lrock Posted February 14, 2009 Report Share Posted February 14, 2009 Does anyone have a bad vibration on their SS? I have a crazy vibration when I drive. I thought I might have a flat spot on my tires, but it did not go away after driving. I am going to check the balance. If that is not it, I will have to call Shelby. The vibration seems to come from the front end. My car shakes and vibrates so bad, you can't hold a line. I have never had 20 inch rims, so I first blamed them. Now, something has to be wrong. It is the first thing anyone who drives it notices. Any ideas before I take it in? The steering wheel bounces several degrees back and forth and shakes while driving. The whole car feels unsettled. Thanks.. Lrock 07ss0157 Link to comment Share on other sites More sharing options...
INDYSHELBY Posted February 14, 2009 Report Share Posted February 14, 2009 Ive never had any problems like you have ,very good handling sounds like rim or tire issue. Something really wrong on the front end hope you get it fixed soon Link to comment Share on other sites More sharing options...
Budman340 Posted February 14, 2009 Report Share Posted February 14, 2009 It sounds like a wheel weight may have popped off. Definately have the wheels rebalanced Bud Link to comment Share on other sites More sharing options...
Michael Morris Posted February 14, 2009 Report Share Posted February 14, 2009 It sounds like a wheel weight may have popped off. Definately have the wheels rebalanced Bud He beat me to it!! I know of another SS that had a viberation. He had ALL the wheels rebalanced and the car was fine. These wheels use the taped on weights and they can fall off. MM Link to comment Share on other sites More sharing options...
V1PER Posted February 14, 2009 Report Share Posted February 14, 2009 I had this a couple of weeks ago and from the severity of the vibration you're feeling it's sounds like the same problem I had. The whole car shook and shuddered like I've never felt and the doors felt like they were going to fall off. (mind you that was at 145mph) It turned out to be one of the tyre pressure monitors had come off. If you jack your car up and rotate a wheel you'll find that you might hear it rolling around inside. Do let us know how you get on. Good Luck Link to comment Share on other sites More sharing options...
Joker45 Posted February 14, 2009 Report Share Posted February 14, 2009 It's most likely the wheel weights. I had the same problem and I had to get all 4 tires rebalanced. It was really bad on mine too! at about 80 MPH it felt like the front of the car was about to rip off. Link to comment Share on other sites More sharing options...
JWZ Posted February 14, 2009 Report Share Posted February 14, 2009 Like y'all,had a vibation & noise from left front tire- sounded like tire slap or extreme flat spot. Raised car & rotated tire. Sounded like something was loose inside. Removed tire & wheel & had it broke down. Appears both sensor & bracket were damaged during initial installation & sensor was loose inside tire. Replaced damaged parts & re-balanced. Have yet to drive it, but am confident that problem's corrected. Thanks for the tip! Link to comment Share on other sites More sharing options...
Robert M Keefe Posted February 14, 2009 Report Share Posted February 14, 2009 Like y'all,had a vibation & noise from left front tire- sounded like tire slap or extreme flat spot. Raised car & rotated tire. Sounded like something was loose inside. Removed tire & wheel & had it broke down. Appears both sensor & bracket were damaged during initial installation & sensor was loose inside tire. Replaced damaged parts & re-balanced. Have yet to drive it, but am confident that problem's corrected. Thanks for the tip! I've got a few quality issues with my Snake. However where I live their is still snow on the ground. Will wait another few months till spring. What happened to the QC department?? Link to comment Share on other sites More sharing options...
lrock Posted February 15, 2009 Author Report Share Posted February 15, 2009 Thank you all for the help. I am going to take my car in and have the tires balanced and have the sensors checked. I will post an update when I get it done. Lrock 07SS0157 Link to comment Share on other sites More sharing options...
ShelbyRookie Posted February 15, 2009 Report Share Posted February 15, 2009 I've got a few quality issues with my Snake. However where I live their is still snow on the ground. Will wait another few months till spring.What happened to the QC department?? Where was your car done Robert? I would take it back and get it fixed. Good luck with it. Don Link to comment Share on other sites More sharing options...
