Chrome FR500
sfadchi
Nope they are 18x10 Rear 18x9 front with the stock tires mounted on them!
I was hoping you would say that. I have been searching for great looking wheels that were 18" and would still fit over the brakes. Where did you buy them? They look super on your car. Thanks again.
Jim
Jim
American Muscle, if you are a member of SVTPerformance.com they give you a discount code.
I am a member of SVTPerformance. Where on the web site can I find the discount code? American Muscle shows the fronts on sale for $187 each and the rears on sale for $210 each. How does that price stack up? Thanks.
Jim
Jim
Jim, that sounds like an awesome price. I say pull that trigger.................I want to see the pics.
Chris
Jim
I found them here for about $100 less. $162 for front and $187 for rear. Never bought from this site before. Should be same wheels?
http://cruizinconceptswholesale.com/products.asp?cat=216
They do not seem to have pure chrome versions but only what they call "black chrome." Pure chrome they seem to have only in 20's.
Jim
Jim
Go into the vendor forum and PM them for the code, I think it saves 6 to 10 percent. As always they have free shipping and no taxes!
A couple of people asked me to post some pictures of my car with the FR500s on them so here they are! The car is lowered with the FRPP springs.
looks fantastic. great choice in wheels. i love these on the gt500. i have only seen a few guys run these so far.
i'm assuming you went with the ones specifically for the 05-09's with 40mm offset/7" backspacing. is that correct?
any need for spacers to clear the front brembo's?
how many turns do you get with the lug nuts? 6, 6.5, 7, 7.5, 8, etc? the reason for this is i may need to run some spacers and want to make sure i still get enough wrap on the studs.
how much further do they stick out compared to the stockers? my calculations say that it should be almost 16mm/0.6" further. is this about right?
how much clearance do you have between the tire and shock cover?
how much clearance do you have between the wheel and the bump stop bracket?
how much clearance do you have between the wheel and the sway bar?
do you think you could add another 1.5"?
sorry for all the questions. i have been considering these replica's or the frpp silver 500's and having them widened to 11.5". the only thing holding me up is the right tire choice for me is not available.
how about some shots from under the car showing the clearance from above the rear fender and from the rear (no angle)?
thanks, brad
Correct
Nope
about 12 or so
just a little more see attached pics, your guess seems about right
1.7 inches
plenty!
plenty, see pictures
1in for sure, 1.5 may be cutting it close, but my car is lowered if that makes a difference I dont know
see pictures
thanks, brad
Jim
Near the bottom of the page they have the 9" and 10" 18's in chrome. Seems like a great price.
http://cruizinconceptswholesale.com/prodde...X9C&cat=216
http://cruizinconceptswholesale.com/prodde...5UPFR50018X10.5
Car looks great.
How do they compare clearance wise /the way they sit in wheel wells compare to stock?
How much do the rims weigh?
Did you use the stock lug nuts?
will the stock center caps fit in the fr500 rim?
thanks in advance
Car looks great.
thanks in advance
Thanks!
Clearance they are fine, I'm running the stock tires right now and if you look at my other pictures in this post you will see that the tires stick out maybe a 1/4 inch. The rim itself is about flush with the fender.
I did use the stock lugs.
The center cap with not fit it, I tried it today.
Car looks great.
thanks in advance
What did you do to put the "SHELBY" letters across the back of the trunk lid? Looks great!
