sdac guy Posted March 29, 2009 Report Share Posted March 29, 2009 I saw this over on turbo-mopar and thought I would make note of it here too. http://denver.craigslist.org/cto/1095320425.html The guy is honest about admitting that he switched all the parts from #503 to this car, but it isn't even and 87 body, it's an 86, and the sale is listed as an 87 GLHS. Link to comment Share on other sites More sharing options...
shelbymotorsports Posted March 29, 2009 Report Share Posted March 29, 2009 The guy is honest about admitting that he switched all the parts from #503 to this car, but it isn't even and 87 body, it's an 86, and the sale is listed as an 87 GLHS. Wow that car definitely deserves a yellow warning flag. The most disturbing part is the title and the first line of the ad: This car is my 1987 Shelby GLHS, production number 503 of 1000. I don't think so. Your car at best is a 1986 Dodge Shelby Charger with some additional parts from a scrapped 1987 Shelby GLHS. My biggest concern is that he is not clear on the vin number. I've read his ad several times and it's hard to say what vin number this 1986 Dodge Shelby Charger has. Its original vin from Chrysler or has the vin from the GLHS been swapped over? Thanks Barry for the heads up. I'll be sure it gets noted for the registry. Steve ------------------------ 1987 Shelby Charger GLHS - $4200 (Denver, CO) Reply to: sale-dn8bz-1095320425@craigslist.org [Errors when replying to ads?] Date: 2009-03-27, 5:37PM MDT This car is my 1987 Shelby GLHS, production number 503 of 1000. For those familiar with the 1987 GLHS this car may look different, that is because the original chassis suffered damage to the B pillar in an accident and was not able to be repaired to my liking. I am a professional mechanic and decided to purchase another chassis to swap all parts from the original car into. The chassis you see is a 1986 Shelby Charger. ALL original GLHS specific parts have been swapped into this chassis. These parts include: engine, transmission, ecu, wiring harness, steering rack, gauge cluster, steering wheel, shifter and all suspension components. The chassis swap was completed approximately 8 years ago and the car is solid and runs very well. There are no problems or "gremlins" with vehicle I just want to have full disclosure with the new owner of this vehicle and I will happily answer any questions that you have. Essentially this car is everything that a 1987 GLHS is but it just happens to be in a 1986 Shelby Charger chassis. If you are unfamiliar with the 1987 GLHS please google it and you will see that this is an actual car built by the legendary Carroll Shelby. I primarily used this car for autocross, road racing and leisurely drives in nice weather. In the almost 10 years that I've owned this car it has always been garaged and never driven in the winter. I have put approximately 7000 miles on it since I purchased it and it has 109,000 miles on the odometer. I have upgraded and modified this car significantly over the years I will list as many modifications as I can remember. I had a great time owning this car and it will be a nice project car for someone else, but with starting a family I don't have the time for this anymore. The car runs and drives well and passes emissions with no problems. Please contact me with any questions. LIST OF MODIFICATIONS: -Mopar Stage II ECU -Forward Motion ported and polished cylinder head -Forward Motion upgraded cam and valvetrain (for a more broad powerband) -Forward Motion ported two piece intake manifold -Forward Motion ported exhaust manifold -52mm throttle body -Larger fuel injectors (I can't remember flow rate but they are 2 sizes larger than stock and good for 300+ hp) -Adjustable fuel pressure regulator -Walbro 255 lph fuel pump -Original Garrett turbocharger has been rebuilt and upgraded to a T3/T4 -Mopar Super 60 Intercooler -Turbo XS rfl blow-off valve with custom upper intercooler pipe -All new Mopar Performance motor mounts -Low profile electric radiator fan with manual override switch -Centerforce clutch and pressure plate -New Koni adjustable struts at all 4 corners -Mopar Performance lowering springs (approx 1 inch drop and stiffer spring rate) -Rear disc brake conversion from a 1990 Dodge Daytona -Baffled oil pan -Battery has been relocated to the trunk -Battery kill switch -Sparco 4 point harnesses for front seats -Autometer boost and A/F gauges on A-pillar -Custom 16x7.5 wheels with 205/45/16 tires -Custom exhaust (2.5 inch cat back with center mounted tip) -Custom heim jointed shifter linkage The purchaser of this vehicle will recive all original parts and extra parts that I have as well as the original Shelby wheels and 6 R compound race tires also mounted on factory wheels (2 BF Goodrich and 4 Kumho) Please email me or contact me at 720-934-5151 leave a message and I will promptly return your call. Link to comment Share on other sites More sharing options...
