Dale Jerome Posted June 29, 2009 Report Share Posted June 29, 2009 FedEx delivered mine today! Now I just have to carve out enough time to put it on the car. Link to comment Share on other sites More sharing options...
Robert M Posted June 29, 2009 Report Share Posted June 29, 2009 Got my tracking number today. :happy feet: R Link to comment Share on other sites More sharing options...
500forme Posted June 29, 2009 Report Share Posted June 29, 2009 Got my tracking number today. :happy feet: R You will love the way it looks on the car! BIG improvement over the plastic! Link to comment Share on other sites More sharing options...
Robert M Posted June 29, 2009 Report Share Posted June 29, 2009 You will love the way it looks on the car! BIG improvement over the plastic! Like I had mentioned in another thread related to this CF diffuser, if nothing else it finishes the CF look that was started in the front and down the sides and buying it at $600 plus shipping (which is just over $100 because of its size) is much better than $800+ plus shipping. I believe (but am not positive), that someone told me they had priced a replacement front splitter from Shelby for their Super Snake, the cost was over $700? I think? If this is the case, $600 for this rear diffuser with its much larger mass was a Great deal!!................and then like I said, it completes the look. R Link to comment Share on other sites More sharing options...
03 DSG Snake Posted June 30, 2009 Report Share Posted June 30, 2009 Like I had mentioned in another thread related to this CF diffuser, if nothing else it finishes the CF look that was started in the front and down the sides and buying it at $600 plus shipping (which is just over $100 because of its size) is much better than $800+ plus shipping. I believe (but am not positive), that someone told me they had priced a replacement front splitter from Shelby for their Super Snake, the cost was over $700? I think? If this is the case, $600 for this rear diffuser with its much larger mass was a Great deal!!................and then like I said, it completes the look. R Yes, the front is about $650 from Shelby. This piece covers a much bigger area. :happy feet: Link to comment Share on other sites More sharing options...
500forme Posted July 1, 2009 Report Share Posted July 1, 2009 Here are some installation tips that I would like to share with you from my install. 1) Leave a couple of weep hole gaps in the bottom adheasive/sealer for moisture to drain. 2) Trim the adheasive tip for a 1/8" bead for the diffuser to facia seam. 3) Be prepared to use a lot of squeeze/grip force for the caulking gun for the 3M adheasive. Similar to gripping the handle bars of a big bore dirt bike at throttle wide open! If you use a 3/16 bead at the seam (as suggested in the instructions) it will be way to much sealer and you will have a big mess on your hands and lots of excess sealer to clean up. Run the bead at a 45 degree angle forcing the sealer into the seam and any gaps that are present. I also waited untill the next day to install the bottom screws and the mud flaps. When I installed the bottom screws shortly after the adheasion, they pulled the top edge away from the facia producing a 1/16"-1/8" gap in several areas, so I backed them off and the gaps went away. One last tip, don't wait to long to work and smooth the sealer. It is not as forgiving as a silicone sealer, it sets up relatively fast and has a granular consistancy producing a less than slick finish, but will match the texture of the original plastic. Hope this helps! B) Link to comment Share on other sites More sharing options...
Craigo Posted July 1, 2009 Report Share Posted July 1, 2009 Very good! Thanks for sharing. Link to comment Share on other sites More sharing options...
Craigo Posted July 3, 2009 Report Share Posted July 3, 2009 Got my tracking number today! Should be here soon!!!! Link to comment Share on other sites More sharing options...
Robert OHara Posted July 3, 2009 Report Share Posted July 3, 2009 Got my track number yesterday, but not on the fed x site yet :huh: Link to comment Share on other sites More sharing options...
KAM Posted July 3, 2009 Report Share Posted July 3, 2009 Here are some installation tips that I would like to share with you from my install. 1) Leave a couple of weep hole gaps in the bottom adheasive/sealer for moisture to drain. 2) Trim the adheasive tip for a 1/8" bead for the diffuser to facia seam. 3) Be prepared to use a lot of squeeze/grip force for the caulking gun for the 3M adheasive. Similar to gripping the handle bars of a big bore dirt bike at throttle wide open! If you use a 3/16 bead at the seam (as suggested in the instructions) it will be way to much sealer and you will have a big mess on your hands and lots of excess sealer to clean up. Run the bead at a 45 degree angle forcing the sealer into the seam and any gaps that are present. I also waited untill the next day to install the bottom screws and the mud flaps. When I installed the bottom screws shortly after the adheasion, they pulled the top edge away from the facia producing a 1/16"-1/8" gap in several areas, so I backed them off and the gaps went away. One last tip, don't wait to long to work and smooth the sealer. It is not as forgiving as a silicone sealer, it sets up relatively fast and has a granular consistancy producing a less than slick finish, but will match the texture of the original plastic. Hope this helps! B) PICS Link to comment Share on other sites More sharing options...
500forme Posted July 3, 2009 Report Share Posted July 3, 2009 Scroll up ^^^^^ Link to comment Share on other sites More sharing options...
camm77 Posted July 4, 2009 Report Share Posted July 4, 2009 Mine is due to be delivered tomorrow. stll waiting Link to comment Share on other sites More sharing options...
GT500FLYBOY Posted July 4, 2009 Report Share Posted July 4, 2009 I got a charge on my cc - still waiting for a tracking #... Link to comment Share on other sites More sharing options...
