ARMORINE Posted March 10, 2009 Report Share Posted March 10, 2009 so i already have the lower intake bezels and piaa driving lights. i was thinking about doing the cs6 grill with the lights, im trying to figure out if the electrical system would support this? i was thinking i would run a seperate harness for the grill lights. would this work? would i have to beef up the alternator? i figure the sgt would have some electrical power left over for safety margin, running a seperate harness i could use that since it would go through the battery and not the harness already in there. i'll start figuring out the power draw tonight i do however need the schematics and specs for the electrical system. i unfortunatly can't seem to find them. any ideas or input would be greatly appriciated Link to comment Share on other sites More sharing options...
tekheavy Posted March 10, 2009 Report Share Posted March 10, 2009 so i already have the lower intake bezels and piaa driving lights. i was thinking about doing the cs6 grill with the lights, im trying to figure out if the electrical system would support this? i was thinking i would run a seperate harness for the grill lights. would this work? would i have to beef up the alternator? i figure the sgt would have some electrical power left over for safety margin, running a seperate harness i could use that since it would go through the battery and not the harness already in there. i'll start figuring out the power draw tonight i do however need the schematics and specs for the electrical system. i unfortunatly can't seem to find them. any ideas or input would be greatly appriciated Here's the diagram for the headlights: headlights.jpg.pdf I just used the plug that's already powered up for the GT grille lights headlights.jpg.pdf Link to comment Share on other sites More sharing options...
ARMORINE Posted March 10, 2009 Author Report Share Posted March 10, 2009 Here's the diagram for the headlights: headlights.jpg.pdf I just used the plug that's already powered up for the GT grille lights i would do that too but unfortunatly thats already taken by the PIAA driving lights. im going to hav to set up another harness for the grill lights seperatly. the factory harness only has previsions for one set of fog lights(driving lights in this case) im just worried about over loading the system. on the other hand these will look and function phenomenaly if i get it all figured out Link to comment Share on other sites More sharing options...
ARMORINE Posted March 10, 2009 Author Report Share Posted March 10, 2009 i might be able to splice into the bus...but i risk overloading the current harness. Link to comment Share on other sites More sharing options...
tekheavy Posted March 10, 2009 Report Share Posted March 10, 2009 i might be able to splice into the bus...but i risk overloading the current harness. Did you want the lower lights to switch on seperately from the CS6 grille lights?? Link to comment Share on other sites More sharing options...
ARMORINE Posted March 10, 2009 Author Report Share Posted March 10, 2009 Did you want the lower lights to switch on seperately from the CS6 grille lights?? not really, i could put in a switch in the wiring for that, i want them to function together. Link to comment Share on other sites More sharing options...
tekheavy Posted March 10, 2009 Report Share Posted March 10, 2009 not really, i could put in a switch in the wiring for that, i want them to function together. If you want them both to operate off the fog light switch, all you need is to add a 20/30 amp relay. Use the output of the fog light connector thats under the hood to operate the coil side of the relay with the other side to ground. Then the other two sides of the relay are your high current side, with one going to the battery thru a fuse and the other going to the load side of your lights. Link to comment Share on other sites More sharing options...
greaser Posted March 10, 2009 Report Share Posted March 10, 2009 If you want them both to operate off the fog light switch, all you need is to add a 20/30 amp relay. Use the output of the fog light connector thats under the hood to operate the coil side of the relay with the other side to ground. Then the other two sides of the relay are your high current side, with one going to the battery thru a fuse and the other going to the load side of your lights. +1 this is youre best bet. Link to comment Share on other sites More sharing options...
