silver08elly Posted February 5, 2009 Report Share Posted February 5, 2009 Lucky a$$ lol Link to comment Share on other sites More sharing options...
07SGT4578 Posted February 5, 2009 Report Share Posted February 5, 2009 got my airbag cover in the mail yesterday. :happy feet: :happy feet: chris Link to comment Share on other sites More sharing options...
Grabber Posted February 14, 2009 Author Report Share Posted February 14, 2009 Make sure you protect your airbag cover when you send it in. You can also put your name and instructions on it. Then wrap it in some thin foam padding. 1st layer. 2nd layer Then wrap it in some bubble wrap. Then put it in a box that will not allow it to slide around. This will assure that your airbag travels save and does not get damaged in the mail. Link to comment Share on other sites More sharing options...
Grabber Posted February 14, 2009 Author Report Share Posted February 14, 2009 Someone was asking me what the back of the airbag cover looks like. It has a bunch of plastic slots in it that hold the airbag in it. All you have to do is pull the plastic slots away from the airbag tabs and the airbag comes out. Here is what the back looks like after you pull the airbag out of it. It is also a good pic that sows the 16 clips / tabs that hold the airbag into the dash that you have to release in order to remove the airbag cover. Link to comment Share on other sites More sharing options...
silver08elly Posted February 14, 2009 Report Share Posted February 14, 2009 Grabber you are lke the guru of knowledge around here. I it wasnt for you id have no info ever...wish i had documented mine like this so i could help more. Link to comment Share on other sites More sharing options...
Grabber Posted April 17, 2009 Author Report Share Posted April 17, 2009 I Installed my signed airbag cover. It was very easy to take out. No risk to scratching the dash. Just take your time like I did. I think it took me an hour, but I was not in a hurry. In fact I went to a movie with my family after I unhooked the battery and unplugged the airbag. Here are the steps. 1. Un hook the battery. I did both terminals. 2. Remove the glove box cover. 4 screws on the bottom and push the 2 tabs inwards and it comes out. 3. Reach in and unplug the airbag. 4. pull out the 2 screws that hold the airbag to the metal frame. 5. push the 6 bottom clips inwards. 6. Then do the sides. 7. The top is hard to reach, so you push the top drivers side 2 clips inwards and then do the others the best you can. 8. From the outside, slowly pull on the airbag cover from the drivers side first working your way to the passenger side. It comes right out very easly that way. I did not have to force it all. Just slow pressure. 9. Then set the airbag cover on a towell so you don't scratch the front. Remove the airbag unit and put it in the other cover. 10. The cover pops right back in the dash very easy. It just clicks right in. 11. Put the screws back in and plug the bag back in, put the glove box door on and connect the battery. Mine went in with out a flaw, and the old one came out flawless as well. These 2 PDF files will also help you with the installation of this mod. Airbag_20panel_20removal_1_.pdfAirbag_20Trim_20Cover_20removal_1_.pdf Bump for the new guys. Link to comment Share on other sites More sharing options...
Mustang_Scotty Posted April 18, 2009 Report Share Posted April 18, 2009 I Installed mine today. But I never got a certificate of auth or a letter????? Link to comment Share on other sites More sharing options...
Alexandros Posted April 18, 2009 Report Share Posted April 18, 2009 :happy feet: Link to comment Share on other sites More sharing options...
Mustang_Scotty Posted April 18, 2009 Report Share Posted April 18, 2009 I did get the letter but no certificate card. I Installed mine today. But I never got a certificate of auth or a letter????? Link to comment Share on other sites More sharing options...
XLR8 Posted April 24, 2009 Report Share Posted April 24, 2009 Got mine back in about 10 days! :happy feet: Got Jack Roush to sign my visor at Roush Days in Manchester, OH. Link to comment Share on other sites More sharing options...
Grabber Posted June 16, 2009 Author Report Share Posted June 16, 2009 Very cool. Link to comment Share on other sites More sharing options...
Alexandros Posted June 16, 2009 Report Share Posted June 16, 2009 :happy feet: Nice.... Link to comment Share on other sites More sharing options...
Grabber Posted December 19, 2009 Author Report Share Posted December 19, 2009 Bump for the new guys. Link to comment Share on other sites More sharing options...
kahmann Posted December 20, 2009 Report Share Posted December 20, 2009 What's the trick to getting the airbag itself out of the original cover? I've got it out, but can't get the module detached from all those little loops. Link to comment Share on other sites More sharing options...
