Backfire at full throttle GT-H
I have been having a backfire problem at full throttle (Around 6000rpm) on my GTH. Will do it under a load or reving up. Plug? / coil? . No codes, it has done it on the stock tune and on a custom tune I have in it now :headscratch: THANKS for any help.
I'll try plugs next.....There is heavy corrosion on the plug end just up from the hoop enclosing the electrode. What's up with that?
That corrosion is a problem with plugs in a 3-valve eng. Its a build-up from the combustion process,
it also causes the plugs to break off inside the heads if it gets to thick. There's TSB from Ford on
this concern that shoulod be followed when removing & installing plugs, its been discussed on a
previous thread. If your experiencing an induction backfire, I would check fuel pressure, make sure
its to specs. A fuel filter would also be a good idea just to be sure its not clogged.
Floating or Sticky Valves??????? Hope not................
How many miles did you have on the engine and any trouble changing the plugs?
They were the originals and they were coked up pretty bad. 21500 miles. Plugs are cake to change. Just need a couple of extensions to get there and a magnets handy to pull up the plugs.
