mastersmech1 Posted November 3, 2008 Report Share Posted November 3, 2008 Does anyone know if it is critical where you mount the band with the sensor? I know you want the sensor on the opposite side of the valve stem and that there is a direction ( One side of the sensor is to be matched up with the outside edge of the wheel.) My question is, do you want if centered on the wheel or towards the inside or outside of the wheel? Link to comment Share on other sites More sharing options...
SGT/SC2873 Posted November 4, 2008 Report Share Posted November 4, 2008 Does anyone know if it is critical where you mount the band with the sensor? I know you want the sensor on the opposite side of the valve stem and that there is a direction ( One side of the sensor is to be matched up with the outside edge of the wheel.) My question is, do you want if centered on the wheel or towards the inside or outside of the wheel? when they broke down my tires and wheels couple of weeks ago the bands were located on the outside of the wheel with the sensors 180 from valve. They installed sensor with new band in same location. Craig Link to comment Share on other sites More sharing options...
mastersmech1 Posted November 4, 2008 Author Report Share Posted November 4, 2008 when they broke down my tires and wheels couple of weeks ago the bands were located on the outside of the wheel with the sensors 180 from valve. They installed sensor with new band in same location. Craig Thanks Craig, thats good info. John Link to comment Share on other sites More sharing options...
Grabber Posted November 4, 2008 Report Share Posted November 4, 2008 MM, do you have the sensor training tool ? - here's the sensor training required. TPMS_Sensor_Training.pdf Here's what happens with bad sensor installs: TPMSWAN.pdf TPMS_Sensor_Training.pdf TPMSWAN.pdf Link to comment Share on other sites More sharing options...
SGT/SC2873 Posted November 4, 2008 Report Share Posted November 4, 2008 MM, do you have the sensor training tool ? - here's the sensor training required.TPMS_Sensor_Training.pdf Here's what happens with bad sensor installs: TPMSWAN.pdf Grabber, thanks for the post - good information. Guess I am ok as we just swapped out the sensors to the new wheels and I had them rotate at the same time. The light came on when first cranked and then went out after just a couple miles. Craig Link to comment Share on other sites More sharing options...
SCGT500 Posted November 4, 2008 Report Share Posted November 4, 2008 MM, do you have the sensor training tool ? - here's the sensor training required.TPMS_Sensor_Training.pdf Here's what happens with bad sensor installs: TPMSWAN.pdf MM has my tool. In some cases the sensors will be picked up after a few miles without training. Link to comment Share on other sites More sharing options...