Grabber Posted December 20, 2009 Author Report Share Posted December 20, 2009 What's the trick to getting the airbag itself out of the original cover? I've got it out, but can't get the module detached from all those little loops. I just did another install for a friend recently and it's kinda fresh in my mind still. The trick is to roll the airbag with in the cover. When you do this it will come loose from the tabs very easily. Just give the airbag a little trist with in. Link to comment Share on other sites More sharing options...
Grabber Posted December 20, 2009 Author Report Share Posted December 20, 2009 I cant remember which way to roll the module, but once you do it....it will come out. Link to comment Share on other sites More sharing options...
kahmann Posted December 20, 2009 Report Share Posted December 20, 2009 Thanks Rob for the quick help. You were right, it twists right out. Ken Link to comment Share on other sites More sharing options...
Grabber Posted December 20, 2009 Author Report Share Posted December 20, 2009 Thanks Rob for the quick help. You were right, it twists right out. Ken I'm glad that helped. We can add this info to the installation process now. I'm not sure why I did not include it in the instructions that I posted. Link to comment Share on other sites More sharing options...
kahmann Posted December 20, 2009 Report Share Posted December 20, 2009 Your guide was perfect otherwise. I wouldn't have attempted it without these clear instructions. Thanks again man! Ken Link to comment Share on other sites More sharing options...
Grabber Posted September 11, 2010 Author Report Share Posted September 11, 2010 Bump for a friend Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted September 12, 2010 Report Share Posted September 12, 2010 Best mod possible. Very nice signature Link to comment Share on other sites More sharing options...
SGT0225 Posted November 9, 2010 Report Share Posted November 9, 2010 Best mod possible. Very nice signature BUMP for new people. Mine is in and looks awsome. :happy feet: Link to comment Share on other sites More sharing options...
Grabber Posted November 10, 2010 Author Report Share Posted November 10, 2010 BUMP for new people. Mine is in and looks awsome. No Pic's Link to comment Share on other sites More sharing options...
jrcjr65 Posted February 1, 2011 Report Share Posted February 1, 2011 Great info. I'm definately doing this. Link to comment Share on other sites More sharing options...
stg Posted March 30, 2011 Report Share Posted March 30, 2011 can you tell me,,, if you have time ,, i would like to get this done,,,,,, cannot fine any info on hear on how to get started thks T/ Link to comment Share on other sites More sharing options...
stg Posted March 30, 2011 Report Share Posted March 30, 2011 Sorry about that got info from Google Thks T/ Link to comment Share on other sites More sharing options...
stillmy428 Posted August 5, 2011 Report Share Posted August 5, 2011 Grabber, He must have signed yours along with mine.Only 8 days till it showed up,UPS guy wouldn't leave till i opened it.Only toke me about 35 min. to install,Came out a lot easier than i tought. Link to comment Share on other sites More sharing options...
IA Shelby Posted August 7, 2011 Report Share Posted August 7, 2011 Grabber, He must have signed yours along with mine.Only 8 days till it showed up,UPS guy wouldn't leave till i opened it.Only toke me about 35 min. to install,Came out a lot easier than i tought. I sent mine in 3-4 weeks ago and has not arrived yet. I sure hope it comes soon. I am more excited about this "mod" than the CR heat exchanger, shifter, ceramic brake pads & Shelby light bar that are sitting in my garage awaiting installation. Link to comment Share on other sites More sharing options...
Grabber Posted April 2, 2012 Author Report Share Posted April 2, 2012 My signed Carroll Shelby Airbag Cover has arrived today in record time. 7 days total from the day I shipped it to the day I have it in my hot little hands. :happy feet: Tracking results as of Jan 13, 2009 1:48 PM CST Ship date Jan 12, 2009 Destination Gardena, CA Delivery date Jan 13, 2009 9:50 AM Signed for by SSMITH Service type Ground-Domestic Here's the Part number for the GT500 airbag in case anyone wants to order this mod. The airbag cover is $150 bucks. Here's what came in my package today. Proof that Carroll Shelby signed it. A letter and a invoice comes with it too. Tax right off going to a good cause. Here's a photo with the plastic off the bottom front of the airbag cover. Carroll di a very nice job signing it. Thank you Carroll !! Here's the instructions link if anyone else wants to send something in to have it signed http://www.cscf.org/...g_autograph.php This piece sure means allot to me. Wow. Sad that CS is not doing well. Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted April 2, 2012 Report Share Posted April 2, 2012 This piece sure means allot to me. Wow. Sad that CS is not doing well. My signed banner with the 1966 & 2006 GT-H was signed on January 13, 2009 and certificate is # 11621. Must have been signed after your airbag cover. Link to comment Share on other sites More sharing options...
