MMcGuirk Posted February 19, 2009 Report Share Posted February 19, 2009 This past weekend I installed Steeda's billet idler pulleys. Literally took 10 minutes, cost $119 plus freight. The PN is the same for SC and naturally aspirated cars. I have a Whipple, but checked with KB annd Saleen. They will fit these apps. The Steeda pulleys have a bigger, better quality bearing and weight much less then the stock stamped steel FOMOCO ones. They look great and I swear my car runs smoother. I will post pics tomorrow. Link to comment Share on other sites More sharing options...
kahmann Posted February 19, 2009 Report Share Posted February 19, 2009 This past weekend I installed Steeda's billet idler pulleys. Literally took 10 minutes, cost $119 plus freight. The PN is the same for SC and naturally aspirated cars. I have a Whipple, but checked with KB annd Saleen. They will fit these apps. The Steeda pulleys have a bigger, better quality bearing and weight much less then the stock stamped steel FOMOCO ones. They look great and I swear my car runs smoother. I will post pics tomorrow. Can you post the link to the part? The one I found is $209 direct from Steeda. Also, did you do the install yourself or have a shop do it? If shop, how much was the labor? Ken Link to comment Share on other sites More sharing options...
ilmor Posted February 19, 2009 Report Share Posted February 19, 2009 I assume these are the pullies. They do look nice. I look forward to seeing the pics. http://www.steeda.com/products/steeda_two_...ey_kit_s197.php Link to comment Share on other sites More sharing options...
kahmann Posted February 19, 2009 Report Share Posted February 19, 2009 I assume these are the pullies. They do look nice. I look forward to seeing the pics. http://www.steeda.com/products/steeda_two_...ey_kit_s197.php Thanks for the link. +1 on the pics. Link to comment Share on other sites More sharing options...
Michael Morris Posted February 19, 2009 Report Share Posted February 19, 2009 They are going to look good, cant wait to see pics MM Link to comment Share on other sites More sharing options...
awakeinAZ Posted February 19, 2009 Report Share Posted February 19, 2009 They look nice! Link to comment Share on other sites More sharing options...
MMcGuirk Posted February 19, 2009 Author Report Share Posted February 19, 2009 Can you post the link to the part? The one I found is $209 direct from Steeda.Also, did you do the install yourself or have a shop do it? If shop, how much was the labor? Ken Hey Ken I did the install, it was a snap - I used a 1/2" drive breaker bar in the receptacle on the belt tensioner, removed the belt from the alternator, used a 15mm socket to remove the coolant hose support bracket, removed the stock pulleys with a 13mm socket, installed the Steedas with supplied hardware and torqued to 20 lb/ft, re-installed the hose bracket and popped the belt back on. The entire process took 10 minutes. Steeda supplies excellent install instructions. Got the camera out and the battery was dead. I will charge tonight and take some photos to post. Michael Link to comment Share on other sites More sharing options...
pottydr Posted February 20, 2009 Report Share Posted February 20, 2009 I will help Michael out, he sent me his extra set and I installed them in about 15 minutes, I took the belt off of the KB S/C becuase it was easier then the alt, because the alt had a lip on it and was too hard to slip over and I also used loctite on the threads, Rick Link to comment Share on other sites More sharing options...
Dig-It Posted February 20, 2009 Report Share Posted February 20, 2009 That's pretty nice looking. Link to comment Share on other sites More sharing options...
1badsgt Posted February 21, 2009 Report Share Posted February 21, 2009 Just installed a set on my SGT about 2 hours ago. Took about 15 minutes and it looks good. $119 direct from Steeda had them in 4 days. Link to comment Share on other sites More sharing options...
mikesdream Posted March 7, 2009 Report Share Posted March 7, 2009 I will help Michael out, he sent me his extra set and I installed them in about 15 minutes, I took the belt off of the KB S/C becuase it was easier then the alt, because the alt had a lip on it and was too hard to slip over and I also used loctite on the threads, Rick Rick, those look awsome. ? Is there a benefit other than looks for this mod? Is there a performance gain. I try to stay out of the engine bay unless there is a power/efficiency gain. Mike Link to comment Share on other sites More sharing options...
pottydr Posted March 7, 2009 Report Share Posted March 7, 2009 They are good for looks and I think the bearings are better than stock as some people have had them make alot of noise, I do not want to get stuck outta town with a bad pulley, but in my mind they are worth 50 hp, Rick Rick, those look awsome. ? Is there a benefit other than looks for this mod? Is there a performance gain. I try to stay out of the engine bay unless there is a power/efficiency gain. Mike Link to comment Share on other sites More sharing options...
kahmann Posted March 8, 2009 Report Share Posted March 8, 2009 Wow those look awesome! Kind of looks like a couple of revolver barrels sticking out of the engine. I like it. Ken Link to comment Share on other sites More sharing options...
