ORNGCRSH Posted March 7, 2009 Report Share Posted March 7, 2009 Could someone offer a little input on the TPM. Do I have to reset it to get rid of the "TIRE PRESSURE MONITOR FAULT"? And, should I be running 38 front and 36 rear on these 20's? Thanks much Link to comment Share on other sites More sharing options...
SVTpower Posted March 7, 2009 Report Share Posted March 7, 2009 Assume your 20's you installed have the sensors installed ?? if so, yes, you need to do a retrain.........dealer can do in 5 min. or you can buy the tool and do yourself. Link to comment Share on other sites More sharing options...
ORNGCRSH Posted March 7, 2009 Author Report Share Posted March 7, 2009 This SS is straight out of SAI in Vegas, and I would imagine that the 20's do have the sensors. Is that the norm with SS package? Thanks, and what PSI are you running, (if you have the PZero's also)? Link to comment Share on other sites More sharing options...
enormous Posted March 7, 2009 Report Share Posted March 7, 2009 I think 38 and 36 will be too firm. My 20's are 33 and 31 and are yet still firm. My Ford dealer retrained all 4 sensors in under 2 minutes. I walked up to the tire Tech, gave him $5 and had it done in a jiffy. Going through the sevice desk would have been more time consuming. Link to comment Share on other sites More sharing options...
ORNGCRSH Posted March 7, 2009 Author Report Share Posted March 7, 2009 I think 38 and 36 will be too firm. My 20's are 33 and 31 and are yet still firm. My Ford dealer retrained all 4 sensors in under 2 minutes. I walked up to the tire Tech, gave him $5 and had it done in a jiffy. Going through the sevice desk would have been more time consuming. Thanks....this forum is a great tool!! Link to comment Share on other sites More sharing options...
ORNGCRSH Posted March 8, 2009 Author Report Share Posted March 8, 2009 I think 38 and 36 will be too firm. My 20's are 33 and 31 and are yet still firm. My Ford dealer retrained all 4 sensors in under 2 minutes. I walked up to the tire Tech, gave him $5 and had it done in a jiffy. Going through the sevice desk would have been more time consuming. Went to Ford dealership and they reset mine @ 33 front, 31 rear. Thanks for the info Link to comment Share on other sites More sharing options...
jcool Posted June 5, 2009 Report Share Posted June 5, 2009 I too had a Tire sensor fault after getting my car home from SAI. I found the info on the site and stopped by the dealer and after they were finished drooling over the car; they took it right in and retrained the sensors. I was in and out in about 10 minutes. The info on this site is so right on! Thanks! Link to comment Share on other sites More sharing options...
08 ORANGE SS-725HP Posted June 5, 2009 Report Share Posted June 5, 2009 And, should I be running 38 front and 36 rear on these 20's? I ran 38 cold front and 36 cold rear in my car when I did a HPDE day at Pocono last year and that pressure worked really well. After a session on track, the pressure was up 6psi both front and back but there was even tire temps right across all 4 tires and I could not even get the tires to screech going thru any turns in the infield!! The 20's with a shorter sidewall I felt would be less forgiving if overinflated than with less air than you would typically run on track with a 17-18" tire but my sessions proved my point with the performance of the car. Link to comment Share on other sites More sharing options...
Alexandros Posted June 5, 2009 Report Share Posted June 5, 2009 :happy feet: Good to know...thanks for the info.... Link to comment Share on other sites More sharing options...
