2007 - 2009 Mustang TSB list
Grabber
Here are 3 lists of TSB's. One list for each model year. 2007, 2008 and 2009.
Updated: Oct. 30, 2008. The TSB number is Listed. Take that number to your dealer if you have a concern with the issue listed in the topic title. The most recent TSB is listed first in each model year.
EDIT: If you go to Google and type in TSB (then the TSB number) and click enter....the TSB should come up.
http://www.google.com/
EDIT: 3/12/2010 for 2007 - 2009 current TSB's (all up to date)
Technical Service Bulletins
2007 MUSTANG - US (English)
The Technical Service Bulletins (TSB's) listed here may NOT apply to the vehicle you are working on. You MUST run OASIS with a specific VIN and Symptom Code to determine if it applies. If OASIS does not return the TSB, then it does NOT apply.
10-5-7
4.0L - BUZZ NOISE - UPPER ENGINE
10-4-13
CONVERTIBLE TOP - HEADLINER PULLED OUT FROM NUMBER 1 BOW
10-3-8
SHELBY GT500 - CLUTCH DRAG
10-3-7
REAR DRIVE AXLE VENT - OIL LEAK
10-2-3
HESITATION/LOSS OF RPM/LOW IDLE RPM/DRIVEABILITY CONCERNS
09-24-16
GRUNT/CREAK/SQUEAK/CHIRP NOISE FROM THE LOWER CONTROL ARM BUSHING OVER BUMPS - BUILT ON OR BEFORE 8/3/2009
09-20-4
AXLE WHINE
09-19-17
4.6L WITH TR3650 MANUAL TRANSMISSION - CLASH OR RASPY FEEL - SHIFTING INTO 2ND AND/OR 3RD GEAR
09-18-16
4.6L MANUAL TRANSMISSION - SEPARATOR PLATE BUZZ - BUILT BEFORE 4/5/2009
09-14-8
LUGGAGE COMPARTMENT LID SOLENOID STUCK OPEN
09-12-12
5R55S/5R55N/5R55W TRANSMISSIONS - SHIFT CONCERNS, LOSS OF 2ND, 3RD AND 5TH GEAR, INCORRECT RATIO DTC'S - PROCEDURE TO INSPECT AND REPAIR SERVO PIN BORE WEAR
09-9-7
COLD START FEAD HOOT - WHISTLE NOISE
09-8-7
AIR BAG WARNING LAMP ON - DTC 2295 IN RESTRAINTS CONTROL MODULE
08-26-7
WATER LEAK - FRONT FLOOR AREA
08-24-10
A-PILLAR RATTLE NOISE
08-23-4
SHUDDER ON ACCEL - POSSIBLE WRONG TRANS CROSSMEMBER ASSEMBLY INSTALLED (EXCLUDES GT 500)
08-21-7
POWER WINDOW FEATURE - BOUNCE BACK DIAGNOSTICS
08-17-3
CONVERTIBLE - REAR QUARTER GLASS - TORN/SEPARATING QUARTER GLASS DIVISION BAR
08-9-2
UN-COMMANDED PERIMETER LIGHTING
08-8-5
4.0L WITH MANUAL TRANSMISSION - 4TH GEAR RATTLE/KNOCK NOISE ON ACCELERATION - 1800-2200 RPM APPROXIMATELY 45 MPH (72 KM/H)
08-7-6
SPARK PLUG REMOVAL INSTRUCTIONS - 4.6L 3V/5.4L 3V/6.8L 3V
08-5-10
8.8 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS
08-3-4
RATTLE/BUZZ/VIBRATION - TRANSMISSION CROSS-MEMBER EXHAUST MOUNT - BUILT BEFORE 12/3/2007
08-2-4
MANUAL TRANSMISSION SHIFTER BOOT NOISE - BUILT BEFORE 12/6/2007
07-21-12
FUEL FILL SLOW, OR DIFFICULT TO FILL
07-20-3
CONVERTIBLE TOP - TENSION CABLE NOISE - BUILT BEFORE 12/1/2006
07-19-1
CONVERTIBLE TOP WEAR - BUILT BEFORE 10/11/2006
07-18-2
4.0L AND 4.6L COUPE - FRONT END NOISE OVER BUMPS
07-17-8
CONVERTIBLE SYSTEM CONCERNS
07-17-6
BUZZ/RATTLE FROM DOOR PANEL WHEN OPERATING AUDIO SYSTEM - VEHICLES BUILT BEFORE 8/2/2007
07-16-7
EXTERIOR DOOR HANDLE NOT FLUSH IN THE CLOSED POSITION
07-12-3
