rnoggle Posted February 28, 2009 Report Share Posted February 28, 2009 I can receive emails, but I can't send. I checked the server addresses and they are correct. Anybody have any ideas what might be the problem? Link to comment Share on other sites More sharing options...
hotrodric Posted February 28, 2009 Report Share Posted February 28, 2009 I use Outlook, but I think the settings are the same. Go to your email account Tools/Email Accounts/View or change email settings, select your account and "Change" Depending on your email provider I expect your outgoing email would be SMTP, confirm you have the correct server address, and correct password. Then select "More Settings" select the "Outgoing Server" tab and check "My outgoing server requires (SMTP) Authentication" and then the box "Use same settings as my incoming mail server". Once you have done this, click the "Test Account Settings" button and see if it works. If not, call your service provider tech line, something is probobly not right in the server address. Good Luck Link to comment Share on other sites More sharing options...
