Project GT500 800hp
HP Solutions
Finally got the Kenne Bell 2.8H for the Shelby. Pretty impressive kit as well as numbers. Also put a one piece aluminum driveshaft and gained 14whp from that. Here are some pics of the install. I still have to cut the hood, but I am waiting for the smaller pulley to get here today as we only made 14-15 psi with the 3.5 inch pulley. Hopefully once the 3.25 gets here it will be at 18psi so we can be in the 750 range on pump gas. The car made 712rwhp on the dynojet on 15psi, compared to the stock 436rwhp.
Stock vs 2.8H
N/A Power
Shane giving me a hand and actually working?
Whipple MonoBlade vs KB Twin 75mm
Blower on
The rest on.
The Mammoth edition
Driveshaft installed.
Stock vs KB at 15psi
No offense but you should list that you also have a lower on it too.
No offense taken (don't know why there would be :D ), the car has a 4lb lower.
Nice, did you do the work yourself? How long did the install take?
Yes I did the work here at the shop in Hampton, VA.
Absolutely Sick :drool:
Thank you!
Nice numbers.
What were the numbers with STD and SAE corrections? It states uncorrected on the Dyno sheet.
:shift:
When it made 735 at 16psi it made 722 corrected. I usually do not like to use the correction factor for boosted cars since the program usually over compensates. We have a Dynojet here at the shop. So what it was actually making that day was 735rwhp. :)
Very nice!! I am about to put the KB on mine as well. How long was the install, and let us know how the drivability is once you
put some miles on her.
Taking my time with trimming the hood and dyno time was about 10 hours, much longer than advertised but I did a couple things differently like running the wiring through the car, not under it.
THanks
HP Solutions
757-766-3663
Thank you!
THanks
HP Solutions
757-766-3663
good looking rig. I love that set up on mine :)
