speedyburd33 Posted April 17, 2009 Report Share Posted April 17, 2009 Today while looking over my SGT I noticed that the rear brake ducts didn't look quite right. I put the back end up on some ramps and got underneath it to find that on both sides the front piece was completely out of the back piece. I also noticed that on the driver's side the back piece had been rubbing the inside of the wheel. Also on both sides, the metal plate holding the back piece had been digging into the rubber protective sleeve that covers the brake line. I spent about an hour or so taking them apart. I cleaned them up a little and made some adjustments. All 4 of the bolts holding the 2 back pieces in place were very loose already when I took them off. I think i've got it all taken care of. Has anyone else had this happen? Link to comment Share on other sites More sharing options...
clark17357 Posted April 17, 2009 Report Share Posted April 17, 2009 Mine have been fine since I got them in August 2008. Chris Carter (drhvac) had his done at Quantum not all that long ago. If he sees this thread, he might chime in. Jim Link to comment Share on other sites More sharing options...
Reino Posted April 17, 2009 Report Share Posted April 17, 2009 Might want to apply a dab of Loctite if you havent already. Link to comment Share on other sites More sharing options...
mikewheels Posted April 18, 2009 Report Share Posted April 18, 2009 I forgot, what was the deal with those? Were they an option or standard on SGTs? I know I don't have them on mine but Roger showed me a set he had. Link to comment Share on other sites More sharing options...
clark17357 Posted April 18, 2009 Report Share Posted April 18, 2009 I forgot, what was the deal with those? Were they an option or standard on SGTs? I know I don't have them on mine but Roger showed me a set he had. Option. Jim Link to comment Share on other sites More sharing options...
GT500-07 Posted April 18, 2009 Report Share Posted April 18, 2009 Option.Jim from SAI or Ford? Link to comment Share on other sites More sharing options...
clark17357 Posted April 18, 2009 Report Share Posted April 18, 2009 from SAI or Ford? SAI. Jim Link to comment Share on other sites More sharing options...
08sgt1042 Posted April 18, 2009 Report Share Posted April 18, 2009 anyone have pic's would like to see how these are run. Link to comment Share on other sites More sharing options...
GT500-07 Posted April 18, 2009 Report Share Posted April 18, 2009 SAI. Jim thanks Jim Link to comment Share on other sites More sharing options...
clark17357 Posted April 18, 2009 Report Share Posted April 18, 2009 anyone have pic's would like to see how these are run. Check these and you will get an idea. http://s238.photobucket.com/albums/ff161/c...rakeDuctsFront/ http://s238.photobucket.com/albums/ff161/c...BrakeDuctsRear/ Jim Link to comment Share on other sites More sharing options...
07SGT4578 Posted April 18, 2009 Report Share Posted April 18, 2009 I have not had a problem with mine yet, that I know of. I will have to look when I go out to the shop later. They are a PIA to get lined up it took Quantum almost 2 hours to get mine adjusted just right where they did not rub. Below is a pic of mine. Chris Link to comment Share on other sites More sharing options...
