TSB for tranny??
All TSB's
Technical Service Bulletins
2008 MUSTANG - US (English)
The Technical Service Bulletins (TSB's) listed here may NOT apply to the vehicle you are working on. You MUST run OASIS with a specific VIN and Symptom Code to determine if it applies. If OASIS does not return the TSB, then it does NOT apply.
08-26-7
WATER LEAK - FRONT FLOOR AREA
08-24-10
A-PILLAR RATTLE NOISE
08-23-4
SHUDDER ON ACCEL - POSSIBLE WRONG TRANS CROSSMEMBER ASSEMBLY INSTALLED (EXCLUDES GT 500)
08-21-7
POWER WINDOW FEATURE - BOUNCE BACK DIAGNOSTICS
08-21-6
AXLE WHINE
08-20-2
DOOR MOUNTED SUBWOOFER - STATIC, CRACKLE, POP OR DISTORTED SOUND - BUILT BEFORE 7/7/2008
08-17-3
CONVERTIBLE - REAR QUARTER GLASS - TORN/SEPARATING QUARTER GLASS DIVISION BAR
08-16-4
SHELBY GT500 - CLUTCH DRAG
08-12-9
INOPERATIVE RKE TRANSMITTER (KEY FOB) - DISCHARGED KEY FOB BATTERY
08-9-6
4.6L WITH TR3650 MANUAL TRANSMISSION - CLASH OR RASPY FEEL - SHIFTING INTO 2ND AND/OR 3RD GEAR
08-9-2
UN-COMMANDED PERIMETER LIGHTING
08-7-6
SPARK PLUG REMOVAL INSTRUCTIONS - 4.6L 3V/5.4L 3V/6.8L 3V
08-5-1
SATELLITE DIGITAL AUDIO RECEIVER SYSTEM (SDARS), MAY NOT SEEK ALL SIRIUS SATELLITE RADIO CHANNELS
08-4-2
COLD START FEAD HOOT - WHISTLE NOISE / BUILT BEFORE 1/28/2008
08-3-4
RATTLE/BUZZ/VIBRATION - TRANSMISSION CROSS-MEMBER EXHAUST MOUNT - BUILT BEFORE 12/3/2007
08-2-10
4.6L MANUAL TRANSMISSION - SEPARATOR PLATE BUZZ - BUILT BEFORE 12/13/2007
08-2-4
MANUAL TRANSMISSION SHIFTER BOOT NOISE - BUILT BEFORE 12/6/2007
07-23-10
CLUTCH PEDAL VERY LOW ENGAGEMENT EFFORT - 4.0L - BUILT FROM 8/20/2007 TO 09/06/2007
07-17-8
CONVERTIBLE SYSTEM CONCERNS
07-17-6
BUZZ/RATTLE FROM DOOR PANEL WHEN OPERATING AUDIO SYSTEM - VEHICLES BUILT BEFORE 8/2/2007
07-16-7
EXTERIOR DOOR HANDLE NOT FLUSH IN THE CLOSED POSITION
07-5-13
DISCHARGED BATTERIES - VEHICLES IN STORAGE/LIMITED USAGE
I only have 3900 miles on my 08 SGT Conv, and a few times when just pulling out of my neighborhood, the first time I shift into 3rd from 2nd, the gears have clashed 3 times. This would explain why. Thanks for the info, looks like I need to make a trip to the dealership for this TSB next week if the weather is decent here in Atlanta...right now its just 17 degrees!!!
Thanks for the info Grabber!
Andy
That describes the problem I had exactly, Andy. Only grinds going into 3rd, mainly when cold, and usually only once. Next trip through the gears is smooth. My car's still in the shop. They fixed the TSB, but now it is hard to get into 1st and Reverse, so they're taking the tranny back out again. It's been over 2 weeks so far... Odd, it's beautiful and 60 in Denver.
