08SS0144 Posted August 12, 2009 Author Report Share Posted August 12, 2009 I would add some suspension upgrades such as: Ultimate lowering suspension package Tokico shocks and struts Ford Racing front and rear sway bar Watts Linkage Baer Big Brake Kit (Front and Rear) Aluminum Drive Shaft Already had most of these from the Supersnake upgrade ( Eibach Suspension ) I did change out the factory drive shaft though to a one piece aluminum from Drive Shaft Shop (DSS) Going to be changing the upper and lower control arms out as soon as the Shelby brand are available which is supposed to be approximately 8 weeks. Thanks for the advice ! Link to comment Share on other sites More sharing options...
Lee N. Posted August 12, 2009 Report Share Posted August 12, 2009 As stated in my previous reply, they are relatively quiet at cruising speed ( 2500 to 3000 rpm ) but come "alive" during full throttle. I love it ! You running cats or no? Link to comment Share on other sites More sharing options...
08SS0144 Posted August 12, 2009 Author Report Share Posted August 12, 2009 You running cats or no? Yes High Flow 3" Catted X-pipe from JBA Link to comment Share on other sites More sharing options...
Lee N. Posted August 13, 2009 Report Share Posted August 13, 2009 Yes High Flow 3" Catted X-pipe from JBA I did the non catted JBA X pipe. Should hear it run today. Link to comment Share on other sites More sharing options...
CobraFun Posted August 13, 2009 Report Share Posted August 13, 2009 So what do you think ! :bowdown: Sounds Awesome! Link to comment Share on other sites More sharing options...
08SS0144 Posted August 27, 2009 Author Report Share Posted August 27, 2009 Sounds Awesome! OK ............... Getting ready to bite the bullett again. Taking the Snake to Modular Power House this Saturday the 28th. Having the Heads Ported and Polished Custom Cams Installed 72lb Injectors Boost-a pump installed Twin 75MM Throttle Body and all custom tuned by MPH Will post Dyno results when she's done. ( Hoping for 850 RWHP ) Link to comment Share on other sites More sharing options...
GT500-07 Posted August 27, 2009 Report Share Posted August 27, 2009 OK ............... Getting ready to bite the bullett again. Taking the Snake to Modular Power House this Saturday the 28th. Having the Heads Ported and Polished Custom Cams Installed 72lb Injectors Boost-a pump installed Twin 75MM Throttle Body and all custom tuned by MPH Will post Dyno results when she's done. ( Hoping for 850 RWHP ) Save your self some $$$$, no need to P&P the heads or cutom cams w/o forged internals. http://www.evoperform.com/shop/index.php?m...products_id=559 Link to comment Share on other sites More sharing options...
dbowles22 Posted August 27, 2009 Report Share Posted August 27, 2009 OK ............... Getting ready to bite the bullett again. Taking the Snake to Modular Power House this Saturday the 28th. Having the Heads Ported and Polished Custom Cams Installed 72lb Injectors Boost-a pump installed Twin 75MM Throttle Body and all custom tuned by MPH Will post Dyno results when she's done. ( Hoping for 850 RWHP ) do you not like the cobra jet tb? this is gonna be one of the quickest verts around lol Link to comment Share on other sites More sharing options...
Shelby Owner Posted August 29, 2009 Report Share Posted August 29, 2009 OK ............... Getting ready to bite the bullett again. Taking the Snake to Modular Power House this Saturday the 28th. Having the Heads Ported and Polished Custom Cams Installed 72lb Injectors Boost-a pump installed Twin 75MM Throttle Body and all custom tuned by MPH Will post Dyno results when she's done. ( Hoping for 850 RWHP ) That's a BIG jump in RWHP. Are you upgrading the fuel delivery system from the pumps up to the injectors? Link to comment Share on other sites More sharing options...
08SS0144 Posted August 29, 2009 Author Report Share Posted August 29, 2009 That's a BIG jump in RWHP. Are you upgrading the fuel delivery system from the pumps up to the injectors? Having a "boost pump" installed. Not sure of the brand name but will post tommorow. ( Delivering her to MPH tommorow ) Link to comment Share on other sites More sharing options...
Shelby Owner Posted August 29, 2009 Report Share Posted August 29, 2009 Having a "boost pump" installed. Not sure of the brand name but will post tommorow. ( Delivering her to MPH tommorow ) Maybe the booster pump will also include an increase of the size of the fuel lines. I've heard that over 700 RWHP benefits from larger (read that less resistance) fuel lines and fittings. If you're running 70 to 80 psi fuel pressure at the injectors, you would have much higher pressure at the pumps. Do you still have stock pumps in the tank? I interested in how this goes, sounds like something I'd like to try. Link to comment Share on other sites More sharing options...
dbowles22 Posted September 6, 2009 Report Share Posted September 6, 2009 How did everything turn out?? I'm anxious to see your results LOL Link to comment Share on other sites More sharing options...
08SS0144 Posted September 6, 2009 Author Report Share Posted September 6, 2009 Engine out on Wednesday and Heads Sent for Port / Polish Thursday. Will post results from all this when she's complete. ( About 3 or 4 weeks ) Link to comment Share on other sites More sharing options...
