09KR0058 Posted May 14, 2009 Report Share Posted May 14, 2009 For the stock Alcoa Aluminum wheels on the '09 GT500KR, what are people using to clean them? And after the cleaning, should I use a polish/wax/sealer of some kind? Thx Link to comment Share on other sites More sharing options...
Stalwart Posted May 14, 2009 Report Share Posted May 14, 2009 Soap, water and then a non abrasive wax is all you'll need for years to come. Link to comment Share on other sites More sharing options...
ShowCar Posted May 15, 2009 Report Share Posted May 15, 2009 A non acid wheel cleaner(Show Car Wheel Cleaner), a soft bristle brush, and wheel seal which stands up to heat and brake dust but has no cleaners in it. Its a pure hi temprature sealant for wheels. The wheels are already coated by Alcoa but if you will be racing the car use a wheel seal. The Alcoas are the easiest to clean and keep looking great. Go to the bottom of the page for the wheel seal http://www.showcardetail.com/ShowCarProducts.html Link to comment Share on other sites More sharing options...
SkyDancer Posted May 16, 2009 Report Share Posted May 16, 2009 For the stock Alcoa Aluminum wheels on the '09 GT500KR, what are people using to clean them? And after the cleaning, should I use a polish/wax/sealer of some kind? Thx I actually use that California Wash & Wax on them while they are still wet from washing and rinsing. It really puts a shine to them and puts a slippery coating of wax on them that actually will repel dust and dirt for a couple days. I discovered this accidently when I decided to use the wash and wax just to see how it would work on the wheels. I won't ever go back to using anything else as an after-coat. Another thing I found that works to quickly remove surface dust, bug, tars and smudges off wheels and the front bumper is Stoners Glass Cleaner OR Bisell Glass Cleaner..both in a spray can. Shake the can a couple of times to foam the contents and then spray and wipe the bumper and wheels. Leaves a nice shine on the wheels. Link to comment Share on other sites More sharing options...
John Canfield Posted May 16, 2009 Report Share Posted May 16, 2009 For normal cleaning on a clear coated wheel, I use Simple Green and a soft brush. For more detailed work I use a clay bar on it (I keep older bars specifically for wheels) and then put on a coat of wax. The clear coat is just like the cars painted finsh, so treat it as such. Link to comment Share on other sites More sharing options...
shelbymotorsports Posted May 16, 2009 Report Share Posted May 16, 2009 Every couple of months I use simple green for cleaning and then some good old fashioned carnuba paste wax in the can. For regular weekly washing I just use the same car wash soap I use for the car. Steve Link to comment Share on other sites More sharing options...
mixxer Posted June 12, 2009 Report Share Posted June 12, 2009 http://www.autogeek.net/p2wheelclean.html http://www.autogeek.net/dp-wheel-glaze.html Link to comment Share on other sites More sharing options...
