execspec1 Posted April 8, 2009 Report Share Posted April 8, 2009 Hello, I just bought a 2007 Shelby GT and would like to know more about this car,whats under the hood ect.Is there a standard package . any help I'm just learning Shelby. Link to comment Share on other sites More sharing options...
08SGT1977 Posted April 8, 2009 Report Share Posted April 8, 2009 Hello, I just bought a 2007 Shelby GT and would like to know more about this car,whats under the hood ect.Is there a standard package . any help I'm just learning Shelby. Congratulations and welcome. Check out the downloads section. There should be some brochures that show all the modifications from Shelby. Link to comment Share on other sites More sharing options...
ilmor Posted April 8, 2009 Report Share Posted April 8, 2009 If I understand your question correctly - do you want to know all the original specs and what comes as standard equipment on the car? Link to comment Share on other sites More sharing options...
execspec1 Posted April 8, 2009 Author Report Share Posted April 8, 2009 Yes I'm wanting the original specs,the way it was finished from Las vegas 07SGT1856 like I said is there some standard package or are they all different. Link to comment Share on other sites More sharing options...
AstroDan Posted April 8, 2009 Report Share Posted April 8, 2009 Yes I'm wanting the original specs,the way it was finished from Las vegas 07SGT1856 like I said is there some standard package or are they all different. 1st off, Welcome to Team Shelby! That is a sweet ride you have there! Pictures are a must! The Shelby GT is upgraded with the : You may or may not have the installed gauges. Mine also is a GT Premium prior to Shelby and some were standard. All this should be on you sticker... Dan Link to comment Share on other sites More sharing options...
execspec1 Posted April 8, 2009 Author Report Share Posted April 8, 2009 Yes I went back in the Team Shelby news I guess and found the anouncement from the start of the 2007 model year ,and it told of all of the changes thank you all for your help Link to comment Share on other sites More sharing options...
sireal66 Posted April 9, 2009 Report Share Posted April 9, 2009 1st off, Welcome to Team Shelby! That is a sweet ride you have there! Pictures are a must!The Shelby GT is upgraded with the : You may or may not have the installed gauges. Mine also is a GT Premium prior to Shelby and some were standard. All this should be on you sticker... Dan Does the 2007 GT H differ in any way mechanically i.e. suspension, tune, rear end gearing, other then the obvious automatic, and body parts? Link to comment Share on other sites More sharing options...
ejrail Posted April 9, 2009 Report Share Posted April 9, 2009 Welcome. Good choice of cars :happy feet: Link to comment Share on other sites More sharing options...
shelbytexan Posted April 10, 2009 Report Share Posted April 10, 2009 Hello, I just bought a 2007 Shelby GT and would like to know more about this car,whats under the hood ect.Is there a standard package . any help I'm just learning Shelby. You just opened yourself up to an encyclopedia of knowledge with these guys. You have guys on this forum just slobbering at the mouth waiting to help. Welcome. Link to comment Share on other sites More sharing options...
stormeaston Posted April 10, 2009 Report Share Posted April 10, 2009 Jusy keep hanging around here, you'll learn alot............and some stuff you don't care to learn! Oh ya..............."WELCOME"! Link to comment Share on other sites More sharing options...
Michael Morris Posted April 10, 2009 Report Share Posted April 10, 2009 Does the 2007 GT H differ in any way mechanically i.e. suspension, tune, rear end gearing, other then the obvious automatic, and body parts? Pretty much. The SGT was the retail version of the GTH! Different stripes and wheels and most were autos!! MM Link to comment Share on other sites More sharing options...
sireal66 Posted April 12, 2009 Report Share Posted April 12, 2009 Pretty much. The SGT was the retail version of the GTH! Different stripes and wheels and most were autos!! MM Michael thanks, but after seeing your spec sheet I am totally confused- comparing your spec sheet and my spec sheet I don’t see the same items listed for the handling packages (or even the same codes) I don’t see lowering springs, no sway bars. Was the GT H given a less effective suspension? Rich Link to comment Share on other sites More sharing options...
socalwrench Posted April 12, 2009 Report Share Posted April 12, 2009 The spec sheet above actually says "Front Torsion Bar" and "Rear Torsion Bar". This would be an incorrect name for the front and rear anti-roll bars / sway bars. Technically, in an engineering sense, the anti-roll bar DOES act like a lateral torsion bar. However, in car terms a torsion bar refers to another type of suspension spring. However, you are right- I can't find anything says springs on that sheet. I do know that the GT-H used the entire FR1 package- which uses Ford Racing K-springs. Link to comment Share on other sites More sharing options...
sireal66 Posted April 12, 2009 Report Share Posted April 12, 2009 The spec sheet above actually says "Front Torsion Bar" and "Rear Torsion Bar". This would be an incorrect name for the front and rear anti-roll bars / sway bars. Technically, in an engineering sense, the anti-roll bar DOES act like a lateral torsion bar. However, in car terms a torsion bar refers to another type of suspension spring. However, you are right- I can't find anything says springs on that sheet. I do know that the GT-H used the entire FR1 package- which uses Ford Racing K-springs. Socalwrench, so if I read this right the GT H doe not have the same suspension components as the GT? No sway bars or lowering springs!! I just found this in 'Vehicles" on this site, Articles & News 2008 Shelby GT-H Introduced By Staff Report "Thundering Ponies Ford Racing Performance Group’s Power Pack (FR1) will kick up the 4.6L V-8/Five-speed automatic transmission powertrain to 319 horsepower. To put that extra power to the ground, the Ford Shelby GT-H will feature the Ford Racing Handling Pack (FR3) including special-tuned dampers, lowering springs, sway bars and a strut tower brace – plus a 3.55:1 ratio rear axle assembly for extra off-the-line acceleration." Link to comment Share on other sites More sharing options...
07-2937 Posted April 12, 2009 Report Share Posted April 12, 2009 the front susp of the GTH is different Hertz knew if it was lowered there would be alot of curb bashing so the fronts were modified I believe it was the stock strut with the ford racing spring and a modified swaybar. Link to comment Share on other sites More sharing options...
