flat ones...shelby said I had to put a slight angle in the pin for clearance....Any sugestions? No problems, we just were just very careful as to line everything up. Measure, mark it and study it and don't get in a hurry and you will be fine. Link to comment Share on other sites More sharing options...
nlights33 Posted July 19, 2009 Report Share Posted July 19, 2009 It's done. 40 MPH and 50 feet away it looks great!!!! love the paint job and the air brush job. I have the same hood and same color with same dark alloy stripes, I need to ask who did your car and how are those hood struts holding up against the SS hood. Also, I live in south florida, so if your body shop guy lives in florida I will drive to see him. Link to comment Share on other sites More sharing options...
HDFXDWG2005 Posted July 19, 2009 Report Share Posted July 19, 2009 My SuperSnake hood is at the painters...will be done tomorrow...any problems installing the hoodpins?....I got the GT500 hoodpins instead of the flat ones...shelby said I had to put a slight angle in the pin for clearance....Any sugestions? After the pins are in and holes drilled in hood, you will find the holes have to be a little bigger than spec. in the instructions, also the top ring and the plastic insert are made canted, turn them to make them sit level on the hood, the hood is not level. If you have problems getting the angle and the pin pops out of radiator support call me for the fix. 863-581-3903 Link to comment Share on other sites More sharing options...
Torch_Vert Posted July 19, 2009 Report Share Posted July 19, 2009 BTW guys, the paint on the hood, both the regular finish and the graphic look AWESOME. There's no other word for it Link to comment Share on other sites More sharing options...
regalt87 Posted July 22, 2009 Author Report Share Posted July 22, 2009 love the paint job and the air brush job. I have the same hood and same color with same dark alloy stripes, I need to askwho did your car and how are those hood struts holding up against the SS hood. Also, I live in south florida, so if your body shop guy lives in florida I will drive to see him. I did the exterior paint and Wyatt had another guy do the air brush work. I am in Haines City. The hood struts seem to hold but I don't believe they are recommended by them selves. Wyatt extended his prop rod so that the hood would open more to display the airbrush work at shows and still uses the rod as well. Link to comment Share on other sites More sharing options...
skiph Posted September 9, 2009 Report Share Posted September 9, 2009 I am doing a Super Snake hood for a friend of mine and I thought I would include the paint prep and paint step by step for any one who is interested. Been following this thread for a while. Awsome job on the hood, attention to detail and all those little things that make a huge difference in the end. That snake painted on the underside of the hood just pops too! Did I read this right. doing a SS hood for a friend? Talk about a good fiend! Link to comment Share on other sites More sharing options...
mitch07ss0113 Posted September 10, 2009 Report Share Posted September 10, 2009 HEY WERE DID YOU GET THAT CERTIFICATE FOR YOUR CAR Link to comment Share on other sites More sharing options...
skiph Posted September 10, 2009 Report Share Posted September 10, 2009 HEY WERE DID YOU GET THAT CERTIFICATE FOR YOUR CAR Call SVT at 800-367-3788. From what I have heard, you can get a copy of your window sticker as well. So, would save a couple of $ to order them both at the same time if you want em both. I did not know about the window sticker option when I ordered the build cert., and I was REALLY careful when I removed the window sticker, so have not gone that route yet. Link to comment Share on other sites More sharing options...