BoneDoc Posted July 4, 2009 Report Share Posted July 4, 2009 If you are getting yours soon.... please take pics of the install.... it will help the rest of us out quite a bit. Thanks Ron Link to comment Share on other sites More sharing options...
08SHELBYSS Posted July 9, 2009 Report Share Posted July 9, 2009 :happy feet: Got my CF rear diffuser cover today. Looks really good, now I just need some time to put in on Link to comment Share on other sites More sharing options...
Craigo Posted July 9, 2009 Report Share Posted July 9, 2009 Got my tracking number today! Should be here soon!!!! Just got it and it looks great. But no instructions... Link to comment Share on other sites More sharing options...
500forme Posted July 9, 2009 Report Share Posted July 9, 2009 Just got it and it looks great. But no instructions... PM me with your email address and I will send them to you. Link to comment Share on other sites More sharing options...
Robert M Posted July 9, 2009 Report Share Posted July 9, 2009 Here are some pics of my install. Wow!!! I did not see the installed pictures of your diffuser until now. It looks Great!! I got mine today, diffuser, fasteners, tube of caulk, tip, but no instructions. Could I also get a copy of the instructions you have? I will send a PM to you. Thanks, Robert Link to comment Share on other sites More sharing options...
500forme Posted July 9, 2009 Report Share Posted July 9, 2009 Craigo and Robert, email sent with instructions. Glad to help. You'll love the finished results! Link to comment Share on other sites More sharing options...
Craigo Posted July 10, 2009 Report Share Posted July 10, 2009 Craigo and Robert, email sent with instructions. Glad to help. You'll love the finished results! Thanks... I can't wait! Link to comment Share on other sites More sharing options...
Robert M Posted August 1, 2009 Report Share Posted August 1, 2009 Here are some pics of my install. Did you get the email from Scott C. regarding the CF rear mud flaps that are soon to be released, to complete the rear CF look? That is pretty cool, they are doing those flaps in CF also. I am number two on the list. As with the original CF diffuser, he says that there is an "pre-sale offering", it is 20% off currently. He said he would send pictures soon. From what I understand in the email, the front side of each CF flap will have some sort of undercoating, (probably rubberized), to keep the protected from stones and other debris. R Link to comment Share on other sites More sharing options...
500forme Posted August 2, 2009 Report Share Posted August 2, 2009 Did you get the email from Scott C. regarding the CF rear mud flaps that are soon to be released, to complete the rear CF look? That is pretty cool, they are doing those flaps in CF also. I am number two on the list. As with the original CF diffuser, he says that there is an "pre-sale offering", it is 20% off currently. He said he would send pictures soon. From what I understand in the email, the front side of each CF flap will have some sort of undercoating, (probably rubberized), to keep the protected from stones and other debris. R Robert, I'm right behind you at number 3, but he offered me 40% off...just kidding . Darn that Scott, looks like another month of beans and rice! Link to comment Share on other sites More sharing options...
MYSNAKE Posted August 3, 2009 Report Share Posted August 3, 2009 Someone please contact me with info on where to get one or if there is going to be another mass buy.... Thanks Link to comment Share on other sites More sharing options...
03 DSG Snake Posted August 3, 2009 Report Share Posted August 3, 2009 Someone please contact me with info on where to get one or if there is going to be another mass buy.... Thanks http://www.raceskinz.us.com/ Link to comment Share on other sites More sharing options...
Stalwart Posted August 3, 2009 Report Share Posted August 3, 2009 Mine has gone missing, thanks FedEx . . . They are having to send me another one. Link to comment Share on other sites More sharing options...
MYSNAKE Posted August 4, 2009 Report Share Posted August 4, 2009 Thanks for the info 03 DSG Snake Link to comment Share on other sites More sharing options...
07SS330 Posted August 17, 2009 Author Report Share Posted August 17, 2009 NEW NEWS! Raceskins is now selling Carbon Fiber Mud Flaps to go with the Rear Diffuser we all ordered! This will be the Last Piece of Black Plastic to be replaced by CF. If we get enough people interested I will get us all a Discount as a GROUP BUY!! Link to comment Share on other sites More sharing options...
500forme Posted August 18, 2009 Report Share Posted August 18, 2009 NEW NEWS! Raceskins is now selling Carbon Fiber Mud Flaps to go with the Rear Diffuser we all ordered! This will be the Last Piece of Black Plastic to be replaced by CF. If we get enough people interested I will get us all a Discount as a GROUP BUY!! Get ahold of Scott C. at raceskinz and get on the list with some of us that were on the group for the diffuser buy that you initiated for us. They are now offering a 20% discount for a early purchase sign up. Link to comment Share on other sites More sharing options...
Robert M Posted August 18, 2009 Report Share Posted August 18, 2009 NEW NEWS! Raceskins is now selling Carbon Fiber Mud Flaps to go with the Rear Diffuser we all ordered! This will be the Last Piece of Black Plastic to be replaced by CF. If we get enough people interested I will get us all a Discount as a GROUP BUY!! Read the post by Robert M (that's me) at beginning of this page.......... R Link to comment Share on other sites More sharing options...
07SS330 Posted August 18, 2009 Author Report Share Posted August 18, 2009 I will be posting pictures soon! Link to comment Share on other sites More sharing options...