JWZ Posted February 15, 2009 Report Share Posted February 15, 2009 Please don't think I'm complaining about the quality of SS package. I'm not. The quality & workmanship are exceptional! The speed sensor is either a case of human error or defective part which was easily & quickly resolved. Thanks Shelby for the well thought out Super Snake package! It's awesome! Also, this Forum is a great place to get good advice. Link to comment Share on other sites More sharing options...
lrock Posted February 18, 2009 Author Report Share Posted February 18, 2009 I took my SS in to have the tires balanced and the computer reflashed (my program did not take all the way and my speedo was off). After Ford worked through the computer flash, they called and said their tire machine would not balance the 20 inch rims. I called a speciality tire store who said they could do it and they would hold a bay for me. All this time a storm was blowing in. My car has never seen rain. Got there and no open bays. Sleet was in the forcast, I took the car home with no resolution to the tire issue. I parked it and minutes later sleet and hail hit where I live. So.... no idea if the tires are out of balance, but I did get it garaged before it got pelted with sleet and hail. I will post after I resched with the tire store. Bud, thanks for the help on the phone with the computer flash. Lrock 07SS0157 Link to comment Share on other sites More sharing options...
lrock Posted March 5, 2009 Author Report Share Posted March 5, 2009 I had the wheels checked today. All 4 out of balance bad. The drive home was like driving a different car. Before it felt unsettled, not it feels glued to the road. Lrock 07SS0157 Link to comment Share on other sites More sharing options...
ShelbyRookie Posted March 5, 2009 Report Share Posted March 5, 2009 Good news lrock!!! Glad it was simple. Don Link to comment Share on other sites More sharing options...
Michael Morris Posted March 5, 2009 Report Share Posted March 5, 2009 Im glad it was that easy!!! Great riding cars when all is well! MM Link to comment Share on other sites More sharing options...
Shelby101 Posted March 5, 2009 Report Share Posted March 5, 2009 Good news who did the balancing? Link to comment Share on other sites More sharing options...
Alexandros Posted March 5, 2009 Report Share Posted March 5, 2009 :happy feet: Good news..... :happy feet: Link to comment Share on other sites More sharing options...
lrock Posted March 6, 2009 Author Report Share Posted March 6, 2009 I was very happy to find out that it was just a balance issue. I feared I might have a rim out of true. I had everything check, it was ony the balance. My shop thought the tires had been static balanced. They put them on a high speed machine. The tire I watched was 1.90 something out of balance on the machine. The tech said that was bad and all had been that way. It drives like a different car. So happy now... BTW, the shop was Dunlap and Kyle Tires. Lrock 07SS0157 Link to comment Share on other sites More sharing options...
jsdogs1 Posted March 16, 2009 Report Share Posted March 16, 2009 I had a bad vibration in my SS. Only put 475 mile on it since the conversion. End up being the rear was not installed properly and the ring and pinion went bad. Had to have the car towed into the local dealer. Had gear oil sprayed all over the back end. Shelby sent out the parts and had the dealer's mechanic install the parts correctly. Then as i was driving it home after the repair I smelled burning oil. Seems the oil sensor was not tightened upon installing the dash gauges and it was leaking on to the tail pipe. All in all I love the car but have lost confidence in the mod shop. And no I don't race the car. in fact I only take it out when the weather is nice. I only have a total of 1659 miles on it and have had it since Sept. 07 Link to comment Share on other sites More sharing options...
lrock Posted March 18, 2009 Author Report Share Posted March 18, 2009 jsdog1. what shop did your conversion? Mine was done at SAI in Vegas. Lrock 07SS0157 Link to comment Share on other sites More sharing options...
jsdogs1 Posted March 18, 2009 Report Share Posted March 18, 2009 jsdog1. what shop did your conversion? Mine was done at SAI in Vegas. Lrock 07SS0157 same Link to comment Share on other sites More sharing options...