ARMORINE Posted March 10, 2009 Author Report Share Posted March 10, 2009 If you want them both to operate off the fog light switch, all you need is to add a 20/30 amp relay. Use the output of the fog light connector thats under the hood to operate the coil side of the relay with the other side to ground. Then the other two sides of the relay are your high current side, with one going to the battery thru a fuse and the other going to the load side of your lights. good lord...im gonna need an electrical engineer....... wish this was more stright forward. i guess i'll get some friends involved and do this. im good with engines...i kinda suck with wiring, i'll post up when i start on this. this relay would be seperate from the fuse box? Link to comment Share on other sites More sharing options...
tispco Posted March 10, 2009 Report Share Posted March 10, 2009 Just an FYI. In a lot of states, I believe it is illegal to have two sets of aux. lights on at the same time. It would probably be worth checking into so you don't get pulled over. Link to comment Share on other sites More sharing options...
tekheavy Posted March 10, 2009 Report Share Posted March 10, 2009 good lord...im gonna need an electrical engineer....... wish this was more stright forward. i guess i'll get some friends involved and do this. im good with engines...i kinda suck with wiring, i'll post up when i start on this. this relay would be seperate from the fuse box? Its actually alot easier than it sounds. Yes, its a seperate relay that you would install. Pepboys sells them. Theyre usually known as a horn relay, usually made by Bosch. there's 4 or 5 contacts. They'll be numbered 85, 86, 87, 87A and 30. 85 and 86 are your coil contacts. 87 and 30 are your switched high current contacts. 87A you wont need. This should help you: http://www.rattlebars.com/mtz/basicrelay.jpg Link to comment Share on other sites More sharing options...
ARMORINE Posted March 10, 2009 Author Report Share Posted March 10, 2009 Just an FYI. In a lot of states, I believe it is illegal to have two sets of aux. lights on at the same time. It would probably be worth checking into so you don't get pulled over. i think im safe in oklahoma. were so lax on road rules here its all good. Link to comment Share on other sites More sharing options...
ARMORINE Posted March 10, 2009 Author Report Share Posted March 10, 2009 Its actually alot easier than it sounds. Yes, its a seperate relay that you would install. Pepboys sells them. Theyre usually known as a horn relay, usually made by Bosch. there's 4 or 5 contacts. They'll be numbered 85, 86, 87, 87A and 30. 85 and 86 are your coil contacts. 87 and 30 are your switched high current contacts. 87A you wont need. This should help you: http://www.rattlebars.com/mtz/basicrelay.jpg tekheavy you are AWESOME. i think i could build another harness wrap just to make it look all clean. i think this will look great. thanks for the info. i'll go get some of the parts today. hopefully i'll get most of this done quickly. i'll post in here with questions on this every now and then. Link to comment Share on other sites More sharing options...
ARMORINE Posted March 10, 2009 Author Report Share Posted March 10, 2009 i woudl only nee one fo these relays for all four lights? Link to comment Share on other sites More sharing options...
tekheavy Posted March 10, 2009 Report Share Posted March 10, 2009 i woudl only nee one fo these relays for all four lights? yes...... they're usually rated at 20 or 30 amps. That will be plenty. Come to my shop in NY, I have about 500 here. :P Link to comment Share on other sites More sharing options...
ARMORINE Posted March 10, 2009 Author Report Share Posted March 10, 2009 yes...... they're usually rated at 20 or 30 amps. That will be plenty. Come to my shop in NY, I have about 500 here. :P you have to move closer! thats only about 800 miles! now i would wire the lights in parralel right?...its bena very longtime since my electrical classes.... Link to comment Share on other sites More sharing options...
tekheavy Posted March 10, 2009 Report Share Posted March 10, 2009 you have to move closer! thats only about 800 miles! now i would wire the lights in parralel right?...its bena very longtime since my electrical classes.... All your positive leads can be hooked to together and your ground lead should go to the chassis. Probably a good idea to fuse all your hot leads. Link to comment Share on other sites More sharing options...
mywickedshelby Posted March 10, 2009 Report Share Posted March 10, 2009 please let us know how it turns out. Link to comment Share on other sites More sharing options...
ARMORINE Posted March 10, 2009 Author Report Share Posted March 10, 2009 please let us know how it turns out. i'll be sure to do so. i'll pull the trigger on this in about a month so it may be a while. Link to comment Share on other sites More sharing options...
tekheavy Posted March 10, 2009 Report Share Posted March 10, 2009 i'll be sure to do so. i'll pull the trigger on this in about a month so it may be a while. What color SGT do you have? Link to comment Share on other sites More sharing options...