RCM FAULT REPORTING USING DTCS AND BIT-MAPPED PARAMETER IDENTIFIERS (PIDS) - SERVICE TIPS
07-6-7
SPOILER/DECK LID CONTACT
07-5-13
DISCHARGED BATTERIES - VEHICLES IN STORAGE/LIMITED USAGE
07-5-8
BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS
07-4-3
LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE
07-1-7
MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS
06-26-2
CARPET REMOVE AND REPLACE
06-26-1
MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS
06-25-15
ALUMINUM BODY PANELS - CORROSION - SERVICE TIP
06-25-3
PIONEER NAVIGATION RADIO - SEEK FUNCTION INOPERATIVE - SERVICE TIP
06-21-19
HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY)
06-21-7
AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES
06-17-8
SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
________________
TSBs found:44
2008 MUSTANG - US (English)
10-5-7
10-4-13
10-3-8
10-3-7
10-2-8
SYNC SYSTEM DEFAULTS TO OR STAYS IN PRIVACY MODE, MULTIPLE VEHICLE LINES
10-2-3
09-26-7
5.4L / 4.0L - DTC P0607
09-24-16
09-20-10
SPEAKER POP AND/OR RADIO INOPERATIVE/BLANK/LOCKED UP
09-20-4
AXLE WHINE
09-19-17
09-18-16
09-14-8
09-12-12
09-9-7
09-8-7
08-26-7
08-24-10
08-23-4
08-21-7
08-20-2
DOOR MOUNTED SUBWOOFER - STATIC, CRACKLE, POP OR DISTORTED SOUND - BUILT BEFORE 7/7/2008
08-17-3
08-12-9
INOPERATIVE RKE TRANSMITTER (KEY FOB) - DISCHARGED KEY FOB BATTERY
08-9-2
08-7-6
08-5-1
SATELLITE DIGITAL AUDIO RECEIVER SYSTEM (SDARS), MAY NOT SEEK ALL SIRIUS SATELLITE RADIO CHANNELS
08-3-4
08-2-4
07-23-10
CLUTCH PEDAL VERY LOW ENGAGEMENT EFFORT - 4.0L - BUILT FROM 8/20/2007 TO 09/06/2007
07-17-8
07-17-6
07-16-7
07-5-13
________________
TSBs found:33
2009 MUSTANG - US (English)
10-5-7
10-4-13
10-3-8
10-3-7
10-2-8
10-2-3
09-26-7
09-24-16
09-20-10
09-20-4
AXLE WHINE
09-18-16
09-14-8
09-12-12
09-8-7
09-7-7
4.0L ENGINE BELT SQUEAL OR CHIRP NOISE ON COLD STARTUP
08-26-7
08-24-10
08-23-4
08-21-7
08-21-2
SYNC SOFTWARE PROGRAMMING SERVICE TIPS
08-20-2
08-19-10
4.0L DTC'S P030X, P0300, P0316, P0172, P0175 OR DRIVABILITY CONCERN - VEHICLES BUILT BETWEEN 6/3/2008-7/21/2008
08-17-3
________________
TSBs found:23
  • 2 weeks later...
New TSB. PDF file is to big to load on the site. It has pic's explaining the work.
WATER LEAK—FRONT FLOOR AREA TSB 08-26-7
FORD:
2005-2009 Mustang
This article supersedes TSB 07-14-6 to update the 2. Using a garden hose equipped with a shower
model years, part list and service procedure. head attachment, or similar device, run water
onto the vehicle being sure to direct water over
ISSUE the roof ditch moldings, side window weather
Some 2005-2009 Mustang vehicles may exhibit a strips, and windshield / cowl panel area. While
difficult to diagnose water leak in the front floor water is being applied to the vehicle, have an
area. This may be caused by loose grommets assistant inside the vehicle verifying the location
and/or sealer skips around the cowl area, loose of the water intrusion.
