kahmann Posted January 29, 2009 Report Share Posted January 29, 2009 I installed a Moroso aluminum coolant expansion tank last week. Here's what it looks like out of the box. Ken Link to comment Share on other sites More sharing options...
kahmann Posted January 29, 2009 Author Report Share Posted January 29, 2009 Photo 1 - Remove small clamp and hose at top of original tank. Remove 2 bolts at front of tank. Photo 2 - Using channel locks, remove large clamp and hose from bottom of original tank. Before doing this, I pulled the tank (still connected to the bottom hose) as far as I could and held it over a clean bucket. This way, when I was done with the swap, I could re-use my coolant. Photo 3 - Keep two hoses about same height, or the lower hose will start dumping coolant like crazy. Link to comment Share on other sites More sharing options...
kahmann Posted January 29, 2009 Author Report Share Posted January 29, 2009 Photo 1 - I used this opportunity to clean the areas covered by the tank, since there was a lot of dirt built up. Photo 2 - Again, using channel locks, connect the big clamp and hose to the bottom of the new tank. Photo 3 - Do yourself a favor and while installing the 2 bolts to the front of the new tank, don't drop one down this hole. Photo 4 - If you do, you'll be needing one of these. Link to comment Share on other sites More sharing options...
WildAzCat Posted January 29, 2009 Report Share Posted January 29, 2009 Nice looking tank. What is the advantage over the stock tank? Is this a cosmetic or performance part? I've seen these on other stangs and wondered. Thanks... Link to comment Share on other sites More sharing options...
kahmann Posted January 29, 2009 Author Report Share Posted January 29, 2009 Photo 1 - Connect the small clamp and hose at the top of the new tank. Then, pour the coolant from the clean bucket through a funnel into the new tank. Photo 2 & 3 - Finished product. -Ken Link to comment Share on other sites More sharing options...
kahmann Posted January 29, 2009 Author Report Share Posted January 29, 2009 As far as I know, it's simply a cosmetic upgrade. I really like the look of it, But I couldn't stand looking at the stock, bulbous, black plastic tank. This thing cleans up the front of the engine bay pretty nicely IMO. If you buy one, MMR has the best price that I could find FYI. Ken Link to comment Share on other sites More sharing options...
WildAzCat Posted January 29, 2009 Report Share Posted January 29, 2009 It'd does look nice and you made it look easy to install. Is 155.99 a good price? Like I needed to something else for the SGT... Grrr Link to comment Share on other sites More sharing options...
WildAzCat Posted January 29, 2009 Report Share Posted January 29, 2009 I found this description... Direct bolt-in replacement for stock 2-piece plastic tanks. Fabricated aluminum for strength, factory tanks fail after repeated high heat situations such as drag or road racing. This Aluminum tank can be polished, chromed, powder coated or left as is for a race look. Uses factory stock vented cap, bleeds pressure like the factory intended. Hay, it's hot here in AZ.... purchase justified! Link to comment Share on other sites More sharing options...
Shelby-Don Posted January 29, 2009 Report Share Posted January 29, 2009 Can you post a link to the site and item you installed Link to comment Share on other sites More sharing options...
kahmann Posted January 29, 2009 Author Report Share Posted January 29, 2009 Here's the link to the MMR page. The tank is 2nd from the top. http://www.modularmustangracing.com/prod_05.htm $155 is definitely the best price I've heard. It's $170 from MMR. I paid even MORE than that from Summit! <_< Ken Link to comment Share on other sites More sharing options...
Bunky Posted January 30, 2009 Report Share Posted January 30, 2009 ...now you guys got me lookin is this it as well (3rd down) $139.99 ? http://www.rpmoutlet.com/07cool.htm anyone try the power steering reservoir ? Link to comment Share on other sites More sharing options...
WildAzCat Posted January 30, 2009 Report Share Posted January 30, 2009 Here is where I found it for 155.99 http://www.shop.speedunlimited.com/Shop/Co...id/0/rid/126429 Link to comment Share on other sites More sharing options...
WildAzCat Posted January 30, 2009 Report Share Posted January 30, 2009 I LIKE THE POWER STEERING RESERVOIR TANK TOO... Link to comment Share on other sites More sharing options...
kahmann Posted January 30, 2009 Author Report Share Posted January 30, 2009 Yeah man that's it, 3rd one down. Great price. I'm definitely getting this power steering fluid reservoir on order asap. Ken Link to comment Share on other sites More sharing options...
stormeaston Posted February 2, 2009 Report Share Posted February 2, 2009 So, with the Morso tanks you can use your old caps? I installed a Canton and FU because you have to use a regular radiator cap, not your Shelby ones. Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted February 3, 2009 Report Share Posted February 3, 2009 Anyone consider anodized black? Will Moroso do that? I like the overflow and power steering tanks. Looks nice Ken. Your vista blue SGT looks real sharp. Link to comment Share on other sites More sharing options...