Kvin C Posted March 10, 2009 Report Share Posted March 10, 2009 i'll be sure to do so. i'll pull the trigger on this in about a month so it may be a while. Sounds like you are in good hands with tek for the electrical work...but do you have the CS6 grille yet? If not, that may be your biggest stumbling block. Last I checked (3 weeks or so ago), SPP was still out of stock and prospects for their replacement in the near future were then pretty slim. If you know better about the CS6 grille, please advise and, in any event, best of luck with your project - very unique! Kevin Link to comment Share on other sites More sharing options...
tekheavy Posted March 11, 2009 Report Share Posted March 11, 2009 Sounds like you are in good hands with tek for the electrical work...but do you have the CS6 grille yet? If not, that may be your biggest stumbling block. Last I checked (3 weeks or so ago), SPP was still out of stock and prospects for their replacement in the near future were then pretty slim. If you know better about the CS6 grille, please advise and, in any event, best of luck with your project - very unique! Kevin Thanks for the props Kevin. Yeah, I didn't even think to ask him if he had it yet. From his first post, it sounds like he doesn't. Link to comment Share on other sites More sharing options...
ARMORINE Posted March 11, 2009 Author Report Share Posted March 11, 2009 What color SGT do you have? black, i havent seen one with this mod yet so im looking really hard...i dont knwo how it will look, one of my firends is going to photochop a picture for me..thats about as close as i'll get seeing a finnished one with out actually doing it i think Link to comment Share on other sites More sharing options...
ARMORINE Posted March 11, 2009 Author Report Share Posted March 11, 2009 Sounds like you are in good hands with tek for the electrical work...but do you have the CS6 grille yet? If not, that may be your biggest stumbling block. Last I checked (3 weeks or so ago), SPP was still out of stock and prospects for their replacement in the near future were then pretty slim. If you know better about the CS6 grille, please advise and, in any event, best of luck with your project - very unique! Kevin my mod shops become adept at getting me parts. i was told it would be near impossible to get the lights and bezel. i wnet to the shop and they called up shelby and had a set in for me 3 days later. theyr a good bunch of people. Link to comment Share on other sites More sharing options...
mustangman33 Posted March 11, 2009 Report Share Posted March 11, 2009 so i already have the lower intake bezels and piaa driving lights. i was thinking about doing the cs6 grill with the lights, im trying to figure out if the electrical system would support this? i was thinking i would run a seperate harness for the grill lights. would this work? would i have to beef up the alternator? i figure the sgt would have some electrical power left over for safety margin, running a seperate harness i could use that since it would go through the battery and not the harness already in there. i'll start figuring out the power draw tonight i do however need the schematics and specs for the electrical system. i unfortunatly can't seem to find them. any ideas or input would be greatly appriciated That grill looks awsome and you sould be able to use the current GT harness already there. Does anyone know of anyone who has one of the old chopped up grill that SAI left on the 07's???? I would like to buy one so I can put the CS6 grill on my car. Plese PM me if you know of anyone. Thanks. And good luck with your grill. Jim Link to comment Share on other sites More sharing options...
ARMORINE Posted March 13, 2009 Author Report Share Posted March 13, 2009 photochops courtesy of one of my firends, this is just a look at what it will look like. so far im liking it. without grill lights with grill lights Link to comment Share on other sites More sharing options...
tekheavy Posted March 13, 2009 Report Share Posted March 13, 2009 That looks awesome!!! I wonder how it would look in white. Link to comment Share on other sites More sharing options...
ARMORINE Posted March 13, 2009 Author Report Share Posted March 13, 2009 That looks awesome!!! I wonder how it would look in white. well i called my shop today and told them to see how soon they could get one in. im VERY confident in their ability i believe theyll be more then capable of getting me a grill and lights Link to comment Share on other sites More sharing options...
ARMORINE Posted March 13, 2009 Author Report Share Posted March 13, 2009 im thinking maybe a mesh black out kit for the main lights then splitters then use some black turn signals. whatca think? Link to comment Share on other sites More sharing options...
tekheavy Posted March 13, 2009 Report Share Posted March 13, 2009 im thinking maybe a mesh black out kit for the main lights then splitters then use some black turn signals. whatca think? Sounds like the makings for a pretty mean looking car. Go for it! Link to comment Share on other sites More sharing options...