A-pillar window weatherstrip retainer, misaligned
body harness grommet through the firewall, Water Leak Inspection / Repair Procedure
misaligned body harness grommet from the Inspect the following areas for visible signs of leaks
passenger door. and follow the appropriate repair steps.
ACTION 1. Verify that the plastic cowl panel grill is evenly
Follow the Service Procedure steps to correct the seated against the windshield and not warped.
condition. If warped, replace with current service stock.
SERVICE PROCEDURE 2. Remove the cowl panel grill. Refer to Workshop
Manual (WSM), Section 501-02, and inspect for NOTE
proper cowl panel mount grommet installation
DO NOT REMOVE THE DASH OR THE DASH and pinch weld sealing. Water may enter the
INSULATOR AT ANY TIME DURING THIS cowl channel, through the cowl panel grommets
PROCEDURE. / seals or forward pinch weld, potentially
Water Leak Testing Procedure causing a sloshing sound and/or water leaking
down the dash kick panel area. If there is
1. To pressurize the cabin open trunk and remove standing water in the cowl channel, remove by
the floor carpet. Remove the plastic tail panel siphoning through a cowl panel mount grommet
cover. Remove side carpet push pins and move hole. (Figures 7-8 - end of article)
the carpet aside. Locate the body vents in the
lower rear corners of the trunk (rear of wheel 3. Verify that the ten (10) cowl panel mount
wells) and tape them off. Close the trunk. Place grommets and seals are installed and sealing
the blower motor on high. Turn air recirculation tightly to the vehicle. If any are missing, or the
to off mode. Close windows and doors. Open seals are damaged, replace as necessary.
the hood and spray soapy water along body (Figure 1)
seams / grommets, particularly around the
A-pillar / fender and hood hinge area, and
check for bubbles.
NOTE
DO NOT REMOVE COWL GROMMETS DURING
WATER TESTING. (FIGURE 7 AT END OF
ARTICLE)
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do
the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper
vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a
Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation
determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article.The information in this Technical Service Bulletin
(TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates.The most recent information is
available through Ford Motor Company’s on-line technical resources.
Copyright ã 2008 Ford Motor Company Online Publication Date December 15, 2008 PAGE 1
TSB 08-26-7 (Continued)
Figure 1 - Article 08-26-7 Figure 2 - Article 08-26-7
a. Remove old cowl grommets and clean entire NOTE
cowl surface with a suitable wax and grease DO NOT USE SILICONE.
remover. If silicone and/or seam sealer was
used to seal grommets, ensure all sealer is 5. Check the main body wiring harness grommet
removed before installing new grommets. for proper seating into the bulkhead on the
driver / passenger side.
b. With surface clean and prepped, snap the
hot melt cowl grommet into cowl panel. a. Position the grommet into the bulkhead
making sure the grommet is fully seated and
c. Using a suitable heat gun, heat the hot melt sealed. If there is any aftermarket wiring
cowl grommet until the hot melt material installed through the grommet, reroute and
begins to squeeze out from under the seal as necessary. To ensure proper sealing
plastic grommet. Do not over heat the around the wiring harness grommet, apply a
grommet because deformation of the plastic small amount of Motorcraft Seam Sealer
grommet may occur. and install the grommet. (Figure 3)
d. After heating the grommets, a light amount
of pressure may be applied to the outer
perimeter of the grommet to help sealing.
e. Do not over heat around windshield or
fender edges or damage may result.
NOTE
HEAT SEALED GROMMETS WERE USED IN
PRODUCTION STARTING WITH VEHICLES BUILT
ON 9/4/2008.
4. Inspect the cowl panel to bulk head pinch weld
and A-Post to cowl joint for any skips in seam
sealer or excessive gaps between panels.
