COBRA SCOTTY Posted February 4, 2009 Report Share Posted February 4, 2009 I WANTED TO KNOW IF ANYBODY CAN TELL ME IF THE GT500 WHEELS CAN BE USED WITH THE TIRES OF MY STOCK SHELBY GT AND WILL THEY BOLT UP TO MY 08 SHELBY GT. WILL THE TIRES FIT ON THE GT500 RIMS OR IS THERE A BETTER TIRE SIZE AND BRAND TO USE. PLEASE PROVIDE FRONT AND REAR TIRE SIZES WOULD BE HELPFUL. I AM PLANNING ON WIDENING THE REAR WHEELS. THANKS FOR THE HELP. SCOTTY Link to comment Share on other sites More sharing options...
pottydr Posted February 4, 2009 Report Share Posted February 4, 2009 GT500 Tire Size (front): P255/45ZR18 Z Tire Size (rear): P285/40ZR18 Z Shelby GT Tire Size (front): P235/50ZR18 Tire Size (rear): P235/50ZR18 So I think they will not work Link to comment Share on other sites More sharing options...
tispco Posted February 4, 2009 Report Share Posted February 4, 2009 The GT500 rims will bolt right up to your SGT, but your SGT tires are not wide enough for the GT500 rims. The max rim width for a P235/50/18 is 8.5" and the GT500 rim is 9.5" wide. If you get new tires for the GT500 rims, they will work great. Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted February 4, 2009 Author Report Share Posted February 4, 2009 GT500Tire Size (front): P255/45ZR18 Z Tire Size (rear): P285/40ZR18 Z Shelby GT Tire Size (front): P235/50ZR18 Tire Size (rear): P235/50ZR18 So I think they will not work WILL THE GT500 RIMS BOLT RIGHT UP TO THE SHELBY GT AXLE OR IS THE LUG PATTERN OR OFFSET GOING TO MAKE THEM STICK OUT OF THE WHEEL WELLS. IT APPEARS THAT SINCE THE TIRES ARE 18 INCH I SHOULD BE ABLE TO TAKE THEM OFF THE STOCK SHELBY GT WHEELS AND HAVE THEM MOUNTED TO THE GT500 RIMS. SOME MORE HELP HERE PLEASE. ANYBODY THANKS, SCOTTY Link to comment Share on other sites More sharing options...
07SGT1638 Posted February 4, 2009 Report Share Posted February 4, 2009 WILL THE GT500 RIMS BOLT RIGHT UP TO THE SHELBY GT AXLE OR IS THE LUG PATTERN OR OFFSET GOING TO MAKE THEM STICK OUT OF THE WHEEL WELLS. IT APPEARS THAT SINCE THE TIRES ARE 18 INCH I SHOULD BE ABLE TO TAKE THEM OFF THE STOCK SHELBY GT WHEELS AND HAVE THEM MOUNTED TO THE GT500 RIMS. SOME MORE HELP HERE PLEASE. ANYBODY THANKS, SCOTTY The GT500 wheels bolt right up and do a nice job filling the wheel well. They do not stick out. But as said above, you need to buy new tires. Stock SGT wheels are 18x8.5 the GT500 wheels are 18x9.5. The GT500 rims are too wide for the stock SGT tires. On the plus side if you do this (GT500 wheels) you can finally put upgraded brakes under there, because you get more offset room for the caliper. When I did this, I went with 275/40ZR18 tires all around. The 275/40 is sized for 9.5 inch wide wheels. Todd CSM1638 Link to comment Share on other sites More sharing options...
GT500-07 Posted February 4, 2009 Report Share Posted February 4, 2009 they fit great, Link to comment Share on other sites More sharing options...
motorjock205 Posted February 4, 2009 Report Share Posted February 4, 2009 The GT500 wheels fit just fine and you can even use the same lug nuts that came on the Shelby GT...they are the same ones that the GT500 uses...The tires are the problem...the standard SGT tire, 235/18 is made to fit on a max width wheel of 8.5 inches and the GT500 wheels are 9.5 inches wide. I bought a set of GT500 wheels that had the original tires mounted on them, and they fit the SGT just fine. So to answer your question, wheels are fine, tires while still being 18" diameter, they are not wide enough for the wheels...you'll need new tires too. Pottydr has the correct tire sizes above for the GT500 wheels. One more thing to consider is that with the lowered suspension of the SGT, they did NOT take into account the need for an adjustable pan hard bar, and I would suggest getting one of those as you will notice that the rear end is shifted to the left just a little bit when you go with wider wheels and tires. The adjustable pan hard bar will re-center the rear end in the wheel wells and make it look and handle better. Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted February 4, 2009 Author Report Share Posted February 4, 2009 Thanks guys for the awesome input. All i need to due is buy me some gt500 rims and tires. LWR CONTROL ARMS UPPER THIRD LINK AND ADJUSTIBLE PANHARD BAR. THANKS AGAIN !!!!! SCOTTY :happy feet: :happy feet: :happy feet: Link to comment Share on other sites More sharing options...
James Hill Posted February 16, 2009 Report Share Posted February 16, 2009 they fit great, What about the TPMS? I am looking to aquire a set of GT500 wheels for my 07GT. The seller says they have the original TPMS still inside the tires as they have never been off the wheels. Did you have to buy one of the "learning" tools, or will the systems be compatable with my GT. Link to comment Share on other sites More sharing options...
tispco Posted February 16, 2009 Report Share Posted February 16, 2009 The sensors are the same on the GT and GT500. Whenever you move sensors or replace sensors, you need to train them to the new car. You can buy the tool from Ford or have the dealer do it. Link to comment Share on other sites More sharing options...
James Hill Posted February 16, 2009 Report Share Posted February 16, 2009 If they are the same, would it still need to be done? Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted February 16, 2009 Author Report Share Posted February 16, 2009 If they are the same, would it still need to be done? YES YOU WILL STILL NEED TO HAVE THEM DONE. SCOTTY Link to comment Share on other sites More sharing options...
James Hill Posted February 17, 2009 Report Share Posted February 17, 2009 Thanks for your help. IMO, thats the width of wheel that should have been put on at SAI. Link to comment Share on other sites More sharing options...
ShelbyPilot Posted February 17, 2009 Report Share Posted February 17, 2009 The stock Shelby GT wheels came from Ford not SAI. Link to comment Share on other sites More sharing options...