kahmann Posted February 3, 2009 Author Report Share Posted February 3, 2009 So, with the Morso tanks you can use your old caps? I installed a Canton and FU because you have to use a regular radiator cap, not your Shelby ones. The Shelby caps work fine with these tanks. I've got the PS reservoir on order. I'll let you know if there's a problem with the cap. Ken Link to comment Share on other sites More sharing options...
kahmann Posted February 3, 2009 Author Report Share Posted February 3, 2009 Anyone consider anodized black? Will Moroso do that? I like the overflow and power steering tanks. Looks nice Ken. Your vista blue SGT looks real sharp. I haven't seen any black tanks, but I'm sure you could have them coated pretty easily. Black aluminum tanks would look amazing under the hood of your Hertz, IMO. And thanks a lot for the compliment! Ken Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted February 3, 2009 Report Share Posted February 3, 2009 I think someone mentioned elsewhere that the Moroso tank fixes an issue with the stock tank, mainly that the stock tank/cap leaks and or fails when used with a supercharger. I believe it only occurs with the Paxton charger. Sam AKA: Link to comment Share on other sites More sharing options...
kahmann Posted February 3, 2009 Author Report Share Posted February 3, 2009 Thanks for the info. I'm planning on getting the Paxton installed, once they get the EO for the 08's. So, I guess this mod ISN'T a complete waste of money! Ken Link to comment Share on other sites More sharing options...
kahmann Posted February 4, 2009 Author Report Share Posted February 4, 2009 So, with the Morso tanks you can use your old caps? I installed a Canton and FU because you have to use a regular radiator cap, not your Shelby ones. I got the Moroso power steering fluid reservoir in the mail last night. It does require me to use their cap. The Shelby cap won't fit. FYI <_< Ken Link to comment Share on other sites More sharing options...
WildAzCat Posted February 4, 2009 Report Share Posted February 4, 2009 :angry2: That really suxs. Thanks for letting me know before I bought one. Do you think you can custom fit the Shelby cap? Link to comment Share on other sites More sharing options...
kahmann Posted February 5, 2009 Author Report Share Posted February 5, 2009 I just finished the install of the power steering fluid reservoir. The hoses on this tank were much more difficult to get loose compared to those on the coolant tank. I can't really think of any way to modify the tank so that my Shelby cap will fit it. The Moroso cap is a threaded style cap, whereas the Shelby cap is a 1/2 twist/lock style cap. Kind of a bummer, but the Moroso cap doesn't look too terrible. Ken Link to comment Share on other sites More sharing options...
kahmann Posted February 5, 2009 Author Report Share Posted February 5, 2009 ... Link to comment Share on other sites More sharing options...
WildAzCat Posted February 5, 2009 Report Share Posted February 5, 2009 That really completes the look of the two tanks. You say you're done with under hood stuff... you're in denial. :lol2: Admitting to your mod bug is the first step to recovery. :D Link to comment Share on other sites More sharing options...
Guest hfrosso Posted February 5, 2009 Report Share Posted February 5, 2009 I installed a Moroso aluminum coolant expansion tank last week. Here's what it looks like out of the box. Ken thank's a lot for the info ! it just makes that much ease for me to install looking at your "instructions" since i dont have a lot of skills when it comes to do that kind of stuff!! i'm going to by the cooling tank and the power stering, nice looking parts!! :happy feet: Link to comment Share on other sites More sharing options...
kahmann Posted February 5, 2009 Author Report Share Posted February 5, 2009 That really completes the look of the two tanks. You say you're done with under hood stuff... you're in denial. :lol2: Admitting to your mod bug is the first step to recovery. :D LOL no joke! I thought that I might have had you fooled. But the FRPP cam covers just arrived, so I guess I AM in denial. Ken Link to comment Share on other sites More sharing options...
kahmann Posted February 5, 2009 Author Report Share Posted February 5, 2009 thank's a lot for the info ! it just makes that much ease for me to install looking at your "instructions"since i dont have a lot of skills when it comes to do that kind of stuff!! i'm going to by the cooling tank and the power stering, nice looking parts!! :happy feet: Very cool, I'm sure you'll do just fine. If you have any questions, let me know. I'll be more than happy to help you out. Don't forget to post some pics of your engine bay! Ken Link to comment Share on other sites More sharing options...
Chill Posted February 6, 2009 Report Share Posted February 6, 2009 Ken, I'm interested to know how easy (or difficult) the cam cover replacement is. I love them but haven't messed under the hood for many years. Let us know how is goes. Chuck Link to comment Share on other sites More sharing options...
Guest hfrosso Posted February 7, 2009 Report Share Posted February 7, 2009 Very cool, I'm sure you'll do just fine. If you have any questions, let me know. I'll be more than happy to help you out.Don't forget to post some pics of your engine bay! Ken I will ,just waiting on a bunch of parts,and I'm taking the car to tasca ford this tuesday 10 to get the stripes/hood scoop fixed,some minor body work,going to have installed the start/stop button and 3:73 gears then i will post some pictures!!! By the way I just founded these nice looking radiator cover that will match with the moroso cooling tank and everithing alum. under the hood I just bought one you may want to take a look they're web site is www.mossmuscle.com. Link to comment Share on other sites More sharing options...
