AFBLUE Posted April 24, 2009 Report Share Posted April 24, 2009 Messing with a tire size calculator tonight. http://www.1010tires.com/TireSizeCalculato...p?action=submit While I think the 20" razors look better than the 18" razors, one of my concerns of going from 18" to 20" wheels has always been the more firm ride you get with the lower profile tires (smaller sidewall height). So I got to thinking. What if you ran a higher profile 20" wheel to lessen the firmness? In 255s I think most folks get the 255/35/20s. Overall diameter is 27.02" and the sidewall height on the these is 3.51". No need to recalibrate the speedo as it's within less than 1% of the OEM tires. The OEM wheels are 235/50/18s. at 4.62" sidewall height and 27.25" in overall diameter. Thus, over an inch taller sidewall than the 255/35/20s. If you went with the 255/40/20s you would have 4.01" diameter sidewall height and are 28.03" in overall diameter. Your speedometer would be off by less than 2mph at 60mph (2.8%) and you would have a half inch more sidewall height than the 255/35/20s. Does anybody have this setup (255/40/20s)? If so can you post some pix and speak to any tire rubbing issues? I found these pix of this combo. Thanks PS: Go ahead Swedeman...I'm waiting. Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted April 24, 2009 Report Share Posted April 24, 2009 Genius...the rear wheel always looks a little small in the wheelwell to me with most combos...you may be on to something here this is looking KILLER!!! I like the exact wheels in the pic and everything! Thanks! Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted April 24, 2009 Report Share Posted April 24, 2009 BTW do you know how to find out the specifics of the pictured combo (wheel backspace etc...) Thanks! Great job man! Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted April 24, 2009 Report Share Posted April 24, 2009 How about 35 series in the front for a "raked look" ? Link to comment Share on other sites More sharing options...
AFBLUE Posted April 24, 2009 Author Report Share Posted April 24, 2009 Got it from post #8 of at this link. That's all I got. I was hoping someone on here had done the same thing. http://www.allfordmustangs.com/forums/2005...tml#post1449554 The rears in those pix are 295/40/20s Link to comment Share on other sites More sharing options...
my08stang Posted April 24, 2009 Report Share Posted April 24, 2009 I placed an order for the CS40 Rims from SPP 20 x 10 rear and 20 x 9 fronts, and I'm still debating on what track tire to use.. poss Nitto for the 20's and going with drag radial for my 18's way too much info out there..LOL Link to comment Share on other sites More sharing options...
RACERX009 Posted April 24, 2009 Report Share Posted April 24, 2009 Messing with a tire size calculator tonight. http://www.1010tires.com/TireSizeCalculato...p?action=submit While I think the 20" razors look better than the 18" razors, one of my concerns of going from 18" to 20" wheels has always been the more firm ride you get with the lower profile tires (smaller sidewall height). So I got to thinking. What if you ran a higher profile 20" wheel to lessen the firmness? In 255s I think most folks get the 255/35/20s. Overall diameter is 27.02" and the sidewall height on the these is 3.51". No need to recalibrate the speedo as it's within less than 1% of the OEM tires. The OEM wheels are 235/50/18s. at 4.62" sidewall height and 27.25" in overall diameter. Thus, over an inch taller sidewall than the 255/35/20s. If you went with the 255/40/20s you would have 4.01" diameter sidewall height and are 28.03" in overall diameter. Your speedometer would be off by less than 2mph at 60mph (2.8%) and you would have a half inch more sidewall height than the 255/35/20s. Does anybody have this setup (255/40/20s)? If so can you post some pix and speak to any tire rubbing issues? I found these pix of this combo. Thanks PS: Go ahead Swedeman...I'm waiting. I'm running 275/35/20's and its smooth on decent road way and air pressure 32 !! Link to comment Share on other sites More sharing options...
