Captain Beyond Posted March 9, 2009 Report Share Posted March 9, 2009 Has anyone removed their Shelby signed dash plaque? Is there alot of sticky residue left from the tape? If so, what's the best way to clean without damaging my dash? Thanks. Link to comment Share on other sites More sharing options...
shel-b001 Posted March 9, 2009 Report Share Posted March 9, 2009 Shouldn`t be a problem as there isn`t` alot 3m on the back. Just use a good cleaner wax or wax should remove it no problem Link to comment Share on other sites More sharing options...
carrera Posted March 9, 2009 Report Share Posted March 9, 2009 Has anyone removed their Shelby signed dash plaque? Is there alot of sticky residue left from the tape? If so, what's the best way to clean without damaging my dash?Thanks. I had to remove mine when my car was sent to Tasca to be Super Snaked. The plaque came off quite easily using a piece of fishing line wrapped around each thump and sliding it back and forth in a sawing motion behind the plaque. Using a heat gun to soften the adhesive helps. Just go slowly and it comes off without leaving a mark Link to comment Share on other sites More sharing options...
thewheelman Posted March 9, 2009 Report Share Posted March 9, 2009 GooGone is my favorite! Link to comment Share on other sites More sharing options...
Torch40 Posted March 20, 2009 Report Share Posted March 20, 2009 Has anyone removed their Shelby signed dash plaque? Is there alot of sticky residue left from the tape? If so, what's the best way to clean without damaging my dash?Thanks. Here's how I did it. There was virtually no residue from mine. Just lift slowly, making sure the corners don't dig into the dash. http://www.teamshelby.com/forums/index.php...st&p=584868 Link to comment Share on other sites More sharing options...
Captain Beyond Posted March 23, 2009 Author Report Share Posted March 23, 2009 Thanks for all the replies. I used the spatula method, but broke it. I then used some fishing line and it also broke. That thing is stuck on there good. I'm gonna see if I can find some stronger fishing line. Link to comment Share on other sites More sharing options...
09shlb Posted March 23, 2009 Report Share Posted March 23, 2009 Thanks for all the replies. I used the spatula method, but broke it. I then used some fishing line and it also broke. That thing is stuck on there good. I'm gonna see if I can find some stronger fishing line. Remember to use the hair dryer to lightly heat up the adhesive. Warming up the adhesive will help the fishing line cut through Link to comment Share on other sites More sharing options...
shelbymustangdan Posted March 23, 2009 Report Share Posted March 23, 2009 Just as a side note: When I installed mine, I went to the store and picked up some of those white foam like, double sided sticky pads (they come in circles or squares) for hanging pictures and such. I thought it would be easier to remove and less chance of damaging the underlying surface. When I saw the 3M type tape which came with the plaque, I thought it was overkill for such a light weight piece. (unlike a side scoop) Anyway, just food for thought if anyone installs (or reinstalls) one. Dan Link to comment Share on other sites More sharing options...