Figure 3 - Article 08-26-7
a. To ensure a water tight seal, apply a small
amount of Motorcraft Seam Sealer to the 6. Verify that the door to the A-pillar wiring
pinch weld and work into seam with harness grommet is fully seated into the
fingertip, leaving a small amount on the A-pillar.
edge, especially near the windshield center
a. To ensure proper sealing around the wiring
bracket area. (Figure 2)
harness grommet, apply a small amount of
Motorcraft Seam Sealer and install the
grommet into the A-pillar. (Figure 4)
PAGE 2
Figure 4 - Article 08-26-7 Figure 6 - Article 08-26-7
7. Remove and inspect the foam seal of window b. Assemble other trim as required.
weatherstrip retainer at the A-pillar. Tears in the
foam seal may allow water to enter the vehicle, 8. If no leaks are found in these areas, refer to
between window weatherstrip retainer and the WSM, Section 501-00 for water leak
A-Pillar, and travel inside the interior A-Pillar diagnostics.
trim molding into the dash kick panel area.
PART NUMBER PART NAME (Figure 5)
9R3Z-63517C58-A Retainer-Cowl Panel
9R3Z-6351238-A Retainer-Weather Right Side
9R3Z-6351239-A Retainer-weather Left Side
TA-2 Motorcraft Seam Seal
WARRANTY STATUS: Eligible Under Provisions Of
New Vehicle Limited
Warranty Coverage
IMPORTANT: Warranty
coverage limits/policies are
not altered by a TSB.
Warranty coverage limits
are determined by the
identified causal part.
OPERATION DESCRIPTION TIME
Figure 5 - Article 08-26-7 MT082607 Use SLTS Operations If Actual
Available; Claim Additional Time
a. Replace window weatherstrip retainer, if Diagnosis Or Labor
foam seal is damaged. (Figure 6) Performed As Actual Time
DEALER CODING
CONDITION
BASIC PART NO. CODE
63517C58 07
PAGE 3
Figure 7 - Article 08-26-7
PAGE 4
Figure 8 - Article 08-26-7
PAGE 5
Are these TSB's covered under warrenty? Or just something Ford is aware of that we have to take care of on our own? I am in the process of buying an 07 GT500 and would like to learn as much about this stuff as I can. Looks like the most serious issue is the Water Leak and Trans issue's. I have seen some people post about even having the second generation trans. How would I know whats in the car when I get it?
  • 10 months later...
Thanks Grabber for your hard work. It paid off for me. Dealer could not identify my SGT's issue. I came home found your TSB listing (TSB 08-9-6) and took it into the dealer. :salute:
Kind of sad YOU had to find it :headscratch:
Way to go Rob. You da man!
:salute:
  • 4 months later...
The first post has been updated to be current on all 2007 - 2009 TSB's.
Here's the list that is also in Post #1:
10-5-7
10-4-13
10-3-8
10-3-7
10-2-3
09-24-16
09-20-4
AXLE WHINE
09-19-17
09-18-16
09-14-8
09-12-12
09-9-7
09-8-7
08-26-7
08-24-10
08-23-4
08-21-7
08-17-3
08-9-2
08-8-5
08-7-6
08-5-10
08-3-4
08-2-4
07-21-12
07-20-3
07-19-1
07-18-2
07-17-8
07-17-6
07-16-7
07-12-3
07-6-7
07-5-13
07-5-8
07-4-3
07-1-7
06-26-2
06-26-1
06-25-15
06-25-3
06-21-19
06-21-7
06-17-8
________________
TSBs found:44
10-5-7
10-4-13
10-3-8
10-3-7
10-2-8
10-2-3
09-26-7
09-24-16
09-20-10
09-20-4
AXLE WHINE
09-19-17
09-18-16
09-14-8
09-12-12
09-9-7
09-8-7
08-26-7
08-24-10
08-23-4
08-21-7
08-20-2
08-17-3
08-12-9
08-9-2
08-7-6
08-5-1
08-3-4
08-2-4
07-23-10
07-17-8
07-17-6
07-16-7
07-5-13
________________
TSBs found:33
10-5-7
10-4-13
10-3-8
10-3-7
10-2-8
10-2-3
09-26-7
09-24-16
09-20-10
09-20-4
AXLE WHINE
09-18-16
09-14-8
09-12-12
09-8-7
09-7-7
08-26-7
08-24-10
08-23-4
08-21-7
08-21-2
08-20-2
08-19-10
08-17-3
________________
TSBs found:23
