Remove Shift Knob?????????
I just got my Redline Shifter Boot and my Grabber Pony Knob should be coming soon. It is probably very easy, but I just want to make sure.
How do you remove the Shift Knob???
I am guessing just use a wrench on the nut under it, but do not want to jack anything up.
Thanks All
Bill
  • 2 weeks later...
Thanks All
Bill
Just get a wrench and give the nut on the old knob's underside a quarter turn to loosen. From there just unscrew the old knob. Screw the new knob on to through to the last thread...then back it off just enough to line up any lettering or design on top the knob....then while holding the knob in that correct alignment and using your fingers tighten the nut up to the knob. After the nut butts up against the knob, continue to hold the knob in alignment and then wrench tighten the nut to lock into the bottom of the knob securely.
